Fuel consumption
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Neticstacoma, May 10, 2023.
  1. May 10, 2023 at 9:08 PM
    Neticstacoma
    Neticstacoma [OP] Well-Known Member
    Hi
    I have 2008 tacoma 2.7 5speed manual 4WD I am running 235/85R16 M/T with steel wheels most of my driving on the highways I have been reading that the 2.7 doesn’t consume that much of fuel but mine I feel like it does I have changed the spark plugs, engine, belts, fuel filter, fuel filter, greased the driving shaft but still feels something is missing
    When the tank is full I drive it the empty light turns on and it takes around 290 - 295 miles only
    Any idea guys?
  2. May 10, 2023 at 9:11 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    When the truck is idling does the tachometer needle bounce a little or is it steady? How many miles on truck?
  3. May 10, 2023 at 9:13 PM
    Neticstacoma
    No its steady
    It has around 134000 miles
    Steves104x4[QUOTED] likes this.
  4. May 10, 2023 at 9:22 PM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    Your tires are taller than stock. Track your mileage using GPS and compare to the trip odometer. You're probably going further and getting better mileage than you think.
    2015WhiteOR likes this.
  5. May 10, 2023 at 9:25 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Punctuation, for one.
  6. May 10, 2023 at 9:26 PM
    JasonLee
    15 TRD OffRoad
    Do this for a week, at least 100 mi and report back.
    essjay[QUOTED] likes this.
  7. May 10, 2023 at 9:27 PM
    JasonLee
    15 TRD OffRoad
    Are you light or heavy on the throttle? Are you driving City, hwy or mixed?
  8. May 10, 2023 at 9:38 PM
    Neticstacoma
    Thanks guys i’ll do that and see what am getting
  9. May 10, 2023 at 9:39 PM
    Neticstacoma
    No actually I am kinda in the middle but you can say am light on the throttle
    Mostly highways
  10. May 10, 2023 at 9:59 PM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    I try not to let my fuel tank get that low, it's not good for the fuel pump.
  11. May 10, 2023 at 10:29 PM
    Neticstacoma
    No just to count how many miles it will run
  12. May 10, 2023 at 10:29 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    I don't buy that. Your light comes on at 2-3 gallons. That's not enough to cool the pump? Really? Temperature huh? Do fuel pumps last longer in Canada than Southern California or Arizona? Just what are the cooling properties of gasoline? How many gallons does your pump need? 4? 6? 10?
    maineah likes this.
  13. May 11, 2023 at 1:53 AM
    Neticstacoma
    I have base single cab
  14. May 14, 2023 at 1:55 PM
    Neticstacoma
    Anybody with some ideas?
  15. May 14, 2023 at 1:59 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    The light trips at roughly 4 gallons in his truck.
    TacomaCZman likes this.
  16. May 14, 2023 at 2:05 PM
    amyracecar
    amyracecar suck it up buttercup
    Virginia Applejack
    SouthEast USA
    2013 AC V6 MT OR Spruce/Mica
    So what MPG are you actually getting?
    I have a 2013 V6 MT, I get 13mpg very consistently and calculate it every time I fill up to be sure.
    From what I have seen/others report, given my set up + how I drive, everything is fine with my truck.
    It is my driving that causes me to get 13mpg vs ~17mpg.
    I get the same 'lower' MPG in my car - 20mpg [reality] vs the 25mpg advertised - for the same reasons..
  17. May 14, 2023 at 2:54 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I do better with my manual 4L than I did with the 2.7 manual.
  18. May 14, 2023 at 4:09 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    The Ox may be slow but the Earth is patient. Fortune cookie after Gen Tso chicken
  19. May 14, 2023 at 4:37 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    295 miles/tank doesn't tell us anything unless you're driving it till it runs dry every time. When your fuel gauge gets to "E" you could have 1 gallon left, or 5 gallons left. It isn't precise. Figure out miles/gallon and get back to us.
    FWIW, my truck is usually getting pretty low somewhere around 275-300 miles for my normal everyday driving. I have gone 350 a few times on road trips. That translates to around 16ish mpg around town and 19-20 mpg on the road in my truck. I have no idea in your truck.
    I don't like to push things, when I get to 1/4 tank I start looking for a gas station. I was driving between Chattanooga and Dalton earlier today. An 18 wheeler caught fire and really messed up traffic. It took me over an hours to drive 4 miles. There were 2 cars that ran out of gas in that 4 miles. There was an exit with fuel 1 mile past where the truck was burning. I'm not going to be "That Guy".
    The 2.7 doesn't really do much better on gas than the 4.0. Especially a 4X4 with off road tires. That little engine is working harder. You buy the 2.7 to save a few thousand when you buy the truck. Without accurate information on your real mpg's it is hard to say, but I don't think you're far off what I'd expect.
  20. May 14, 2023 at 4:50 PM
    BlueCollarNerd
    BlueCollarNerd Member
    Maine
    2015 TRD OR
    Try cleaning the maf sensor and throttle body with the battery disconnected.
    Check if a brake is dragging.
    But like others have said your not getting a accurate reading using the odometer with bigger tires.
    Also being light on the throttle isn't always best when accelerating. Its a I4 so dont be afraid to rev it up. Try getting up to coasting speed sooner. And the biggest way to boost mpgs is coasting into stops, just learn to ignore the idiots who ride your ass into every stop sign or light.
