Fuel door
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Njgator, Sep 8, 2018.
  1. Sep 8, 2018 at 7:54 AM
    Njgator
    Njgator [OP] Member
    Bob
    I unfortunately live In NJ, the only state left where you can't pump your own gas. Well it appears that the "highly" trained attendants have somehow bent the hinges to the point where the door is contacting the body on my 2017. I have tried to bend back in place but I think is only making it weaker and eventually goes back to where it was.
    Has anyone had to replace the door on theirs? Looks like it might be riveted in place
  2. Sep 8, 2018 at 9:06 AM
    HacksawMark
    HacksawMark Well-Known Member
    Mark
    OREGON
    2018 Silver Tacoma V6 DCSB TRD OffRoad traded for 2019 Ford XLT 3.5L EcoBoost SC
    You forgot about Oregon......
    Tacotime24 likes this.
  3. Sep 8, 2018 at 9:20 AM
    salmonmigration
    salmonmigration Well-Known Member
    2018 TRD Sport 6MT
    So it's lined up okay again now? Why do you want to replace it?
  4. Sep 8, 2018 at 9:55 AM
    Wsteven
    Wsteven Well-Known Member
    2018 Tacoma TRD Pro
    Working on them
    Entire Door and Hinge have to be replaced together and they are Riveted in with special rivet (odd size) part number Toyota Fuel Door Rivet 90269-06017 very easy to remove and a total Pain in back side to get it right when installing if you use some other rivets because the Toyota ones fit tight so self align takes place.
    And BTW you rivet it from back side Not with the Fuel door open. You put the 2 rivets in place close the door use folded paper to line the door up and hold it in position then from the under side you do the rivets use body paint tape to hold in place and hold it shut, many just do it the other way that works.
  5. Sep 8, 2018 at 10:00 AM
    Loaded NightraiN
    Loaded NightraiN Well-Known Member
    17 TRD Off Road
  6. Sep 8, 2018 at 10:19 AM
    BlakeM
    BlakeM Well-Known Member
    Blake
    Gonzales, LA
    2023 T4R.SR5.4WD.OMG.LOL.WTF
  7. Sep 8, 2018 at 12:22 PM
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    Oregonian here. You can only pump your gas in small rural towns. Even then most gas stations still fill up for you. I hunt the east side of the state quite a bit and have yet to pump my own gas. Well, that doesn't include filling up at Pac Pride, but those have always been self serve.
    The last guy that filled my tank slammed the gas door and it didn't close straight... he had to pull it back open and try again. I told him he probably shouldn't do that. He just gave me a deer in the headlights look..
  8. Sep 8, 2018 at 12:28 PM
    rickm
    rickm Well-Known Member
    Rick
    MA
    2018 BLK Tacoma TRD Pro
    Open and close the door yourself, let them pump the gas regardless of the look you get.
  9. Sep 8, 2018 at 1:59 PM
    jdr3366
    jdr3366 Well-Known Member
    When I lived in NJ I would race the attendant to the pump. Actually, it wasn't much of a race. They came out and reminded me I'm not allowed to pump my own only after I was half way done.
    Of course, that's the least of NJ's problems.
    Once, the attendant went to squeegee my rear plastic window. What was in the solution fogged the plastic for good. Doofus.
  10. Sep 8, 2018 at 2:02 PM
    kite_325
    kite_325 A simple human, being
    North Carolina
    2017 TRDOR
    ^ This.
    Also, I may have pumped my own gas in NJ before... :spy:
  11. Sep 8, 2018 at 4:53 PM
    BSFord
    BSFord Well-Known Member
    2018 TRD Sport 4x4
    Clazzio PVC Seat Covers Dashcam install TRD Pro Grill MESO Total Tail Stage 1 Tailgate Lock vled total interior light upgrade TRD Pro Shift knob N2 Designs Autostart w/ smart phone module
    Is this true!?
  12. Sep 8, 2018 at 5:44 PM
    ELT2JV
    ELT2JV Well-Known Member
    17 TRD OR ACLB
    8112 front 8100 rear. Method NV with 265/75/16 KO2.
    Its cause they don't put enough/any anti-seize in the hinge which causes it to bind and bend. Buy some and work it in there.
  13. Sep 9, 2018 at 7:19 AM
    Dcross
    Dcross Well-Known Member
    Southern Illinois
    2017 Super White TRD Off Road Dbl cab
    Agree!!! Anti-seize works miracles.
  14. Sep 9, 2018 at 10:25 AM
    FrenchiesTaco
    FrenchiesTaco Well-Known Member
    Kevin
    NJ
    2018 Inferno Sport
    I go to the BJs in Linden NJ and pump my own gas. There is always a long line and the attendant's are overworked, so it help them and I won't scratch my truck.
  15. Sep 9, 2018 at 10:36 AM
    NC_IslandRunner
    NC_IslandRunner Well-Known Member
    Rory
    2018 Inferno Taco TRD offroad
    I went through NJ on a trip, those morons think they deserve a tip for something I didn't ask them to do, and think it is a good job. But my opinion of that state has never been high. It's only a spot or 2 behind California for worst.
    Maybe get some decal instructions added to the gas door to help them out?
    1bad2k likes this.
  16. Sep 9, 2018 at 11:53 AM
    Scotty Dosent Know
    Scotty Dosent Know Well-Known Member
    2017 Tacoma DCSB
    Always make sure I have enough gas to get into and back out of Oregon for this exact same reason LOL
  17. Sep 9, 2018 at 7:09 PM
    HacksawMark
    Mark
    OREGON
  18. Sep 10, 2018 at 6:33 PM
    Joisey
    Joisey Well-Known Member
    I too unfortunately live in this asshole state. I get out of the car and open the fuel door and remove the filler cap. I don't trust those pump jockies anywhere near my vehicles.
    Njgator[QUOTED][OP] likes this.
