Fuel door issue!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WrecklessWilli, Jul 7, 2016.
  1. Jul 7, 2016 at 5:38 AM
    WrecklessWilli
    WrecklessWilli [OP] Member
    Austex/Telluride
    2009 Access TRD OR
    nada
    Just got a new to me '09 Access and the d#*@ fuel door barely opens 1/2 way, and I have to force it to get it even that far open. Question...IS THAT NORMAL?
  2. Jul 7, 2016 at 5:47 AM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    Not normal. Take a look at the hinge, it's probably bent. Also make sure the little plastic lanyard that holds the gas cap to the vehicle isn't coiled up in a weird way.
  3. Jul 7, 2016 at 6:09 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I personally don't think the fuel doors on these trucks were designed with any importance at all. jtweezy makes a good point of checking for any damage that may be affecting the door but you may also need to lubricate it. These fuel doors are notorious for getting hard to move and rusting/cracking paint.
    WOODEX M.E. likes this.
  4. Jul 7, 2016 at 6:15 AM
    Clearwater Bill
    Billy
    Largo Florida
    Yes. It's intentional to make fueling very difficult and theft even harder. Much cheaper than having an in vehicle fuel door release like most other vehicles since the early 90's.
    Of course it's not normal. Examine another Taco fuel doors operation and figure out what's wrong with yours. There's not much too it. It can't be that hard.
  5. Jul 7, 2016 at 6:46 AM
    WrecklessWilli
    Austex/Telluride
    2009 Access TRD OR
    nada
    Thanks for the quick replies. Yeah, that door design and implementation looks pretty cheesy. Although it didn't look bent, the hinge bracket now looks to be a likely candidate. A frustrated person could likely bang it closed and force the bracket inward causing the stamped edge to contact the inner housing. The metal is surprisingly thin. I'll pry it out a little, lube it and see what that does.
  6. Jul 7, 2016 at 6:27 PM
    RBTaco
    RBTaco Well-Known Member
    2013 RC 4X4
    Trac rac, tow hitch, fog lights, tonneau cover, Texas Edition rims, custom console, weathertech floor mats.
    My gas door and hinge had to be replaced before it was 2 years old. The hinge is very cheap and rusts and binds up. Then the sheet metal bends and and the door doesn't open far at all
  7. Jul 7, 2016 at 6:34 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    I had a deer run into the side of my truck years ago. No appearant damage, left behind some snot lol. The fuel door looks straight and flat but binds when opening after that. I just put on xtra wax and lube it good.:thumbsup:
  8. Jul 7, 2016 at 7:48 PM
    smd3
    smd3 Well-Known Member
    I overextended mine a bit while fueling with a gas can. I can't even figure out how it's bent, but it's never been the same.
  9. Jul 7, 2016 at 8:56 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    White lithium grease.
    The hinge on my wife's old Scion tC basically completely bound up on me. A liberal dose of the grease and it was back to almost new.
    Start there before you investigate changing/modifying the hinge.
  10. Jul 12, 2016 at 10:11 AM
    tgear.shead
    tgear.shead Well-Known Member
    Oil it. Then work it, then more oil, work it some more, lots of oil.
    Unless something is bent, that should fix it.
    The fuel door should swing open/closed with almost ZERO resistance.
  11. Jul 12, 2016 at 10:43 AM
    RBTaco
    2013 RC 4X4
    Like others have said, lubricate it well with a penetrating oil and then maybe some spray grease. But double check to see if the hinge is cracked or broken. I noticed the hinge was cracked and part of it was broken due to rust causing the hinge to stick.
