Fuel Economy Slipping...!?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JBU, Oct 28, 2020.
  1. Oct 28, 2020 at 5:12 AM
    JBU
    JBU [OP] Active Member
    2013 Tacoma
    I have a stock 2013 Tacoma 4WD 4.0 L, 6 cylinder, Automatic 5-spd, Regular Gas truck. I'm at 175,000 km (108,700 miles) on the odometer right now. Problem is that I've started to notice the truck performing at a much lower fuel economy lately. Been travelling to the cottage over the last 5 years and its a 200 km trip and I usually burn just slightly over 1/4 tank of gas going one way. Nowadays for the same trip I'm burning close to 1/2 a tank of gas. This is close to double the amount of gas than I used to burn. Anybody have any ideas as to what is going on? I'm not doing anything out of the ordinary, not towing anything, or hauling anything super heavy. I've also been doing all the recommended maintenance at the dealer. The only odd thing that came up recently is that my Air Conditioning is not working, the light is flashing, so I turn it off and just use a little bit of heat which works fine. It's too cold for AC now anyway. Would appreciate if anybody has any insight into this. Thanks.
  2. Oct 28, 2020 at 5:21 AM
    Kyle01
    Kyle01 Well-Known Member
    Kyle
    Chicago
    2024 TRD Offroad double cab 6MT
    My guess is winter fuel. I typically see about 110 miles at 1/4 tank (slightly less than you) and for the past several tanks it’s gone WAY down... like 90 miles at 1/4 tank... summer months I average 320 - 350 (on a really good tank) and right now I can barely manage 290.
    edit: not sure where you’re at geographically. Winter fuel might not be a thing where you are...
    RedWings44 and JBU[OP] like this.
  3. Oct 28, 2020 at 5:22 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    All others components being good, it'll be one to two things. 1st: fuel filter. 2nd: (less likely but has been found to be true) injectors. Well documented by the Aussies.
    As well as in conjunction with what he said about the fuel change.^^^
    JBU[OP] likes this.
  4. Oct 28, 2020 at 6:41 AM
    JBU
    2013 Tacoma
    I'm in Ontario, in the Greater Toronto Area... Never heard of "winter fuel". Thanks - will ask about it.
  5. Oct 28, 2020 at 6:52 AM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    It just let's the engine start easier in cold weather. And has less energy in it
    JBU[OP] likes this.
  6. Oct 28, 2020 at 7:00 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    I think I would begin with some basic maintenance.
    Clean throttle body and MAF
    Change air filter
    Change spark plugs
    Change lubes in Diffs, Xfer case, tranny, power steering.....
    Check the serp belt drive for dragging pulleys
    Check tire air pressure.
    Clear the truck of extra weight.
    Check the Front End Alignment.
    Verify tranny is shifting into Over Drive.
    Just work to reduce any source of drag and friction.
    I have essentially the same truck with 109,000+ miles. I get 19.* mpg in mixed driving, temperatures are ranging from 20F to 40F. When I'm running 60 mph in OD, the tach indicates about 1600 rpm.
    These may or may not help.
    JBU[OP] likes this.
  7. Oct 28, 2020 at 7:08 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    How many time is "lately?" Its still possible that for the last two trips you just got an unlucky headwind.
  8. Oct 28, 2020 at 7:14 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    A friend of mine with a very similar truck to the OP's had a very similar problem and brought the truck over for me to check out. Believe it or not, it was his front wheel bearings. And believe me, for wheel bearings to negatively affect fuel mileage, they have to be pretty bad. And his were. OEM Tacoma front wheel bearings (on 4WD trucks) are about a 100,000 mile item. I just replaced both of mine at 106,000 miles because one was just starting to go.
    JBU[OP] likes this.
  9. Oct 28, 2020 at 7:20 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Fuel gauges are notoriously inaccurate. You need REAL numbers to know anything. What kind of mpg/kpl were you getting previously and what are you getting now?
  10. Oct 28, 2020 at 7:22 AM
    Knute
    Yes, wheel bearings can be a huge source of drag.
    If this turns out to be the case, then you would be wise to change all the front wheel bearings on both wheels.
  11. Oct 28, 2020 at 7:31 AM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Are there any other symptoms to bad front wheel bearings besides bad fuel economy? Can I check it by lifting the front end and grabbing the wheel to see if there's play?
  12. Oct 28, 2020 at 7:32 AM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    PCV replacement.
    MAF cleaning.
    TB cleaning.
    Spark plugs.
    The “fuel” part of the air/fuel/spark triumvirate isn’t usually a problem in Tacoma’s... so try basic items for the other two.
  13. Oct 28, 2020 at 7:36 AM
    Knute
    That is one way, but may not be definitive.
    Lift the truck, remove the wheel, slowly rotate the the hub in both clockwise and counter clockwise. You are feeling for "bumps", drag, resistance in spots, listen for grinding or unusual sounds.
    Worse case, pull the hub to access the bearings directly.
  14. Oct 28, 2020 at 7:39 AM
    Accipiter13
    California
    '11 DCLB 4x4 Sport
    Play would indicate ball joint wear more than anything.
  15. Oct 28, 2020 at 7:40 AM
    Too Stroked
    Tom
    Yes. Generally speaking, they will make noise before you can detect play. The noise will generally be a humming sound that gets worse in corners. (That was my truck.) If they continue to get worse, you will be able to feel play (up and down and / or side to side) in a wheel when you jack the truck up. (That was my friend's truck.)
    If it is a wheel bearing, as has already been said, you're better off replacing both sides plus the two seals on each side. After all, if one went, the other side won't be far behind. And be very careful of what kind of bearing you replace them with. There are many, many different brands out there with some significant differences is quality. Beware the cheap crap like Dorman.
  16. Oct 28, 2020 at 7:41 AM
    Too Stroked
    Tom
    That's what if you feel any play, you have to look closer to see where the play is coming from.
  17. Oct 28, 2020 at 7:42 AM
    Accipiter13
    California
    '11 DCLB 4x4 Sport
    Unfortunately both the wheel bearings and ball joints suck on our Tacoma’s. Yay Toyota.
  18. Oct 28, 2020 at 7:43 AM
    Too Stroked
    Tom
    The wheel bearing on a 4WD Tacoma is a sealed unit with the hub pressed onto it, so you can't really pull just the hub.
  19. Oct 28, 2020 at 7:46 AM
    Kyle01
    Kyle
    Chicago
    Buy replacement hub assemblies from TW member 05Taco4X4
    Unless you buy OEM from the dealer he’s the only guarantee that you’re gonna get OEM quality (Koyo) bearings that are pressed in correctly (there’s a long thread about it)
    As a plus he ships very quickly, the hubs look great and are SUPER reasonably priced.
    Too Stroked likes this.
  20. Oct 28, 2020 at 7:53 AM
    Knute
    :( I hate that construction.
    My GMC Sierra 2500HD had a similar build. Right front ABS sensor failed......$600 to replace the hub. The ABS encoder was buried in a sealed hub.
    I guess I'm just old school. When you could pull the hubs, remove the tapered roller bearings, hand pack grease into the new bearings, press the races into the hub, reassemble with the castle nut and cotter pin. Total cost was bearings, seal and a bit of grease.....typically less than$25. Now, the repair is several hundred $$. o_Oo_Oo_Oo_O Progress???:facepalm:
    JBU[OP] likes this.
