Fuel Filter Bracket
Discussion in '1st Gen. Tacomas (1995-2004)' started by cumminsdiesel, Nov 24, 2009.
  1. Nov 24, 2009 at 1:08 PM
    cumminsdiesel
    cumminsdiesel [OP] Well-Known Member
    Alex
    Brecksville, Ohio
    Toytec coilovers, skyjacker leaf springs.
    Well I changed my fuel filter today, and it seems like it was never replaced. And my luck, the bracket in which holds the filter, the adjusting screw (to clamp the bracket) was severely rusted out and broke.. Should I get a new bracket (screw that broke will not budge)? Or just rig something up?
    Also, question about which way the filter goes in, does IN go towards the rear of the engine block, or front of the engine block?
    Thanks, Alex
  2. Nov 24, 2009 at 1:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    "IN" is from the tank.
  3. Nov 24, 2009 at 1:18 PM
    hoosiertaco
    hoosiertaco Well-Known Member
    Welcome to the 'World'. I really like your user name!!:cool:
  4. Nov 24, 2009 at 5:31 PM
    cumminsdiesel
    Alex
    Brecksville, Ohio
    By far the biggest PITA. Id rather be doing a full overhaul.. Gas that came out of the filter looked as dark as oil.
  5. Nov 24, 2009 at 6:59 PM
    Siebler
    Siebler Duck Killing Machine
    CJ
    Portland, OR
    99 Long Travel 5 lug, 01 Tundra 4wd
    TC LT Front, F67 on 12" shackle, LCE Underdrive Pulley, Flex-a-lite fan, DT headers, Super 44 muffler, 4:11's and Aussie Locker, 22 Gallon Fuel Cell, Beard seats, sliders, bed cage
    I broke mine too when I did it. Used a hose clamp to hold it in place. No problems 40k miles later
  6. Nov 25, 2009 at 5:08 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Rig something up.....
  7. Nov 25, 2009 at 10:39 PM
    cumminsdiesel
    Alex
    Brecksville, Ohio
    Ya, ended up using a hose clamp.
    For some reason, my filter was on backwards when I took it off?? The "IN" should be facing the rear of the truck correct?
  8. Nov 25, 2009 at 10:58 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Yes, IN means in from gas tank and OUT means out to engine.
