fuel capacity 09 pre runner sr-5 v-6 6 speed
Discussion in 'Toyota Trucks & SUVs' started by hotrod45, Aug 26, 2011.
  1. Aug 26, 2011 at 4:22 AM
    hotrod45
    hotrod45 [OP] Well-Known Member
    paul
    sarasota fl
    16 sr 5 access cab
    i am in need of knowing the exact fuel capacity of my 09 taco. i am aware that the stated gallonage from the factory is typically + or - something. i am interested in an accurate number.
  2. Aug 26, 2011 at 7:15 AM
    hotrod45
    paul
    sarasota fl
    16 sr 5 access cab
    manual didn't come with this used vehicle.
  3. Aug 26, 2011 at 10:01 AM
    hotrod45
    paul
    sarasota fl
    16 sr 5 access cab
    yes, this helps a lot. good starting point. thanks for your help here.
  4. Aug 26, 2011 at 10:02 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    and when the lights comes on you have what like 3-4 gallons left
  5. Aug 26, 2011 at 10:13 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I typically drive about 20ish miles after the light comes on, it's usually about 18ish gallons.
  6. Aug 26, 2011 at 11:01 AM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    On almost all Toyota's when the gas light comes on or your needle hit's empty, you have around 3 gallons in the tank left.
  7. Aug 26, 2011 at 11:07 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    The Gauge (+/- 0.5 gal.):
    FULL: 21 Gallons
    3/4 line: 16 (down 5)
    1/2 line: 12 (down 9)
    1/4 line: 8 (down 13)
    Light On: 4 (down 17)
    E line: 3 (down 18)
