Fuel filter 2nd gen, 2.7l, db, 2wd, at
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Orlando roofer, Jun 21, 2020.
  1. Jun 21, 2020 at 6:47 PM
    Orlando roofer
    Orlando roofer [OP] '15 Prerunner i4 2.7 DC SB RWD AT
    Sean
    '15 Prerunner i4 2.7 DC SB Auto
    Hi,
    My 2015
    2nd gen, 2.7l, db, 2wd, AT has about 170k miles, and i m getting a feelinf that fuel filter needs to be replaced as it kind of vibrates at idle n showing signs of struggling for fuel at idle.
    So, the question is where the fuel filter located? Any tips n recommendation will be great!
    Thank you Tacoma World !
  2. Jun 21, 2020 at 7:21 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If it was struggling at an idle it would really suffer under a load.
    The fuel filter is inside the gas tank as part of the fuel pump assembly.
    Maybe clean the MAF and the throttle body.
    Muddinfun, TnShooter and whatstcp like this.
  3. Jun 22, 2020 at 1:26 PM
    Orlando roofer
    Sean
    It'a vibration at idle/park only when ac is on.
    Once i put it in D or N the vibration goes away.
    I am suspecting engine mounts.
    What do you think?
  4. Jun 22, 2020 at 4:02 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    It is an internal combustion engine sitting on rubber mounts. There is always some vibration.I highly doubt the engine mounts causing anything. I've never had to replace an engine mount due to a vibration...
    What is the RPM reading with the AC off?
    and with the AC on?
    The RPM should increase when the AC is on.
    Have you cleaned the MAF and Throttle body. You probably need to at that high mileage 172K.
  5. Jun 22, 2020 at 4:06 PM
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    I also vote for cleaning the MAF. I do it once a year on my 2.7 and the engine will typically run quieter and smoother after. Just something Ive noticed, and something I do as routine maintenance rather than looking for an effect so I wouldnt say it's a placebo.
  6. Jul 10, 2024 at 9:29 PM
    Orlando roofer
    Sean
    now 4 years later it has 270k miles and i just log back in here and saw your messages! didn't changed mounts and didn't changed MAF :) the vibration coming from transmission mount i am sure ..will change soon :) Thank you all!
