Fuel Economy Concerns
Discussion in '2nd Gen. Tacomas (2005-2015)' started by twkamp91, Feb 17, 2017.
  1. Feb 17, 2017 at 6:04 PM
    twkamp91
    twkamp91 [OP] Member
    Tyler
    Bellingham, WA
    2011 Tacoma TRD Off Road
    Hello everyone. I have some concerns on my fuel economy and figured I'd throw my situation out there. My main concern is why is it so low.
    I am currently getting 13 to 15 mpg on average per fill up. More towards the lower end. I would say my city to hwy ratio is 2 to 1.
    I have done two Lucas oil flushes in the past 6 months. Always run Castrol oil and only use Shell or Chevron gasoline. Also recently had a front wheel bearing replaced along with an alignment.
    I also do accent 600ft 1-3 times a day to my house. I have a feeling this is the main contributor, but wanted to get some confirmation
  2. Feb 17, 2017 at 6:47 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    your milage is normal with winter blend fuels
    Lord Helmet and twkamp91[OP] like this.
  3. Feb 17, 2017 at 8:15 PM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    City driving will reduce your MPG as will long ascents. With your mix of city vs highway driving what you're getting doesn't seem alarming.
    If you're really concerned take advantage of your next long freeway trip (starting with full tank) and when you have to refill calculate your MPG.
    Also check that your engine air filter is clean.
    twkamp91[OP] likes this.
  4. Feb 18, 2017 at 1:42 AM
    AKHawkeye
    AKHawkeye Well-Known Member
    Anchorage, AK
    15 AC Sport 4x4 6 Spd
    Locked as stock
    I don't even look at my MPG's during winter. The combination of winter gas and pretty much always being in 4WD makes me just happy if I can get 200-240 miles before the light comes on.
  5. Feb 18, 2017 at 4:12 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Stop pissing away money on Lucas Oil crap. Its 2017 gas is clean (regardless of who you buy it from).
    Looks like in your picture you have wider/bigger tires. :smack: No kidding that will drop mpgs. And if you are running larger diameter tires make sure you are accounting for that when doing your mpg calculations. If not it will appear you are getting lower than you are.
    Also city driving sucks on this truck. So if you do short city trips your mileage will be low.
    AND keep your foot out of it. Keep rpms under 1500-2000. No taking off at lights.
    jogirob, cliffyk, Lord Helmet and 2 others like this.
  6. Feb 18, 2017 at 4:23 AM
    Sidponcho
    Sidponcho Well-Known Member
    Dan
    At 40k miles my truck consistently get 20-21 mpg and I check it at least every other tank. 15 DCSB 4WD.
  7. Feb 18, 2017 at 6:22 AM
    Sugar Silva
    Sugar Silva Well-Known Member
    Dave
    San Diego, CA
    16 Toyota Land Cruiser
    Kings Sliders TRD Rock Warrior Wheels Tint
    Ouch!
  8. Feb 18, 2017 at 6:33 AM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    buy the 2.7l 4 cylinder and keep it stock and you wont be blowing as much money out of the exhaust pipe
  9. Feb 18, 2017 at 7:53 AM
    twkamp91
    Tyler
    Bellingham, WA
    Thank you everyone for your comments and tips. It has helped clear up my concerns!
  10. Feb 18, 2017 at 9:09 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Be happy, I've averaged 10mpg over the last nine fill ups.
  11. Feb 18, 2017 at 10:33 AM
    14TACO4X4
    14TACO4X4 Mmmmm... Beer
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    I have averaged 17-18 since I got the truck. Towing is what kills it for me. Drops to 13.
  12. Feb 18, 2017 at 10:39 AM
    SoCOTaco
    SoCOTaco Well-Known Moron
    Mitchell
    Lakewood, CO
    2012 Tacoma TRD Off Road 4X4
    GFC, Fox 2.0's w/ Dakars, SCS BR6's, Fridge w/ Beer
    Even in Colorado with mixed driving I get around 17 in the winter. I'm soft on the gas and only run 265/75/16 Duratracs. I probably sit at 75% highway and 25% city with an elevation change of about 1500-1700ft on my daily commute.
