FUEL ECONOMY-2.7 L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wannagoagain, Jul 19, 2015.
  1. Jul 21, 2015 at 8:58 PM
    #81
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Pretty damn good with E rated!
  2. Jul 21, 2015 at 8:59 PM
    #82
    JBecker
    JBecker Well-Known Member
    Virginia
    2015 AC SR 4X4 2.7 Manual
    Yeah I don't think it's too bad. It's slow, but it works.
  3. Jul 21, 2015 at 9:05 PM
    #83
    akkyle
    akkyle Well-Known Member
    Kyle
    Alaska
    2014 regular cab 4x4
    I think I hover around 16 to 17 mpg with AC on, mixed driving, but I drive it like I stole it plus E rated 265/70/R17 mud terrains and 300lbs worth of armor as well. Now in the winter you don't even wanna know how bad the mileage is.........
  4. Jul 22, 2015 at 1:22 AM
    #84
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Pulled from another thread:
    EDIT: I should add that I run the Blizzaks at 32 PSI; and the LT Summer tires at 50 PSI (makes for a harsh ride but keeps the heavier tire from sucking down my MPG. I run the heavy tire in Summer to avoid cutting down a tire on the gravel roads I find myself on in Summer. I've had too many friends destroy P-rated tires, so I went with the extra precaution; my tire guy advised me to run them at 50 for daily use, and air them down for soft stuff (beaches or mud).
  5. Jul 22, 2015 at 6:27 AM
    #85
    JBecker
    Virginia
    So I checked my tires this morning and all 4 were at 27 psi. They're now at 40 so that should help. lol
  6. Jul 26, 2015 at 6:40 PM
    #86
    Taco Mike
    Taco Mike Member
    Morris Oklahoma (near Tulsa)
    12 AC 2.7 4x4 Canadian Specs
    Former - 06 Impulse Red 4X4 6-Speed
    Just took my 2012 2.7 5 speed manual AC 4x4 from Tulsa to Branson and back. 21.2 MPG with about 90% highway 10% city. Lots of up and down steep ozark mountains.
    The same trip in my 2006 4.0 6 speed manual DC 4x4 was 15.9 mpg.
    I am loving my 2.7!!!!
    T4RFTMFW likes this.
  7. Jul 30, 2015 at 3:11 PM
    #87
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    Just got back from a nearly 2000 mile road trip, driving on interstates, back country mountain forest roads, local roads and highways and some heavy city traffic. The truck was loaded with my wife and me and enough camping gear in the rear and behind the seats that I could barely see with the rear view mirror. The truck is an AC, 4wd, manual, with LT 265/75 R16 Load Range E mud and snow tires (at about 37 psi), and with 5W30 oil in the engine. Speeds ranged from 10 to 65 mph, depending on the road. Did not use the air conditioning. The gas mileage for the trip was 25.3 mpg.
    tacomakid96 and 23Skidoo like this.
  8. Jul 30, 2015 at 3:34 PM
    #88
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    4wd 5 speed manual.
    1.75 front level.
    265/75/16 duratracs 10 ply at 40 psi
    22-24 mpg.
    With the BFG KOS same size and ply.
    26-27 mpg.
    My dash command obd reader showed 24.8 avg for last 6k miles.
    Winter driving and a remote starter.
  9. Aug 17, 2015 at 10:51 AM
    #89
    prodelivery
    prodelivery Well-Known Member
    Tay
    '98 reg cab 4wd 5 speed GREEN
    Somebody said earlier that it all comes down to what you want more power or mpg. I disagree, I love my 2.7 because it encompasses more of Toyota's legacy when it comes to small pickups. I like the characteristic of it, it's obviously slow but it feels like a little tank. I also like being the underdog and towing is fun in a way because you're barely making it. Plus everyone seems to think you can't tow for anything with it yet in other countries the exact same drivetrain/engine setup is rated at 6500 lb just like the v6 (the theory is that they're trying to upsell the v6 to dumb Americans that don't understand what is actually important in towing).
    Also, the mpg difference has the potential to be a much bigger difference. Driving economically there is not a huge difference but if you hold both to the floor their will be a bigger drop in v6 than the little 4 cyl. The only reason why a bigger v6 motor only has a small drop in mpg's in the first place is because it has the ability to keep the rpms very low through it's much higher torque. When you rev them up though they really start to to get thirsty. Meanwhile 4 cylinders are used to revving higher even with normal driving in order to get any power at all from being a smaller displacement.
    I love 4 cylinders :)
  10. Aug 17, 2015 at 11:02 AM
    #90
    T4RFTMFW
    18.3 MPG last fill up. I've since increased my lift height and filled up the tank the morning of the install, so will see in a few days/week if that has had any effect.
  11. Aug 17, 2015 at 12:46 PM
    #91
    bacollier90
    bacollier90 Well-Known Member
    Bryce
    Springfield, MO
    19 DCSB 4x4 Cement
    08 AC 4x4 I get right around 18. No lift but I do have 265/75/16 Cooper AT3's. I have short 10 minute commute to work so it doesn't have much of a chance to get warmed up.... I also have a fairly heavy foot.
    My truck sat for a long time before I bought it (3-ish years) so I think there are probably things I could do to help improve it. Any advice from anyone?
  12. Aug 17, 2015 at 12:47 PM
    #92
    bacollier90
    Bryce
    Springfield, MO
    19 DCSB 4x4 Cement
    Is your truck on steroids???
  13. Aug 17, 2015 at 3:59 PM
    #93
    RBTaco
    RBTaco Well-Known Member
    2013 RC 4X4
    Trac rac, tow hitch, fog lights, tonneau cover, Texas Edition rims, custom console, weathertech floor mats.
    2013 RC 4X4 manual
    With 245s 23.5 mpg city
    With 265s 21.5-22 mpg city
  14. Aug 18, 2015 at 4:35 PM
    #94
    Jeffch
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Not sure but I am pleased with my mpg. I was getting 30 with my impala. And my Mpg was an avg over like 2k miles at least for the taco. Not in a rush anymore so I drive for mileage. Being a 4 manual I avoid interstate driving.
    I'm using dash command with an iPhone plugged into the obd2 port.
    But since I have raised the front
    to re level it I have lost 1-2 mpg I may drive it a little harder since it's getting older and I also did a sub and can't hear my revs anymore.
  15. Jan 13, 2021 at 10:20 PM
    #95
    dadams5302
    dadams5302 Member
    Dillon
    2009 Tacoma 4x4 Reg Cab
    How are you guys getting such good MPG out of the 2.7 liter? I have a 2009 regular cab and I am averaging 14 mpg. I am running 33's but everything else is stock. No lift.
  16. Jan 13, 2021 at 11:51 PM
    #96
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Base model 2.7 5M, stock tires, rims, snugtop rebel plus another 200lbs tools so including me about 600lbs in the truck. Average highway speed is 70. If I have the Thule bars on the roof it’s 21-22, clean roof 23-24. Typical tank is 1/3 city 2/3 hwy miles so it goes up from there. 25 is no problem, best is 27(trip miles/gas to fill as I don’t have a display for it). Given that mileage is a sum of best conditions and less advantageous ones long haul trips could exceed that best. Advertised mileage was 21/24. Range to low fuel light(17.5-18tsp)>400, best was 450 but I think 500 is possible. I use CC but will often drop to 4th on grades @65. It won’t hold that on steepest grades or at altitude but I didn’t buy it for the power.
  17. Jan 14, 2021 at 6:43 AM
    #97
    ECE208
    ECE208 Active Member
    Evan
    Idaho
    2013 White Access Cab Tacoma SR5
    2013 access cab 4x4 MT 245/75/16 E rated tires (they came on the truck when I bought it). 20-22 mpg mixed driving in the summer 19-20 currently with winter blend.
  18. Jan 14, 2021 at 8:23 AM
    #98
    pyrobobd
    pyrobobd Active Member
    Bob
    Southeast Colorado
    '07 basic truck
    Variable speed wiper switch
    2007 base, AC, 4wd, 5spd.
    Over 9 years, 133xxx miles--23.49 mpg. Home base is at 6 800' ASL, lots of rough country and mountain driving.
  19. Jan 14, 2021 at 8:39 AM
    #99
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    I assume the 33s are your problem. Those are much larger than the stock tires. So, not only do you have more rotating mass to spin/un-spin, but more rolling resistance as well. This is hurting your brakes as well as your MPG. It's not often said in these MPG threads, but it also helps to keep the MAF sensor clean.
    Also, nice necrothread revival.
  20. Feb 5, 2021 at 8:33 AM
    #100
    dadams5302
    dadams5302 Member
    Dillon
    After doing some research, I believe it is the cold air that is killing my MPG, almost cutting it in half. Over the summer/ warm air I was averaging 350-400 a tank! Now I am lucky if I get to 280ish. It sucks. I will look into that MAF sensor as well. Thanks for the heads up!
