Fuel consumption while idling - scangauge
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sechsgang, Aug 11, 2011.
  1. Aug 11, 2011 at 5:22 PM
    sechsgang
    sechsgang [OP] Well-Known Member
    06 DC TRD OR 4WD 6spd
    Does anybody here know what the V-6's fuel consumption while idling is? Maybo those with the scangauge? Does it give that info?
    Thanks a lot for any input!
  2. Aug 11, 2011 at 5:35 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Ultraguage gives that info in gal/hr. I can post it up tomorrow if no one does before then. I think it's like .4 gal/hr if I'm remembering correctly but don't quote me on that, my memory is a little rusty...
  3. Feb 6, 2013 at 4:16 PM
    djo991
    djo991 Active Member
    07 Double cab SR5
    Nothing on it .... FOR THE MOMENT
    i would like someone give me is gal/hr consommation when the truck is idling at his normal rpm , please , i want to know why i can only make 330-300km a tank(like 200miles ) maybe you can get this info with a ultragauge ?? with the v6 4.0L
  4. Feb 6, 2013 at 4:23 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  5. Feb 6, 2013 at 4:41 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    During the cold start-up it burns 1.5 to 1.6 gallons/Hr. ... after 3 minutes or so when it's reasonably warmed up it burns .4 to .6 gal/Hr.
    ... at least that's whay my UltraGuage indicates.
    **edit** I didn't realize this thread is super old. :eek:
  6. Feb 6, 2013 at 5:40 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Super old, but technically no one answered the old question either :)
    Winter cold with conventional oil, figure 1.6-1.7 gal/hr coming down to about 1.4 gal/hr pretty fast. Synthetic will start around 1.4-1.5 and fall. In the summer I've seen cold starts as low as 1.2 gal/hr.
    Fully warmed up idle, 700 rpm, no a/c, that's 0.33 gal/hr. With a/c, about 0.40 gal/hr. Figure at least 15 minutes of driving for it to get that low.
    The 1300 rpm idle that it likes to do if in neutral and over 10 mph, that's 0.60 gal/hr. Odd behavior here - if the a/c kicks on during high neutral idle, it'll still be 0.60 gal/hr, but rpm will drop to about 1000.
  7. Feb 7, 2013 at 8:17 AM
    djo991
    07 Double cab SR5
    thanks to you guys ill be watching this when i receive my ultragauge :D and .. when the truck gets repaired :eek:
  8. Feb 7, 2013 at 8:34 AM
    hutch96r
    hutch96r Well-Known Member
    San Antonio
    2013 SR5 4X4
    275 70 17 BFG TA KO ProComp shocks 2.75
    Damn, sorry about the truck! Hope it's back to you soon.
