Fuel cell for extra storage?
Discussion in 'Technical Chat' started by JJ04TACO, Nov 24, 2016.
  1. Nov 24, 2016 at 7:42 AM
    JJ04TACO
    JJ04TACO [OP] Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    Just throwing this out there. Would it be possible to have a fuel cell in the bed, wired with a fuel pump, and plumbed to pump fuel into the filler neck for refueling in the go? The delema for me at least would be getting fuel into the main tank safely and reliably. I just drove to Moab last month from Dallas, and the extended range would be nice, as well as I took a route that didn't lend itself to many places to stop. (Not an issue if you stop when you can as opposed to when you have to. , but still.). System could be removable, and it would eliminate the need to manually fill from a jerry can.
    Another option would be to simply run a line from the cell and manually fill up with a siphon pump or if you were fancy a fuel pump just because.
    I remember having dual tanks on my moms old chevy truck and flipping a switch to swap tanks. It was convenient because we had horses and we traveled a lot in the summer for trail riding competitions.
  2. Nov 24, 2016 at 8:35 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I knew a guy who installed a 'transfer tank' opposite his regular tank on his old hilux 4x4. Of course he had to re-route his exhaust to the middle (next to the drive-shaft ! ) . A neat solution that was almost invisible from outside the truck. I don't recall whether he rigged a pump or a syphon.
    Another old solution, I recall, was installing a tank where the spare tire used to be.
  3. Nov 24, 2016 at 8:43 AM
    Thelgord
    Thelgord The Pantagonist
    Augusta, GA
    '13 TRD (OffRoad, 4x4)
    SOS Rocksliders, All Pro skid plate, Procomp add-a-leaf, Bilstein 5100 @ 1.75", CB, high-lift jack
  4. Nov 24, 2016 at 9:09 AM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    I'd be ok with a bed mounted setup. Although the spare location is nice. Maybe cut a hole in the bed for a flush mounted filler Location. I was going for simplicity. I don't mind the cell in the bed.
    The real trick is getting the fuel into the main tank w/o throwing some sort of code (pressurized tank and all). And I wouldn't want to compromise the tank itself. Just the filler neck. How about a small fitting that a hose can be threaded onto when in use and capped off when not in use? Maybe a check valve in line somewhere to prevent back flow and hold pressure too.
    Maybe the tanks would have to be vented or have a return line of sorts too, to allow for air displacement to move between tanks while filling. Damn that just got too complicated. Lol...
  5. Nov 24, 2016 at 9:21 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Use a junction pipe in the fill hose. Get/build one that has two ports. Place them so one is on top and one is either on the side or the bottom. Run two hoses to the fuel cell (which generally have a vent/return fitting on top). Use an aux fuel pump (transfer pump). As you pump fuel, it will vent from the OE tank to the aux. MAKE SURE YOU USE GROUNDING STRAPS.
  6. Nov 24, 2016 at 9:21 AM
    Thelgord
    Augusta, GA
    The devil is in the details LOL!
    If you are just going for a transfer tank in the bed, it can be fairly easy. Farmers do it all the time. Just run a hose off the pump and stop to "fill up"/transfer the fuel. Doing it while driving is when it gets complicated.
  7. Nov 24, 2016 at 9:33 AM
    Thelgord
    Augusta, GA
  8. Nov 24, 2016 at 11:08 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just get a dual tank transfer switch Like what the trucks with dual tanks use
    Just like you had in the Chevy
    I would tee in the line behind the fuel filter .
    No codes no problems
    When and if you want to remove the fuel cell just disconnect the line at the tank plug to keep the dirt out
    If I was wanting to haul extra fuel but not all the time be simple to use
  9. Nov 24, 2016 at 7:47 PM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    This might be the best option. I suppose it would be nice not to have to stop but it wouldn't be a huge deal. Just get a bigger fuel pump to speed up the process. Just have it in when I need it.
