Fuel Economy dropped from high 200s to low 200s per tank
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 09tacomatrd, Apr 6, 2016.
  1. Apr 6, 2016 at 8:52 AM
    09tacomatrd
    09tacomatrd [OP] Well-Known Member
    Jeremy
    New Jersey
    09 Tacoma TRD Access Cab
    URD Intake, Aero Turbine 2525 Exhaust, alpine component speakers and 8" ken wood excelon woofer. Powered by 750 watt ken wood amp.
    Recently my fuel economy has really crapped the bed. Was wondering if anyone could help me trouble shoot. Things I've done. Checked tire pressure, cleaned intake filter.
    Thank you
  2. Apr 6, 2016 at 8:57 AM
    diverdale
    diverdale #sosconceptscrew
    Dale
    Raleigh, NC
    2015 TRD OR DCSB
    Fox 2.5 Coilovers, Fox 2.0 Rear Resi, Icon 3 Leaf AAL
    Leaky fuel injector(s) maybe?
  3. Apr 6, 2016 at 9:02 AM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    Is it running odd? Sputtering/popping/odd noises or feeling when accelerating? Did you change ANYTHING about the truck? Tires, put on a shell?
  4. Apr 6, 2016 at 9:21 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Depending on the odometer reading, how you use the truck and its service history, you may be due for a mass airflow (MAF) cleaning and throttle body cleaning, new spark plugs, etc... normal tune-up items. None of these by itself will affect fuel economy so much as you have experienced, not all of a sudden. But all of them together... I suppose they could.
    Also I've seen bad oxygen sensor(s) do horrible things to fuel economy, that would indicate a check engine light (CEL).
    As posted above, I would pay attention to how everything is running. Is anything different lately, other than bad fuel economy? Good power and throttle response? Starting OK? Shifting OK? Normal operating temperatures? Funny smells?
    digitaLbraVo likes this.
  5. Apr 6, 2016 at 9:34 AM
    09tacomatrd
    Jeremy
    New Jersey
    Also, I ran a bottle of fuel injector cleaner through her. She has 85k miles. Got new spark plugs, and wires at 35k. No check engine lights. She does start a a bit loud and has a bit of a tendency to hang out in higher gears a toch longer than she should.
  6. Apr 6, 2016 at 9:37 AM
    digitaLbraVo
    When did you run the cleaner? If it's been awhile and you don't run it regularly it may have knocked something loose and gunked it up worse? I run injector cleaner about every oil change and the mileage typically goes down a bit but not 100mi on a tank.
  7. Apr 6, 2016 at 9:40 AM
    09tacomatrd
    Jeremy
    New Jersey
    I ran the cleaner 2 wks ago now after the problem had been noticed. Fuel economy has improved but only slightly.
  8. Apr 6, 2016 at 9:42 AM
    digitaLbraVo
    No check engine light? Are you first owner?
  9. Apr 6, 2016 at 9:46 AM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Unplug battery for 10 mins to reset ecm
    :notsure:
  10. Apr 6, 2016 at 9:48 AM
    digitaLbraVo
    Won't hurt anything but radio station settings, hehe.
  11. Apr 6, 2016 at 9:51 AM
    pa blaster
    pa blaster Well-Known Member
    Scott
    central pa
    2024 GMC Canyon AT4X AEV
    Welcome to my world :p I've averaged 14 mpg since new
  12. Apr 6, 2016 at 9:53 AM
    odinsbro15
    odinsbro15 Well-Known Member
    Eric
    LOS ANGELES CA
    2016 Gray Tacoma trd offroad DCSB
    ROUGH COUNTRY FRONT 2 INCH LEVEL KIT, TINT, DIPPED RIMS, DITCH LIGHTS, CUSTOMER REAR FACING LIGHT, INTERIOR MATS
    how recently did this happen? the gas companies just went from the winter blend to the summer blend and i noticed a slight difference in MPG
  13. Apr 6, 2016 at 9:53 AM
    digitaLbraVo
    Less skinny pedal.
  14. Apr 6, 2016 at 9:56 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    You're overdue for new plugs
  15. Apr 6, 2016 at 9:58 AM
    pa blaster
    Scott
    central pa
    That's probably partly the reason but mostly I believe it's my location being in central PA no matter where you go it's up hill half the time
    digitaLbraVo[QUOTED] likes this.
  16. Apr 6, 2016 at 10:02 AM
    Clearwater Bill
    Billy
    Largo Florida
    Don't you go downhill the other half time?
    diverdale likes this.
  17. Apr 6, 2016 at 10:04 AM
    09tacomatrd
    Jeremy
    New Jersey
    Its been on going for the last two months now. I am a second owner. If I replace plugs should I also do wires? I'll reset the battery tonight.
  18. Apr 6, 2016 at 10:05 AM
    pa blaster
    Scott
    central pa
  19. Apr 6, 2016 at 10:07 AM
    pa blaster
    Scott
    central pa
    Figured someone would try that argument :rofl:
  20. Apr 6, 2016 at 10:09 AM
    pudge151
    Sean
    Connecticut
    just plugs and reset ECU, maybe get some MAF spray
