Fuel filler door rubbing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jofixer, Jan 9, 2011.
  1. Jan 9, 2011 at 5:44 AM
    jofixer
    jofixer [OP] Well-Known Member
    joe
    webberville, mich.
    SR5 sport 4x4
    does anybody have a problem with their fuel filler door rubbing against the inside when it is open approx. 90 deg. to the sidebody/fender? If so please recommend how to fix it. I'm thinking about drilling out the rivets and shimming it out maybe 1mm or so. Is this a common problem or has mine been tweaked?
  2. Jan 9, 2011 at 6:07 AM
    sixdoubleseven
    sixdoubleseven Well-Known Member
    Dave
    Boston
    14 DC 4x4
    Mine rubs ever so slightly. I don't think it's worth removing and reinstalling after re-drilling holes. I say live with it.
  3. Jan 9, 2011 at 6:11 AM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    I opened mine up and pulled it straight out by hand..fixed the rubbing although it wont stay open by itself now
  4. Jan 9, 2011 at 6:53 AM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    Mine was bent one day. Not sure how, but maybe some kids who knows. I noticed when it opened it stopped halfway and was contacting on the edge near front of truck. It took the paint off. I noticed the lower hinge had crumpled paint so it got bent inwards. I used a large screwdriver and towel under it to pry it back out. I then cleaned and touched up with paint. The odd part was when closed it was flush with bed so I'm not sure how it was that off.
  5. Jan 9, 2011 at 7:56 AM
    ilscungilli
    ilscungilli Member
    Longmont, CO
    2008 TRD Dble Cab Short Bed
    Rear TSB, Billy 5100 at 1.75" up front.
    I noticed that mine rubbed on the paint. I told the dealer, and they touched up the paint, and bent the inside part of the door. The tolerance seems way too close to me. They should have given it a little more room.
    Gunshot-6A likes this.
  6. Jan 9, 2011 at 8:00 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Same thing happened to mine. Dealer touched up the paint and adjusted the door (probably just bent it). I probably could have bent it myself but it was under warranty and no sense in me attempting and breaking something.
  7. Jan 9, 2011 at 8:14 AM
    sea nymph
    sea nymph Well-Known Member
    PA
    2005 DC Off Road SR5 4x4
    Mine rubs as well! The paint hasn't worn yet, but I'm keeping an eye on it and opening very carefully!
  8. Jan 9, 2011 at 9:31 AM
    jofixer
    joe
    webberville, mich.
    SR5 sport 4x4
    Sorry about no picture, not quite TW literate yet. Anyway, is there a quick and dirty fix to seal the paint as mine has rubbed off already. I live in salty michigan so I should act quickly..... Thanks for the quick responses..
  9. Jan 9, 2011 at 3:03 PM
    sixdoubleseven
    Dave
    Boston
    14 DC 4x4
    You can get touch-up paint from the dealer. It's a perfect match and is very cheap. I applied some to cover up a rock chip.
  10. Jan 9, 2011 at 3:12 PM
    Coreyjon
    Coreyjon Northern Alliance: Airlift Div
    Upstate, Ny
    08 DCab 4X4 SR5 TRD Sport
    iPod Adapter, Bilstein 5100's @ 1.75" front, Wheelers 3-leaf 1.5" + overload rear (2"), custom carrier bearing drop spacers.
    I have the same problem, not really worried about the paint being worn off as you never see it, When I have some time though I do need to bend the bottom hinge back out and touch it up to prevent corrosion. I agree, its not bent much, hardly noticeable , the tolerances for the fuel door are way too tight.
  11. Jan 9, 2011 at 3:39 PM
    vinnyvavoom
    vinnyvavoom Well-Known Member
    CT
    2020 White SR5 4WD DC LB
    of course
    Mine does not touch at all, not even close....
    wonder if they made some extra clearance on the 09? :notsure:
  12. Jan 9, 2011 at 5:50 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    I doubt it as mine has plenty of clearance too ('05). But maybe these guys' doors/hinges are getting tweaked because they're not lubricating them regularly? If you don't keep them lubricated, the hinges will snap. So maybe this is the precursor to that? (not saying that's the case, just a thought/idea on a possible reason for it happening)
    I'd like to see pics of these tight-fitting doors to compare with mine.
  13. Jul 12, 2013 at 12:00 PM
    Eldub
    Eldub Member
    Baltimore, MD
    2010 Off Rd Dbl Cab Std Bed Red Auto
    My cover has rubbed off the paint on the bottom left corner and the door actually slides off one of the clips in order to open it enough to insert gas pump. Seems like it doesn't open nearly as much as it should, the lower bend of the hinge rod thing is hitting on the part that is riveted to the truck and keeping it from opening farther. I keep meaning to pry at it with a screwdriver but only think of it when getting gas. Have any of you guys had success with prying at it or have you just ignored it?
  14. Jul 12, 2013 at 12:02 PM
    Eldub
    Eldub Member
    Baltimore, MD
    I have never even thought to lubricate the fuel filler door, but it makes sense since it is a hinge. I will try to take a pic and post.
  15. Jul 12, 2013 at 1:11 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    The hinge could be going bad, especially in the rust belt. I had to replace my hinge a year ago. top was rusted so bad that it broke. I bought a new door assembly from a dealership and carefully pried the hinge off and put my original painted door on. Door and hinge cost around $35
  16. Jul 12, 2013 at 2:04 PM
    jassco
    NH
    2023 TRD Offroad
    Keep a can of lithium in the cab and give the hinges a spray every few fill-ups. I use it for my clutch pedal too. They actually do this at some dealers when you service it.
    A screw driver with a cloth over the tip worked great to bend the hinge back into place. Just make sure you touch it up where the pain is cracked or it will rust quickly.
    TRDSport10 likes this.
  17. Jul 21, 2015 at 1:55 PM
    WAXSMITH
    WAXSMITH Member
    willi
    saskatchewan,canada
    2011 silver/gray 4x4 access cab
    pipe rack to carry boats, canoes etc
    The hinges on the 2011 I have "WERE" quite small. In 2014 the door started rubbing and lately it could only be opened about 1/2 way if I was careful. Well, the gas bar people fixed that soon enough,both upper and lower hinge broke off and the door then hung on the plastic tie strap to the filler cap. When I looked at the hinges closely I found them to be totally rusted and that despite the fabulous Toyota regular service which "in writing" includes LUBRICATION OF All HINGES. As a protest I was going to start driving around with the door tied shut with bright yellow tape, but decided instead to fix it myself. I bent up two 10mm alum strips and sheet-metal-screwed them on to the existing vertical bracket. The door now works better than before and only very close scrutiny reveals a little skew. Later I looked at a Ford fuel door and although it requires no rocket science they do have "a better idea".
  18. Jul 24, 2015 at 10:13 AM
    bruinsrme
    bruinsrme Well-Known Member
    Scott
    Worcester
    BRM 2010
    My hinge just went. And I have rub marks on the lower left of the door
  19. Jul 24, 2015 at 11:57 AM
    bruinsrme
    Scott
    Worcester
    BRM 2010
    Standing at the dealer now. Fuel Door, hinge, rivets, paint and labor $97
    Can of grease $2.50
  20. Jul 27, 2015 at 11:18 AM
    WAXSMITH
    WAXSMITH Member
    willi
    saskatchewan,canada
    $97, dirt cheap, especially if they do it on their bill.
