Fuel cap door pushed out
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Diddy Spicebush, May 15, 2022.
  1. May 15, 2022 at 4:40 AM
    Diddy Spicebush
    Diddy Spicebush [OP] Well-Known Member
    Brent
    Saco Maine
    2003 sr5 2wd x-cab,and 2017 6/spd m/t sport
    Yakima roof and bed rack and tubular rear bumper.
    has anyone had a problem with their fuel door? It was fine when I opened it but when I closed it it went up and out. Something pushed it all over the place. How do I replace the door?
  2. May 15, 2022 at 4:42 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Drill the rivets holding it on I assume. The fuel door is the cheapest made part of these trucks :annoyed:
    Tacospike and wilcam47 like this.
  3. May 15, 2022 at 5:25 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Just lubricate its hinge once in awhile, and you'll never have an issue.
    AZ Pete and beergeek like this.
  4. May 15, 2022 at 5:49 AM
    Diddy Spicebush
    Brent
    Saco Maine
    Since I posted this I’ve seen the rest of the threads. Wow this is a common problem.
  5. May 15, 2022 at 7:32 AM
    wayne0
    wayne0 Well-Known Member
    The same thing happened to me as well. Bent it back and lubed it. It's fine now.
    wilcam47 likes this.
  6. May 15, 2022 at 8:05 AM
    eurowner
    eurowner Duke Sky
    Scoty
    And make sure the “leash” doesn’t get pinched!
    zoo truck[QUOTED] and 5nahalf like this.
  7. May 15, 2022 at 8:36 AM
    Diddy Spicebush
    Brent
    Saco Maine
    I think that is what happened. That got bound up and pushed it out.
  8. May 15, 2022 at 8:38 AM
    eurowner
    eurowner Duke Sky
    Scoty
    I have caught mine doing it a few times.
  9. May 15, 2022 at 8:39 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    It easily adjustable, back into position. Just take your time doing so.
  10. May 15, 2022 at 9:01 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    This is usually the issue, the leash gets pinched and bends the thin hinges.
