fuel economy 09 4.0 taco
Discussion in 'New Members' started by thegreentaco, Mar 14, 2010.
  1. Mar 14, 2010 at 5:12 PM
    thegreentaco
    thegreentaco [OP] Member
    bc canada
    09 tacoma sr5
    Hi...I recently bought an 09 tacoma with a 4.0 the truck is stock and i was wondering if any one had some suggestions what I can do to improve the fuel economy any comments are welcome ...thx
  2. Mar 14, 2010 at 5:52 PM
    got_titan
    got_titan Well-Known Member
    sevierville, tn
    2010 trd sport dc 4x4
    i would say an air filter and a muffler swap. a bed cover if you can find one under 200. make sure the air pressure is always correct.
  3. Mar 14, 2010 at 5:55 PM
    Brunes
    Brunes abides.
    Rotorhead
    "Light Right Foot Mod" Take it easy on the skinny pedal and you'll be doing yourself all sorts of favors. A Scangauge can help you monitor your progress.
    You'll get minimal gains from filters and mufflers and whatnot- .5mpg and under most likely. Correct tire pressure will help....as will eliminating unnecessary weight from the truck.
    Welcome to TW!!
  4. Mar 14, 2010 at 6:44 PM
    Taco John
    Taco John Well-Known Member
    Illinois
    4X4
    X2. Driving habits dictate a lot of it.
  5. Mar 14, 2010 at 7:03 PM
    Simon's Mom
    Judy or Jude :)
    SBurl Vermont
    13 TRD OR DC MGM
    Stock for now
    Welcome :wave:
    Yes what the guys said. I bought a scangauge it helped me realize keeping the rpms down. My best numbers come when its under 2 & not towing. :)
  6. Mar 14, 2010 at 7:06 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Buy a Prius. Why does this question always come up? If I worried about my fuel mileage all of the time I'd go insane. Actually I am going to buy a Hummer H2 and go on the Hummer forums and ask what I can do to improve gas mileage.
    Sorry in advance but this question just rubs me the wrong way. It's becoming the successor to "What's the best oil" threads.
  7. Mar 14, 2010 at 7:11 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    To each his own... we'll see a lot more of it when gas clips over $3/gal again in the US
    Here's some of what I do:
    Since our trucks shut down the injectors when coasting (at least the the autos do) that helps tremendously on MPGs. I do the following whenever possible:
    - Accelerate moderately but steadily up to speed. No jack rabbit starts but I don't take 2 minutes to get going either. My truck gets 12-15mpg with even light acceleration so I don't want to be too slow about getting to cruising speed
    - I use cruise control whenever going above 40 mph and on relatively flat ground. Cruise control can be more efficient when on flat ground but any time I hit even moderate hills then I can beat it and get better MPGs driving on my own.
    - When driving on my own up/down hills I'll accelerate slightly going downhill (up to 5mph over the speed limit) and then bleed off some of that speed going up the next hill so as to require less acceleration uphill.
    - When I do need to stop I try to lose at least 25% of my speed by coasting. There's no point accelerating up to a stop sign/light anyway, you just transform the wasted gas into heat when you step on the brakes. This is easier than it might sound since as long as the engine is warmed up and you're over about 35mph the injectors will turn off and you'll lose speed fairly quickly if you're on flat ground
    - Any time I see a 1/8 mile or more of downhill slope I'll coast a bit to let the injectors kick off and essentially get unlimited MPGs
    - I rarely get above 2500 RPMs although this isn't a direct reflection of good mileage. It's easy to only be running at 1700 RPMs and only getting 15mpg if you're accelerating up an slight hill. Still, all other things being equal, lower revs equals lower fuel consumption.
    I bought a ScangaugeII about 3 months ago at this point but it hasn't helped me get better mileage... I think I was pushing it for all it was worth before then but having one has helped me confirm the items above. Plus it's a nifty toy and something to pay attention to on my drive to work/home every day.
  8. Mar 15, 2010 at 8:50 PM
    thegreentaco
    bc canada
    09 tacoma sr5
    thx do you suggest a K&n air filter? are they worth it? thx for repling
  9. Mar 15, 2010 at 8:53 PM
    tuckr2
    tuckr2 Well-Known Member
    Western Washington State
    2010 Silver dbl cab LB 4x4 It's Purdy too!
    LT265/70/17 BFG A/T's, Disabled Seat Belt Buzzer, Black and Gray Covercraft Seat Covers front and rear, Matching SnugTop Supersport Canopy, undercoat, bed mat, window vent shades. Black Weathertech Liners. Trans TSB, Rear Spring TSB Installed.
    the filter won't do much for you that light foot wouldn't do as well. You might save money over the long run on filters as the K&N is reusable.
  10. Mar 15, 2010 at 9:09 PM
    SlurpeeBlueMetallic
    Worth it only if you plan to keep your truck for many miles/years since you won't have to replace the air filter. I don't think the impact on MPG will be noticeable...
