fuel duration on an immobilized vehicle with engine running
Discussion in '2nd Gen. Tacomas (2005-2015)' started by volcomig, Jul 13, 2013.
  1. Jul 13, 2013 at 7:16 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    I stand corrected then. but once again to try and put my view into perspective, you cannot buy a generator with the rpm band the truck has to deal with. if you could, it would not be reliable. ideal power generators have two rpms closely related so they oil well at both idle and loaded.
    and like a typical forum junkie, with no evidence or factual data at all, I can guarantee a 1gr to last longer at 2000rpm vs idle. . . . . :rolleyes: crap
  2. Jul 13, 2013 at 7:27 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    I do see your viewpoint and agree with it for most of the popularly posed questions on TW. IMHO Not the best thing for a motor, but nowhere near the worst. All in all a dedicated generator is the better choice for constant use, but for some situations idling just makes better sense IMO.
  3. Jul 13, 2013 at 7:53 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    In all my years of being in the automotive service and repair industry, I have never once seen a vehicle come in with some sort of problem which originated from it "idling too much." While I do agree that idling will waste an ass ton of gas unnecessarily (this is especially true in California), I highly disagree with the fact that idling a vehicle for an extended amount of time is doing some sort of damage to it. I have never seen a vehicle with a problem because of it as I said above nor have I seen some sort of reports or statistics floating around which indicate that it is damaging anything. That is my two cents.
  4. Jul 13, 2013 at 8:18 PM
    Canazes9
    Canazes9 Well-Known Member
    David
    Texas
    '07 Dbl Cab TRD Sport / '12 Dbl Cab Offroad
    Could not agree more! The truck isn't a very effective generator and there are much more efficient methods to generate electricity, but idling for extended periods won't harm the engine.
    David
  5. Jul 13, 2013 at 11:24 PM
    AK 08TACO
    AK 08TACO Well-Known Member
    Kyle
    Wasilla, AK
    I work on the arctic in Alaska where the temp may drop to -60 ambient in the winter. Our work trucks, which are F-series pickups both gas and diesel idle 24/7 for nearly a month straight sometimes. The only problems that occurs are with the diesels and the new exhaust system, because they will not regenerate at idle.
    So as far as idling straight on a few camping trips, I'd say you'll be fine. But like others have mentioned you need to figure out if the bed outlet will power your equipment.
  6. Jul 13, 2013 at 11:31 PM
    Sigi
    Sigi Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
    I went camping and hooked up a light to the back up my truck too and I left it on for like 3 hours with out turning on the truck and when I did it started just fine . I then lefted running for like 30 min and did the same thing again . I have a optima yellow too battery so I don't know if that made a difference .
  7. Jul 13, 2013 at 11:46 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Straight pipe and tune those diesels it will make them run better
  8. Jul 13, 2013 at 11:50 PM
    AK 08TACO
    Kyle
    Wasilla, AK
    They're all owned by bp and want to keep the warranty through Ford, so unfortunately they all stay bone suck
  9. Jul 14, 2013 at 4:54 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Ever seen a cop car sitting still with the engine turned off? No they are not specially designed engines we generally got rid of them at about 180K and we never lost an engine. However using a 200+ HP engine to make 400 watts is nuts. I have one of the cheap generators and have for a good 8 years and use it around the farm it is poorly regulated and noisy but it runs fine if you are going camping spend the $1000 it will keep people from throwing stones at you.
