Fuel Door Latch
Discussion in '1st Gen. Tacomas (1995-2004)' started by ForestRunnerFrank99, Aug 14, 2019.
  1. Aug 14, 2019 at 12:05 PM
    ForestRunnerFrank99
    ForestRunnerFrank99 [OP] Well-Known Member
    Josh
    Rancho Cucamonga, CA
    '99 TRD 4x4 Manual 3.4l v6
    Fox Coil-overs, Dakar Leafs, Intake, Tires, Rims
    Hey guys, on Monday some dip thong broke my locking fuel door and stole an entire tank of gas from me. The lock works fine and the door isn't bent but the plastic retaining piece snapped so now my fuel door just flops around whenever I turn corners or hit bumps. Does any one know if I can find this part somewhere? I really don't want to spend $70+ on a whole new cylinder key set (69058-35140).
    Here is a pic of what I am looking for:
    GQ7227 likes this.
  2. Aug 14, 2019 at 12:38 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K02 AT’s RCI skid Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    Amazon has them for $52. Might be tough to find just that part. Maybe try a junkyard?
  3. Aug 14, 2019 at 12:41 PM
    ForestRunnerFrank99
    Josh
    I think I am going to have to go this route. What sucks is that the Tacomas are the #1 picked car in the junkyard, so getting any worthwhile parts is a pain.
    ChocoTaco88 likes this.
  4. Aug 14, 2019 at 12:42 PM
    monoman
    Dave
    tru dat! Good luck to ya!:thumbsup:
  5. Aug 14, 2019 at 12:43 PM
    96towcoma
    96towcoma Well-Known Member
    james
    1997 single cab 4x4
    I found it really cheap using google. Less than $20
    I’m considering going to the newer, non-locking style.
  6. Aug 14, 2019 at 12:50 PM
    ForestRunnerFrank99
    Josh
    Since I posted I have found other cheaper options. I still think $20 is somewhat of an overkill for a $2 piece of plastic. I'm thinking that may be a good idea, or at least the hinge so my fuel door doesn't flop around.
  7. Aug 14, 2019 at 12:54 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i do recall seeing a mod for this piece in the past several months, cannot remember off hand
    maybe it was @BartMaster1234 that had a fix :notsure:
    BartMaster1234 likes this.
  8. Aug 14, 2019 at 2:02 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    Maybe that part is used on other models of Toyota’s?
  9. Aug 14, 2019 at 2:24 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
  10. Aug 14, 2019 at 2:37 PM
    ForestRunnerFrank99
    Josh
    Unfortunately it's just a Tacoma part.
    GQ7227 likes this.
  11. Aug 14, 2019 at 2:37 PM
    ForestRunnerFrank99
    Josh
  12. Aug 14, 2019 at 3:08 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Perfectly fine. It’s 10x stronger than the OEM one since it uses half inch solid plastic instead of the thin stuff Toyota used.
  13. Aug 14, 2019 at 3:12 PM
    ForestRunnerFrank99
    Josh
    That's pretty cool! I'll try to see if I can find someone to print me one.
  14. Aug 14, 2019 at 3:19 PM
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
  15. Aug 14, 2019 at 3:21 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Now you can print more, sell ‘em, and recoup your cost!
  16. Aug 14, 2019 at 3:27 PM
    maynard911
    maynard911 Member
    1999 short cab 5sp white 280000 and counting
    Place a 1/2"dia.x 1/8" thick neodymium magnet on the upper right-hand screw head holding the plastic around the fuel filler. Close the door and the magnet will transfer to the fuel door in the proper position. To open stick the key in and pull. Works perfectly. I got the magnets on Amazon, but they are available in many places.
  17. Aug 14, 2019 at 3:29 PM
    Kens04Taco
    Kens04Taco Well-Known Member
    Sunland, CA
    2004 PreRunner 4x4
    kangs and thanngs
    Make one out of aluminum and put something around the edge to keep it from scratching. It’s just a catch
  18. Aug 14, 2019 at 3:53 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    I was thinking actually going different route. One of the most common ways of stealing cars was break out the fuel door (with the lock), then make a key for it. The same key usually opens the door and turns the ignition. So if your fuel door is stolen expect to have the car be stolen next day or so.
    On the other hand open fuel door without locking fuel cap is just asking for the cap and/or fuel to be stolen. The best solution is actually what is quite common in modern cars: fuel door open by the lever in the cabin or trunk. I still did not figure out how to do it in 1st gen Tacoma.
    GQ7227 likes this.
  19. Aug 14, 2019 at 3:59 PM
    Wulf
    rock raisin
    I have never heard of this. It seems like way too much work for someone who would rather punch out a window and ignition and be on their way :homer:
    I have two 90s Lexus cars (SC400 & LS400) that have an electronic fuel door lock with a switch inside to open the fuel door. Maybe would be a good donor for a retrofit to the Tacoma?
  20. Aug 14, 2019 at 4:05 PM
    RysiuM
    Rysiu
    This was common was to steal a car for resale. Busting window and ignition is just bad for business. :rolleyes:
    That might be a very good idea.
