Fuel filler door rubbing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jofixer, Jan 9, 2011.
  1. Jul 27, 2015 at 4:01 PM
    10toy
    10toy Active Member
    OH
    2010 Tacoma 4x4
    This happened to my 2010 under warranty and it took some complaining to get them to replace it. It begins rusting inside the hinge and then binds enough to bend the hinge causing the rubbing. They first blamed it on me and I assured them that I have opening fuel filler doors for over 20 years now and have never had this problem before. Some simple plastic bushings would prevent this. Keep it lubed and it won't happen again. My biggest complaint with the truck...not bad.
    Gunshot-6A likes this.
  2. Jul 28, 2015 at 3:59 AM
    bruinsrme
    bruinsrme Well-Known Member
    Scott
    Worcester
    BRM 2010
    I didn't hesitate in saying schedule it.
    Seeing some of the things people are doing and the time it takes, $97 for everything was a bargain.
  3. Aug 5, 2015 at 12:39 PM
    Bjwilms7
    Bjwilms7 Well-Known Member
    Brandon
    Fairfax, VA
    09 Tacoma TRD Sport DCSB 4X4
    Billet grill, 20% tint, 265/70/17 BF Goodrich tires, 3" smittybilt nerfs, weathertech guards, Toytec 3" lift (Bilstein 5100s front/rear, Eibach, AAL), LR UCA's
    This just started happening on my 09. It's not even flush with the side of my truck anymore. Need to bend the hinge ASAP.
  4. Aug 5, 2015 at 12:43 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    Was happening on my 2011. The door was binding because it could not actuate the hinge due to rust buildup. I ended up spraying out the hinge with WD40 to knock all the rust out (a ton of rust came out), then hit it with white lithium grease. No issues now. I relube it ever couple of months. Still bullshit that this happens on a 30k+ dollar truck.
  5. Aug 8, 2015 at 7:41 PM
    Zoot
    Zoot Well-Known Member
    2011 DC/SB TRD O/R 4X4
    Toyota bed mat, Wet Okole's F&R, Window Tint, custom trail-stripes, Cooper A/T3 265/75R16, MedlinAround interior LEDs, Leer 100r, aFe air filter, K&n cabin filter
    WTF this just started on mine when I filled up last time, edge is scraping off the paint inside the door!!!! POS
  6. Oct 3, 2015 at 7:51 AM
    sifuquoc
    sifuquoc Member
    here's what mine looks like... lower hinge was catching, and i used the dremel to trim a bit on the right side... then hit it with some dupont spray/wax. maybe i'll pick up some touch up paint later...
    I don't know why it was bent/rusted at the bottom, maybe the catching bent it eventually?!?
  7. Oct 3, 2015 at 9:53 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Need to keep the hinges lubed up. They dry out and the hing catches bending the metal.
  8. Oct 3, 2015 at 9:55 AM
    DrFunker
    DrFunker Well-Known Member
    I used a few strips of clearbra in there.
  9. Oct 3, 2015 at 2:31 PM
    DEMikey
    DEMikey Mr. Badwrench
    mikey
    delaware
    2013 red taco
    100XR, OTW Surf Rod Rack, Toytec 3" lift, +1 on tires
    mine does it too......im going to drill the rivets, and put a shim behind it and reinstall.
  10. Apr 7, 2017 at 5:45 PM
    BuddyS
    BuddyS Well-Known Member
    Maryland
    2013 TRD Sport 4x4 MT
    Mine just started doing this today, too. On a 3 year old 2013 with 26,000 miles. Funny thing is that it doesn't seem to be rust/corrosion... I think it has to do with the leer cap that I just put on the truck the other day. I think the weight is somehow slightly bending/bulging the fender metal to the point that it rubs the fuel door when it opens. Crazy that this could happen.
  11. Apr 8, 2017 at 4:58 AM
    DEMikey
    mikey
    delaware
    2013 red taco
    i was going to drill the rivets but the truck got side swiped out in front of my house. luckilly from the carnage we figured out it was a silver toyota, with a bug guard and i found him in my neighborhood.
    got me all the way up to the fuel door so ill see what the body shop does about it.
  12. Apr 8, 2017 at 5:05 AM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    My 2005 does it as well. Has the paint off. If I pull out on gas door when opening it doesn't rub. I don't have any rust, trying to gradually bend it, rather rub than pry the damn thing right off.
  13. Apr 8, 2017 at 5:14 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Yes very crazy. I would never think that possible but I guess so. I love these trucks but there is some cheap steel being used to build them (frames rust, flimsy tailgate etc)...
    BuddyS[QUOTED] likes this.
  14. Apr 8, 2017 at 6:11 AM
    Northern Taco
    My tailgate is like a boomerang. But when I go to sell it people don't seem to care, so either do I.
  15. Apr 8, 2017 at 7:13 AM
    #35
    Doughnut Spaghetti
    Doughnut Spaghetti Well-Known Member
    Kristofer
    Lansing, Michigan
    2009 Tacoma SR5
    I have an 09. Mine rubs too. Actually kinda annoys me, but its only when Im getting gas that I have to deal with it.
  16. Apr 9, 2018 at 7:58 PM
    #36
    WAXSMITH
    WAXSMITH Member
    willi
    saskatchewan,canada
    2011 silver/gray 4x4 access cab
    pipe rack to carry boats, canoes etc
    Thanks for the comment. Meanwhile the fuel spout access door on my 2011 fell of and on the door on a 2009 my wife drives one of the 2 hinges broke. I found out too late that those hinges have to be regularly lubed, because road salt and similar stuff easily splashes on these hinges. The funny thing is that in the maintenance check off list for the regular service intervals "LUBE ALL HINGES" is always checked off but those 2 are never actually lubed.
    Corroded not lubed hinges break easily especially because they are very flimsy to start with.
  17. Apr 9, 2018 at 8:00 PM
    #37
    ToyoKühl
    ToyoKühl Well-Known Member
    Aaron
    UP Michigan
    2015 DCSB OR
    OME 887 with Nitrocharger Sports and full Dakar Pack SCS Coopers 255 85 rigid industries
    This happened on my 15 a year after purchasing
  18. Apr 10, 2018 at 4:00 AM
    #38
    Ncskeeter
    Ncskeeter Well-Known Member
    North Carolina
    2005 Silver Tacoma Prerunner DCSB SR5
    Mostly stock
    After about 10 years mine was flexing a little bit and rubbing due to the hinge binding. I hit the hinge with silicone spray and all is good again.
  19. Apr 19, 2018 at 6:01 PM
    #39
    WAXSMITH
    WAXSMITH Member
    willi
    saskatchewan,canada
    Yes, lube is the answer, and that I discovered after both hinges broke due to seizing.
  20. Jun 7, 2018 at 2:02 PM
    #40
    Dennisi01
    Dennisi01 Well-Known Member
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    I hit it with deep creep last night with no change today. When i get home im going to murder the hinges with regular wd tonight and see if i can flush any rust out
