Fuel economy...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by echomonkey, Feb 2, 2018.
  1. Mar 16, 2020 at 4:34 PM
    #201
    SweetTooth182
    SweetTooth182 Active Member
    SoCal
    2020 TRD Sport DCLB
    Found out why my MPG was so high...it somehow got set to Imperial gallons rather than US gallons. Now I'm showing 20-21, right on track with my actual calculated MPG at the pump. I would have been perfectly happy with 20 before I thought I was getting 25 :rofl:
  2. Mar 16, 2020 at 4:36 PM
    #202
    MidCitiesMildMan
    MidCitiesMildMan Well-Known Member
    2017 Toyota Tacoma Limited
    Stock and staying that way
    That has been experience. It is pretty close.
    shakerhood likes this.
  3. Sep 25, 2020 at 8:47 AM
    #203
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Set a new personal record for MPG last night driving from Harrisonburg, Va to Arlington, Va.
    29.6 mpg average for 135.1 miles.
    All highway except for 8 minutes of idling in a Cook Out drive-thru and a couple residential miles.
    (Note: this was with heavy use of hypermiling tactics with little use of the throttle.. targeting ~1600 rpm and 63 mph but slowing to as much as 55 on some minor inclines.)
    15taco4x4 likes this.
  4. Sep 25, 2020 at 9:29 AM
    #204
    boilovepho
    boilovepho Member
    2019 Tacoma TRD OFF ROAD DCSB C-Blue
    I drive the truck normally. I’ve never seen better than 18.5 mpg . V6 mt dcsb.
  5. Sep 25, 2020 at 9:38 AM
    #205
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    I just drove 186 miles towing a trailer with my atv (Can Am approx 720 lbs) with the KO2s/lift/canopy and got 18 mpg at 60 mph
    Kamloops to Valemount, BC so it’s a hillyroute on the edge of the Rockies.
    I figured you guys would be getting better.
  6. Oct 9, 2020 at 2:31 AM
    #206
    MidCitiesMildMan
    I drove to far south Texas last week. Driving 82-93 mph most of the way, it still got over 19 mpg on the highway.
  7. Oct 9, 2020 at 7:08 AM
    #207
    Texaspoff
    Texaspoff New Member
    Lane
    2020 White Tacoma SRTSS
    I have been in my TSS for about a month now, and on average driving 34 miles back and forth to work on the freeway in Houston I am averaging around 22.5 at 70 to 75 MPH. I have the 2.7 auto and everything is stock. Not as good as my 2016 Nissan Max at 27, but not bad considering it is a truck and the tire size.
    TXPO
  8. Oct 9, 2020 at 7:30 AM
    #208
    Phich
    Phich Porkchop Express
    San Antonio
    2017 TRD Off Road tuned to KDMax perfection
    Six Demon Bag
    Just for kicks I'm gonna respond here.
    When bone stock, my 2017 TRD OR got 16-17ish mpg hwy and pretty much the same around town.
    Then I got 285 e load tires and guess what? It pretty much stayed the same.
    Then I got 4.88 gears. My mileage improved to 17-18ish mpg hwy.
    Then I got OVTune. Improvement to 18-20 hwy.
    Cruise control always lowers mpg at highway speeds. I use it on long trips.
    Had an MBRP 3" exhaust. It was just a noise maker. No effect on mpg.
    Had an AFE CAI and while it did help with towing torque and HP at higher rpms, its only effect while not towing was basically just making the truck sound great. No effect on mpg while not towing and even then is speculative.
    Through all that, this the current configuration:
    2.5" lifted on Fox 2.0
    Dakar Leafs
    Stock intake
    OVTune dump tubes
    Gibson 2.5" catback
    OVTune 2.0 Beta (19800) (premium fuel, Shell 93)
    265/70/17's
    No heavy armor/winch/etc
    Rear seat delete with lock box
    Added weight of lowpro steel front bumper and JTM rear bumper and TRD skid makes the truck pretty much about the same weight it was stock, just a little heavier.
    Around town I'm at 17-20, depending on the length of the trip and type of road speeds.
    Highway I'm at 19-21, sometimes see it hit 22, but only on majority flats with at least a mild tailwind.
    Unfortunately, it's one of those vehicles that you have to mess with to achieve desired results and drivability.
    Now, fortunately, I love working on my truck so I accept it.
  9. Oct 9, 2020 at 8:45 AM
    #209
    Mozart
    Mozart Well-Known Member
    Cortland NY
    2018 ACLB SR5 4x4 V6
    32” Tires, BPF Front Recovery
    22.8 is the best I’ve done so far. With 265/75-16 tires. No other mods
  10. Oct 9, 2020 at 9:21 AM
    #210
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Last week driving Washington Route 20 from Wenatchee to Bellingham via Chelan-Washington pass (5500' elevation)
  11. Oct 9, 2020 at 10:57 AM
    #211
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    i average 20-22 mpg with 87 octane. and 25 -28 mpg with 93 octane.
  12. Oct 9, 2020 at 10:58 AM
    #212
    cryptolyme
    Virginia
    try a couple tanks with 93. i have the 2.7 and i get significantly better mpg with 93 over 87.
  13. Oct 9, 2020 at 10:59 AM
    #213
    cryptolyme
    Virginia
    it's not a V4!!! it's an I4
  14. Oct 9, 2020 at 2:05 PM
    #214
    Volt
    Volt Well-Known Member
    Overland Park, Kansas
    2022 SR5 4x4 Double Cab V6
    My fourth red Tacoma
    It seems that I get better mileage when driving on the highway when it is raining. I have noticed this several times.
  15. Oct 9, 2020 at 4:44 PM
    #215
    FrayAdjacent
    FrayAdjacent Well-Known Member
    Matthew
    Austin, TX
    2017 Tacoma SR5 4x4
    I drove from N Virginia back to Austin TX this week, and hit 23MPG average over the whole trip.
    Interbeing likes this.
  16. Oct 9, 2020 at 4:52 PM
    #216
    Interbeing
    Interbeing A Canadian living in Texas
    Austin, TX
    2020 Tacoma TRD Off-Road 4x4 DCSB AT
    TRD Pro suspension with Headstrong 3 Leaf AAL, DV8 OR front slimline bumper & Engine Skid Plate, RCI OR high clearance bumper, CaliRaised Trail Edition Sliders, Spidertrax 1.25" Wheel Spacers, 265/75 16 GY Duratracs, wrapped the OEM wheels, OR Roof Rack, Extang Exceed Hard top Tri fold tonneau.
    That is fantastic mileage! I feel happy getting 18mpg.
  17. Oct 10, 2020 at 8:08 AM
    #217
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Wtf? i filled up with shell E10 premium in my v6 and now have a 112 miles on that tank. I've noticed a lazier truck and slightly over 1 mpg loss over the same roads and speed traveled this week. Can't wait for this tank to run out and put back the 87 regular.
  18. Oct 10, 2020 at 9:34 AM
    #218
    Punkface
    Punkface Well-Known Member
    Colorado
    2020 Tacoma TRD Off-Road DCSB 4x4
    Premium burns faster than regular. Our trucks are tuned from Toyota to be optimized for 87.
    I make about 19 MPG but I drive pretty conservatively and mine's stock.
  19. Oct 10, 2020 at 9:49 AM
    #219
    markm0311
    markm0311 ________________
    2000 Toyota RAV4
    It’s because you bought gas from Shell.
  20. Oct 10, 2020 at 10:27 AM
    #220
    cryptolyme
    Virginia
    it takes a couple tanks for the ECU to adjust to the change in octane.
