Fuel door sticking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ABA180, Jun 22, 2013.
  1. Jun 22, 2013 at 3:30 PM
    ABA180
    ABA180 [OP] It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    The fuel door on my 2010 will only open about halfway. I can push it the rest of the way but don't want to force it or break something.
    Any thoughts? No recent hits to the truck at all.
  2. Jun 22, 2013 at 3:33 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Common problem... oil the hinges
  3. Jun 22, 2013 at 3:44 PM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Mine actually hits the inside and makes a horrible creaking sound. No idea why it started that. I have been too lazy to bend it out and find it a little funny to see people jump at the sound at the gas pumps
  4. Jun 22, 2013 at 3:45 PM
    ABA180
    East Bridgewater MA
    It seems like if I pushed it further I'd get the creaking and such.
    I'll try oiling them up..thanks for the tip!
  5. Jun 22, 2013 at 4:12 PM
    Brandon###
    Brandon### Well-Known Member
    mine does the exact same thing. the fuel door hits the inside about half way through opening it. i have tried pulling it out, but it didnt help
  6. Jun 22, 2013 at 9:38 PM
    ABA180
    East Bridgewater MA
    Silicone spray seems to help some, still a little contact..ugh
  7. Jun 22, 2013 at 9:49 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Mine does it too. 2011 with 45k miles. Gonna try some silicone spray.
  8. Jun 23, 2013 at 6:27 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    White lithium grease on the hinge pins. It will last longer than any oil, which will wash out in no time.
  9. Jun 23, 2013 at 6:47 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^This. If you take the truck to the dealer for oil changes, they should spray lithium grease on all the hinges, including the fuel door. (It's the "lube" in "lube, oil & filter".)
    If the door is hitting something, the hinge wire rod may be bent. Does the door fit flush when closed?
  10. Jun 23, 2013 at 7:04 PM
    ABA180
    East Bridgewater MA
    Yup, that's the odd part..no issues there.
