FUEL ECONOMY-2.7 L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wannagoagain, Jul 19, 2015.
  1. Mar 12, 2022 at 3:41 PM
    #101
    drewskie
    drewskie Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    Going to bump this up because I'm getting abysmal MPG. 08 PreRunner access cab manual with the 2.7
    I get around 17 miles per gallon if I'm lucky. I do have a small lift and I think my tires are 2 inches taller than stock, but I feel like something else is at play
  2. Mar 12, 2022 at 3:49 PM
    #102
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Calibrated the speedometer?
  3. Mar 12, 2022 at 5:18 PM
    #103
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    2” should be noticeable but not that bad. I’ve never once been below 21 and typically 24. Tire pressure, clean the maf sensor, check the wheel bearings and driveline. Traffic and speed, you get 0 mpg sitting with the engine running and it drops quickly above 65.
  4. Mar 12, 2022 at 6:37 PM
    #104
    Michaelo
    Michaelo Well-Known Member
    Michael
    PNW
    2014 Regular Cab 4x4 5 Speed
    I'm getting ~19mpg lifted 2-3 inches on 33's.
    drewskie likes this.
  5. Mar 12, 2022 at 7:50 PM
    #105
    Bobsgym
    Bobsgym Active Member
    2012 Tacoma
    Stock except for BFGOODRICH all terrain tires.
    2012 reg cab base model 4x4 automatic with bfgoodrich all terrains. I average 17 mpg but that is with letting the truck warm up in the mornings. Hopefully it will be 18-19 mpg when I don't warm it up.
  6. Mar 12, 2022 at 7:54 PM
    #106
    drewskie
    Drew
    Burbank, CA.
    Nope
  7. Mar 13, 2022 at 11:06 AM
    #107
    23Skidoo
    23Skidoo A thirsty fish
    Paul
    https://youtu.be/xvFZjo5PgG0
    meme
    I get the same, stock. 19 if it’s all highway, sometimes.
    2010 PreRunner access cab, manual, 2.7.
    drewskie[QUOTED] likes this.
  8. Mar 13, 2022 at 11:54 AM
    #108
    bagleboy
    Scott
    Norcal, Santa Rosa
    What tire pressure are you guys running? With topper and work tools I’m rarely under 400 lbs in the bed and that doesn’t include me or gas weight so I keep tire pressure on the high side as well as extra air in the lift bags for leveling. I see a noticeable drop in economy with lower pressure as we’ll as excessive edge tread wear. Base model AC 2.7 manual stock tires. Fwiw my best mileage to date was driving 70-75 down to Santa Barbara so it isn’t just speed although I prefer doing my commute in off hours so I can drive at a more relaxed pace that driving is coupled with city miles so I haven’t been able to compare over several hundred miles. Does even a minimal lift really increase drag that much?
  9. Mar 13, 2022 at 12:06 PM
    #109
    23Skidoo
    Paul
    meme
    I also have a fiberglass topper and a full load of carpentry tools. Tire pressure around 38. It doesn’t seem to matter how I drive, still 17. I once got 19 mpg driving 4 1/2 hours at around 70-75 mph, nothing in the bed. I gave up trying to figure it out.
  10. Mar 13, 2022 at 12:09 PM
    #110
    23Skidoo
    Paul
    meme
    My 2.4L 1999 5 lug would average 25 mpg, aluminum topper, full load of tools. Although I’d have to turn the AC off when going up hills. ;)
    bagleboy likes this.
  11. Mar 13, 2022 at 12:09 PM
    #111
    bagleboy
    Scott
    Norcal, Santa Rosa
    I guess ymmv is really a thing.
    23Skidoo[QUOTED] likes this.
  12. Mar 13, 2022 at 12:15 PM
    #112
    bagleboy
    Scott
    Norcal, Santa Rosa
    I had to actually turn the heater ON in my Cortina in the summer to keep it from overheating and put cardboard in front of the radiator when driving in snow to get it up to temp so I could even use the heater/defroster.
  13. Mar 14, 2022 at 7:36 AM
    #113
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Then simply figure out the percentage difference in tire size, and multiply that to your next fill-up MPG.
  14. Mar 14, 2022 at 8:15 AM
    #114
    tacobp
    tacobp Well-Known Member
    Bob
    North Carolina
    09 Tacoma, 2.7 automatic
    Installed a Pop n Lock,,That's it !..Bone stock
    I am getting an average of 24 ... Stock 2.7 with auto..
  15. Mar 14, 2022 at 8:43 AM
    #115
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    Hovers right around 20mpg, give or take a little. On 265/70/17s vs the stock 245/75/16s. The height/roll-out difference is minimal, so the speedo is real close.
  16. Jun 10, 2024 at 1:06 PM
    #116
    Taco Mike
    Taco Mike Member
    Morris Oklahoma (near Tulsa)
    12 AC 2.7 4x4 Canadian Specs
    Former - 06 Impulse Red 4X4 6-Speed
    Well I’m back in a 2.7 after all these years. 2019 AC Sr 4x4. I’m getting 23.4 average per tank mixed driving. I missed my 2.7 4x4 so much I got another.
    JGO likes this.
  17. Jun 10, 2024 at 9:38 PM
    #117
    Ymwu5
    Ymwu5 Member
    Southern Alberta
    2010 Tacoma SR5 Access Cab 2.7 L, 5 speed, 2WD.
    LCE Header Amsoil BP Filtration
    Highway geared 2wd, 2.7 L, 5 speed. 100 km/h at 2000 rpm. 100 km/h in 4th is only 2500 rpm’s.
    City….9.0 L/100 kms to 10 L/100 kms.
    Hwy….7.5 L/100 kms to 9.0 L/100 kms.
    Several times I have made just over 1000 km’s on one tank. Buzzards were starting to circle.
    I remember a calm summer day cruising at 110 km/h and getting phenomenal mileage in the low 7 L/100 km range according to my Scanguage. I then turned from hwy #2, from Calgary, onto Crowsnest Pass hwy #3. 15 minutes later I was slamming into a head on mutha’ wind. 40 minutes later I was down to 10 L/100 kms Scanguage average. Foot stayed pinned to the floor as I struggled to keep 100 km/h in 4th. Anyone who has driven the #3 Crowsnest knows what I am talking about. And windshield brutality!!!!
    Usually 200-230 km before my gas gauge would drift off of the full mark on the hwy. Sometimes made Pincher before off the full mark. E10 dropped it under 200 km slightly. Rarely get 200 km’s now with the ethanol. Did not think it would be that drastic?
    I drove this route for many years weekly.
