Fuel Cells- Keeping fuel from Sloshing
Discussion in 'Long Travel Suspension' started by Siebler, Jul 22, 2012.
  1. Jul 25, 2012 at 10:40 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    cheapest wiffle balls i can find----http://www.Amazon.com/Diamond-Plastic-Training-Baseball-Package/dp/B0026LJQLA/ref=sr_1_15?ie=UTF8&qid=1343237925&sr=8-15&keywords=wiffle+ball
  2. Jul 25, 2012 at 10:41 AM
    Siebler
    Siebler [OP] Duck Killing Machine
    CJ
    Portland, OR
    99 Long Travel 5 lug, 01 Tundra 4wd
    TC LT Front, F67 on 12" shackle, LCE Underdrive Pulley, Flex-a-lite fan, DT headers, Super 44 muffler, 4:11's and Aussie Locker, 22 Gallon Fuel Cell, Beard seats, sliders, bed cage
    Wiffle balls, baffles, and foam keep the fuel from sloshing or shifting in the tank which can starve the pump as I experienced twice this week (again this morning in same exact place).
    My cell is doing it with over 10 gallons left which is why its a concern. if it was on the last few gallons id say whatever and just keep it more full than that but this isnt the case.
    Considering trying the PVC this weekend if I get time. Have other maintenance to do but if it doesnt take forever will get on cutting/drilling some to try this week. The only hard part I foresee is stacking around the pickup tube.
  3. Jul 25, 2012 at 10:51 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Okay thanks for the explination....why doesn't the stock tank do it?
  4. Jul 26, 2012 at 9:00 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Stock tanks have some baffles in them.
  5. Feb 24, 2020 at 12:14 PM
    LukeCC
    LukeCC Well-Known Member
    Luke
    Southern California (East County)
    2002 LT DCSB
    Resurrecting the dead here folks.
    I’m getting ready to run a fuel cell as a part of a bed cage I bough that I am customizing for my truck. It’s came with a little 10 gallon Cell and I don’t plan on plumbing it for a while. It won’t be my main source of fuel. I’m only looking to mount it in the cage and use it is 10 extra gallons of storage so I don’t have to drag along a gas can with straps anymore. The foam inside is definitely beat up and falling apart. I’m wondering if trying to replace the foam block is even necessary for the time being seeing as how sloshing and fuel cuts won’t be an issue for me as a storage cell.
    no need? Just pull it out and run it just like a gas can or are there other issues to consider?
  6. Feb 25, 2020 at 6:38 AM
    Canks
    Canks Well-Known Member
    San Diego
    08 DCSB in pieces; 04 Tundra Access cab also in pieces
    there are a few guys I can think of that run no foam and no other means of "slosh resistance". the only thing to look out for is the cell/bladder breaking from the force of the fuel sloshing. I have seen a cell or two come a part, not that common but it is possible. On a 10 gallon cell, I really wouldn't worry about, remove the foam all together and run it.
    Curious, where are you mounting it at?
  7. Feb 25, 2020 at 6:57 AM
    LukeCC
    Luke
    2002 LT DCSB
    So the cell itself is plastic with no bladder so that should t be an issue. I’m going to mount it where it was build to be mounted from the previous owner underneath the spare tire at the rear of the bed. I’m going to cut a portion of the bed out in order to allow it to lay flush with the bed. Sorta where the factory spare used to be
  8. Feb 25, 2020 at 7:03 AM
    LukeCC
    Luke
    2002 LT DCSB
    Here’s a picture of the cage before I started cutting and welding stuff. I circled the connecting points for the cell under the spare tire to give you a rough idea. Everything from the shock tower brace aft is going to being the same as pictured for the most part aside from the bedside mounts
  9. Apr 11, 2020 at 9:30 AM
    manesfesto
    manesfesto Well-Known Member
    Jacob
    Texas
    2001 LT Double Cab
    Been knocking around the fuel cell idea for a while now so this caught my eye. I think adding one similar to yours @LukeCC is ideal. Cut out the bed and flush mount it between the frame rails with supports tying it in to the frame.
    My big one Ive yet to get straight answers on is what pump set up people are using? I don't care to to much about having the gauge, as I use my mileage counter every fill up anyway.
    anyone have specific info on what pump and such people are using to work with the stock ECU and such?
    LukeCC likes this.
  10. Apr 12, 2020 at 12:27 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    You can use stock setup like @Cr250jumper did here:
    https://www.tacomaworld.com/threads/jds-02-tacoma-build.126596/#post-2450893
    manesfesto[QUOTED] likes this.
