Fuel Economy is getting worse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jospur, Sep 26, 2011.
  1. Sep 26, 2011 at 12:13 PM
    jospur
    jospur [OP] Member
    Melbourne, FL
    07 PreRunner TRD Sport
    I have a 2007 DC TRD Sport Tacoma with 34k. I bought it used as a Toyota Certified Pre Owned vehicle, but out of bumper to bumper warranty due to year.
    I usually take it from mid Florida to south Florida down I-95 once every couple of months. I usually do between 74-78mph and usually get 350 miles to a tank +/-.
    A few weeks ago I took it down and doing the same thing I always do I got about 250 miles to a tank. In the city lately I've noticed the fuel economy has gone from about 300 miles to a tank in the city to about 250 in the city and I have purposely have been taking it easy (keeping RPMs below 2k, etc). I recently put more air pressure in the tires and I don't know may have caused it though I don't think so.
    Yesterday I noticed that itwas kinda shaking while idling....like it was running rough. Dunno what the problem could be. Just had it's 30k service and I maintain it well. I am not mechanically inclined so I'd have to take it to a Toyo dealer if need. I do work at a dealership (not Toyota), so if I could troubleshoot the issue maybe one of my mechanics could work on it here.
    Help? Thoughts?
    Thanks.
  2. Sep 26, 2011 at 12:20 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    were the plugs replaced when they did the 30k service?
  3. Sep 26, 2011 at 12:22 PM
    jospur
    jospur [OP] Member
    Melbourne, FL
    No they were not because I was told by the Toyota dealer that it was not part of the 30k service. Though I thought about that .... is it fairly easy to replace those?
  4. Sep 26, 2011 at 12:25 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  5. Sep 26, 2011 at 12:30 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If you paid for the full 30k mile service it should have been included. If you paid for it, you might want to bring it back. It's easy enough to do on your own though.
  6. Sep 26, 2011 at 12:30 PM
    saugus
    saugus Well-Known Member
    Air filter? Go to autozone and spend $10 on a digital tire gauge. 29 and 32 are what my truck uses. Don't over fill. Also rotate the tires at least every 7k. Also could be a broken plug. 34k is not that much so I doubt the plugs are gone.
  7. Sep 26, 2011 at 12:43 PM
    jospur
    jospur [OP] Member
    Melbourne, FL
    I got the service done at my dealership for less than half the cost of what the Toyota dealer wanted. Of course I get employye price and parts at wholesale so that helps. I will look into changing the spark plugs.
    I have a AEM dry flow air filter. I rotate tires every single oil change. I will make sure they are between 29 and 32 ....
  8. Sep 26, 2011 at 1:25 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Darn right spark plugs are included at the 30,000 mile service (it's in your owners literature)... ~$500 is what the dealer is charging me, less a discount coupon for my 30,000 mile service today.
  9. Sep 26, 2011 at 2:11 PM
    lmcc007
    lmcc007 Well-Known Member
    Charles
    Northern CA.
    2006 SR5 PreRunner Doublecab Longbed
    Tube steps & tonneau cover.
    It could be the plugs or something that shook loose after you got the 30K mile service. With that few miles you shouldn't be experiencing any rough idling so something IS wrong with your truck.
