Fuel Catalyst?
Discussion in 'Performance and Tuning' started by Tacoberry, Dec 1, 2008.
  1. Dec 1, 2008 at 7:28 PM
    Tacoberry
    Tacoberry [OP] Member
    Richmond, Kentucky
    2004 Prerunner V6 Double Cab
    Lots of dog hair
    Found this on AutoAnything. I don't know what type of catalyst could do this to gas, diesel or jet fuel. Any chemists in the house?
    Fitch Fuel Catalyst
    For Your 2007 Toyota Tacoma | Change Vehicle
    [​IMG] [​IMG] The Fitch Fuel Catalyst kit
    [​IMG] For Holiday Delivery
    Simply order by 12/15/2008.
    AutoAnything: $195.95 Shipping: Free Shipping
    Customer Rating: [​IMG] (2 Reviews)
    Submodel: 4.0L V6
    Easy Returns
    1-Year Lower Price Guarantee
    Secure Shopping
    Select options for your 2007 Toyota Tacoma
    Bolt on Fuel Treatment Kit Ships between 12/02/2008 - 12/03/2008
    $195.95
    Features
    • The Fitch Fuel Catalyst is a permanent bolt-on fuel enhancer
    • Improve fuel economy by up to 1 - 2.5 mpg
    • Enhances fuel quality by boosting the octane in gasoline
    • Allows the use of lower octane fuel
    • Increases the cetane and lubricity in diesel fuel
    • Better fuel quality delivers added horsepower and torque
    • High-quality fuel helps reduce emissions
    • Reduces number of annual oil changes
    • Keeps injectors, jets and spark plugs cleaner for reduced maintenance
    • Completely maintenance free—install it and forget it
    • Easily installs in your fuel line like a fuel filter
    • Your Fitch Fuel Catalyst is backed by a 250,000 mile warranty
    Description
    Boost power, reduce emissions and save at the pump while you’re at it. The Fitch Fuel Catalyst enhances gasoline by boosting octane and bolsters diesel by improving cetane and lubricity. Designed in union with the Department of Defense, Fitch boosts all fuel types—diesel, gas, even JP fuels.
    Fitch Fuel Catalyst pre-treats fuel before combustion. By running through Fitch’s proprietary metal alloy, normal fuels transform into superior-quality fuels. And, quality fuel means more power, increased MPGs and lower emissions. Plus, it allows premium-fuel engines to run lower-grade gas with no performance loss.
    Not to worry, the Fitch Fuel Catalyst simply bolts right in under the hood. Each system comes with vehicle-specific quick-release fittings, so it’s easy to patch right in-line with your vehicle’s fuel system. What’s more, your Fitch Fuel Catalyst system is backed by a 250,000 mile warranty.
  2. Dec 2, 2008 at 7:31 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    For half that price I'll happily send you a lifetime supply of snake oil.
  3. May 4, 2013 at 1:13 PM
    RELLIM
    RELLIM Well-Known Member
    IOWA CITY IA
    2010 ACC CAB 4X4 V6 SR5 TRD
    Scan Gauge II, AFE air filter, charcoal intake filter delete Fitch Fuel Catalyst, Alpine iDA-X303, AMS OIL (ENGINE) Bilstein 5100 RHA series
    I have this kit installed on my 2010 Taco.
    No it don't give you 50 miles to the gallon, but it has other good benefits.
    I've used it in many different engines such as snowmobiles and motorcycles, it keeps fuel fresh its able to boost octane . The web site has more info.
  4. May 4, 2013 at 2:48 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    There was an article on the product in Off Road Adventures.
    While they proved that it doesn't do to much to quality fuel that has been in your tank for a short time, it DOES reconstitute old fuel. Increasing its degraded octane back to "Par" per say.
  5. May 4, 2013 at 5:53 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    damn I was gunna buy 4 and pray to turn 91 into 110 octane :(
    I suppose Ill just ground my muffler bearing to the frame.
  6. May 4, 2013 at 5:55 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    They made the marketing mistake of using the same name as a number of additives... including some pellets that you add to the tank that don't go away.
  7. May 4, 2013 at 7:18 PM
    RELLIM
    IOWA CITY IA
    Ut oh it was a mistake posting on this subject.
    I know it has worked for me. But Dont expect big gains form it.
    I know it keep fuel fresh, it would boost octane one or 2 points but not Make 87 lnto 110.
  8. May 4, 2013 at 8:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I used something like this before. I grew hair on my knuckles, so I threw it away.
  9. May 4, 2013 at 8:56 PM
    RELLIM
    IOWA CITY IA
    Do you have hairy palms Chris?
    Lol
    J/k
  10. May 4, 2013 at 8:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    *looks at palms*
    Nope......
  11. Feb 2, 2015 at 4:47 PM
    RELLIM
    IOWA CITY IA
    Sorry its been so long.
    The Fitch fuel catalyst is EPA certified and registered under US Federal Register Volume 54:40 CFR 85.2114 (1)
  12. Feb 2, 2015 at 4:57 PM
    Yota64
    Yota64 Professional Threadjacker
    Will it work with a 3rd gen?
  13. Feb 2, 2015 at 5:12 PM
    RELLIM
    IOWA CITY IA
    Yeah, works with any gas or diesel engine. Look up Fitch fuel catalyst, look up the home site, there is lots of info on the site.
  14. Feb 2, 2015 at 6:23 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Off-road Expo magazine also did an article on it. It works very well, bringing old fuel which has been sitting, back to original octane levels.
  15. Feb 3, 2015 at 7:42 PM
    RELLIM
    IOWA CITY IA
  16. Feb 4, 2015 at 10:32 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    When you are researching these type of products, they generally list supporting evidence/documents. Oddly enough, those documents are generally what will tell you they are full of shit. Companies try to present professionally with the understanding that no one will take the time to review. They also know that most people WANT these products to work and are very easily swayed. They hide the lie in plain sight.
    I did some digging and looked up some of the research Fitch (aka FuelStar) cites and found just that.
    *Oddly enough, the ONE professional research paper that supports their claims was not cited. Maybe because the results concluded very minimal reduction in oxidation*
    1: Most of the research was done by people barely qualified to do high school homework, much less qualified to orchestrate and document scientific papers. Procedures were very vague and allowed the "testers" a lot of latitude that could easily provide room for fudging results. Conclusions didn’t support the hypothesis, hypothesis supported the conclusions - a very good indicator of "research/testing" with a predefined conclusion.
    2: Fitch (aka FuelStar) has been CITED for "Section 9884.7 (a)(1) False and Misleading Statements" and "Section 3373 Inserting/Withholding info to cause document to be False/Misleading"
    3: According to this SITE, Fitch (aka FuelStar), despite their claims, controls who can test their products and won't support 3rd party testing:
    4: Most surprising find was there is some credibility behind their claim. The US Army did some research into using the catalyst to reduce and/or reverse oxidation of aged diesel fuels (a well known issue in the military is the deterioration of diesel fuels over time). Their research found that this product was helpful in revitalizing old diesel fuel and reversing oxidation under certain conditions.
    Read more about it here: http://immortality.co.nz/fuelstarletter.html
    5: My Conclusion: This product is a truth stretched to the braking point. Fitch had minimal success and is taking it as far as they can go with "False and Misleading Statements" and by "Inserting/Withholding info to cause document to be False/Misleading." Unless you plan on running bad fuel (that has been sitting for months) through the "catalyst" I don't see any benefits at all. Even still, the amount of oxidation reversed, from what I read, would be very minimal, making this system cost prohibitive.
    Not exactly snake oil, but doesn't live up to the claims.
  17. Feb 4, 2015 at 10:59 AM
    RELLIM
    IOWA CITY IA
  18. Feb 4, 2015 at 11:19 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Basically that outline's a suggested stadardized testing protocol and good practices. As I said, the procedures of the cited tests already accomplished are so ambiguous, the results are pretty much useless. While the author didn't go as far as to say this, it was pretty much implied.
    Before this technology/concept can be taken seriously, the research will have to be taken seriously.
  19. Feb 4, 2015 at 7:21 PM
    RELLIM
    IOWA CITY IA
    This really kind of interesting, it's not snake oil but there's not enough info or conclusive testing to say it really works.
    So what kind of test would prove it works or is a flop?
    Is the GSA contract fake?
  20. Feb 4, 2015 at 8:06 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Your link outlines what needs to be done for conclusive testing and its only a starting point. And thats really only the begining. Read the Government paper and look at how much research and time they put into their papers compared to the crap Fitch posts.
    Holding a government contract isn't hard to do. The testing done by the US Army shows some benefits to reducing and revitalizing old diesel fuel. Its not very effective, but in government terms, not very expensive either. Im not surprised the military would buy this.
    I only have 7 years in the Navy and Ive seen the government buy some pretty stupid shit. Ask anyone with military experience.
