Fuel Filter Change??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cormchar, Aug 24, 2011.
  1. Aug 24, 2011 at 7:07 AM
    cormchar
    cormchar [OP] Member
    Hey guys,
    When do you normally change your fuel filter on your 2nd Generation Tacoma? How many km's?
    Thanks.
  2. Aug 24, 2011 at 7:10 AM
    textoy
    textoy Well-Known Member
    Fred
    Texas
    2011 4x4 TRD DC
    don't know about tacomas but most toyota's have fuel filters that are never supposed to be changed.
  3. Aug 24, 2011 at 7:32 AM
    KBToyota
    KBToyota Well-Known Member
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    OME 883, 5100 all around, Wheelers 3 leaf progressive aal
    Saw this on Tundra Solutions back when I was on that site, thought it might be helpful.
    The great fuel filter myth.
    Written by Jim Hopkins, Toyota Tech Adviser
    Feb 08, 2004 at 04:00 AM
    When Toyota Engineers first developed their electronic fuel injection (EFI), they were searching for a maintenance free, self regulating fuel system that would continually maintain itself in optimum working condition, with NO maintenance. A fuel system customers would just love for it's low, low maintenance.
    They knew that the fuel must be kept clean enough to pass freely through the fuel injectors, etc. without any clogging at all. For this dedicated filtering purpose "Nippondenso" developed a very special fuel filter with over ten times the filtering surface of any previous automotive fuel filter. It is inside a very strong, rust proof metal container with high quality threaded fittings, to withstand the high fuel pressures of EFI. The filter medium is carefully pleated, so a huge filter area can be installed inside a compact metal container. It is a truly fantastic fuel filter! "State of the art"!!!
    The Engineers explained it this way. Their studies had shown that in some areas the current (small) fuel filters showed anywhere between about 60% to 15% clogging after 50K km. Therefore they had previously recommended their replacement at the 50K km service, because they felt that in some parts of the world the fuel filters may not make it to the next service at 100K km with much reserve to spare. They had found however that, overall, North American fuel was relatively clean.
    There would be even less contamination entering EFI cars fuel filters, because of the new, large filter sock over the fuel pump pickup tube, inside the fuel tank that was made quite fine to protect the high speed electric fuel pump required on EFI cars. This pick up filter sock was somewhat "self cleaning" due to the sloshing action of the fuel in the tank bottom, and most dirt would just slosh off and be captured in the bottom of the fuel tank where it could do little harm.
    Unless, of course, someone dumped a full bucket of mud into the fuel tank. They reassured us that with the smaller fuel tank filler neck it was very doubtful that this would ever happen. In any case no
    filter could ever hope to cope with a humongous, catastrophic amount of dirt entering the fuel tank, and that it would require removal and cleaning of the fuel tank anyway.
    Now! Compare fuel filters! If the older style smaller) fuel filter had a filtering capacity of 100 then this new EFI fuel filter with ten times the filtering capacity would be rated at 1000. In an "imaginary"
    comparison test we could assume that since the old fuel filters may show 50% clogging at 50K km, those fuel filters were possibly replaced when 50 of their 100 filtration units were clogged at the time of the
    specified 50K km service interval.
    At 50K km the older fuel filter car would have It's smaller fuel filter replaced with a brand new factory replacement fuel filter, according to the factory recommended maintenance schedule, so it's reserve filtering capacity would be restored from 50 to 100. Since the EFI car neither required nor received any fuel filter maintenance it's larger 1000 unit filtration area would now have only a reserve of 950
    units.
    At 100K km inspection, the same recommended services would be performed, leaving the older fuel filter car with a fresh new fuel filter, with it's filtering capacity fully restored to 100. However, the EFI car would now have it's reserve lowered to 900.
    After the 150K km service the older fuel filter car would be again restored to 100 units, while the EFI car would still have 850 units reserve.
    At 200K km the older style would be restored to 100 units, and the EFI car would be left with 800 units.
    At 250K km it would be 100 to 750reserve filtering units. At 300K km, 100 to 700. At 350 K km100to 650. At 400Kkm 100 to 600. At 450 K km 100 to 600.
    And on and on………….Till finally at "one million" kilometres the older model would have it's EIGHTEENTH new fuel filter installed, restoring it's reserve filtration capacity once again to 100 units and
    the EFI car still having it's original fuel filter would also have a 100 unit reserve filtration capacity.
    Therefore it may, just may, be necessary to recommend that the EFI car should also have it's fuel filter replaced at one million and 50k km. We should live so long!
    However, if the rate of accumulation of dirt was much lower than the predicted 50 filtration units per 50K km, during this one million km. test, then the EFI car may still have a very much larger reserve filtration capacity than we calculated. The lower dirt content would not have benefited the older, small fuel filter car at all. As well, the older style fuel filter would have contributed eighteen discarded fuel filters into a land fill, and at even five bucks a filter, cost
    the customer "ninety" dollars in maintenance. Eureka! No more fuel filter replacements! Fuel filter replacement is finally just a relic of the past! WOW!
    At this time (twenty years ago) fuel filters were completely deleted from all Toyota service maintenance schedules for all EFI vehicles. The oil change, air filter change, etc., remained, and were covered in
    great detail in all factory service manuals, etc. But, all references to "fuel filter replacement" were deleted for all time from all factory service manuals. A whole half page of the factory service manual is devoted just to inspecting fuel pipes for any kinks or
    deformation (including illustrations of a leaking fuel line). Text and illustrations of the precise, recommended placement of the rubber fuel line's spring hose clamp is fully covered, but absolutely NO mention
    whatever of "fuel filter replacement". There is absolutely NO mention of any fuel filter replacement in any owner's manual (does anyone ever read them?) Do you think that the factory repair and owner's manuals
    were trying to tell people something??? Did you get the hidden message??
    The fuel filter was considered to have a service life far exceeding the projected life of the majority of most of the vehicle's other components, and was fully expected to outlast the cars. Replacement of the fuel filter made much less sense than the replacement of the fuel tank or the replacement of the ignition key, or the trunk lid emblem.
    Great! Parts people were instructed to anticipate virtually zero fuel filter sales. One less maintenance service problem??? Great! Wow! Customers would love this!!!
    But, much to the dismay of many Engineers, fuel filter replacement sales for EFI equipped cars remained telatively high. Why? Discarded fuel filters were reclaimed, opened up and found to contain almost no
    dirt at all. Why were people replacing them??? The best laid plans of mice and men often go astray! Who knew why???
    There was great concern that there was a high risk involved because some dirt could accidentally enter the fuel system, downstream of the fuel filter during the fuel filters replacement, and damage the downstream fuel injectors etc. There was also concern that all fuel line fitting gaskets, etc. would not be properly replaced with new ones, and that the fittings torque might not be correctly reset to factory specifications, as this was a very high pressure EFI fuel line.
    This part of the EFI system was intended to be serviced "only" by trained mechanics, yet it was apparent that it was being serviced by people who, clearly did not know what they were doing. There were many complaints that replacement fuel filters were much too expensive, and much too difficult to replace. Why were people still replacing them??
    Nobody seemed to know.
    Believing that the fuel filters were too highly visible they were painted black, and the Engineers tucked them up under the intake chamber where they were very difficult to see or service, on the 7M-
    GE models, to discourage needless replacement, but people kept on replacing fuel filter, despite the difficulties. Why???
    It was suggested that a sticker be applied to warn people not to replace the fuel filter. This had been done previously to discourage needless spark plug replacement. The warning sticker helped, but many
    people simply ignored the warning sticker and replaced the spark plugs anyway. Another very hard to break habit, that still continues today. Nobody wanted to commit to stating "NEVER" replace fuel filters, as
    that's a very, very strong statement. Should the sticker read:
    WARNING! Replace fuel filter every one million kilometres, or 25 years, whichever comes first!
    I think a sticker on the fuel filter stating: Warning! "This is not a fuel filter", may prove to be more effective.
    Do you think that fuel filter replacement is genetic?? My father always replaced his spark plugs and fuel filter, and I am fully committed to continue replacing mine too, and to the preservation of this fine family tradition. I don't know???? I just can't explain why
    people insist on performing these seasonal, cultural, fuel filter rituals. It must be passed down from father to son as it's been going on for over 20 years! No warning sticker can ever overcome that kind
    of dogged determination.
    Why were people in North America still replacing these costly and difficult, and risky to replace fuel filters with NO instructions or any valid technical reasons for doing so??? It soon became apparent
    to the Engineers that fuel filter replacement was so deeply ingrained into the North American culture that people just could not break their highly addictive fuel filter habits.
    I had many phone calls: "Where the hell is the dam fuel filter any way?? What lame brained idiot put the fuel filter up there where I can't even get at it? He sure didn't know a dam thing about what he was doing! I could sure teach him a thing or two about engineering
    cars." All I could say was " Why are you replacing the fuel filter?? Why?? The answer was usually " I always replace fuel filters. I won't ever risk having a fuel filter plugging up. So I asked, "Have you ever had one plug up???" Of course not stupid! Because I always
    replace them. That's why" How can you ever argue with such success???
    I suppose that if people derive some deep inner spiritual satisfaction by performing their traditional "fuel filter replacement" ritual, they
    are free to continue to do so! it's a free Country!! But I really wonder why they insist on doing it??
    Instead of applause, the poor Engineer receives insults!
    I see from reviewing many of the posts on this site that the grand tradition of fuel filter replacement continues on unabated. It continues to be, by choice, the first recommended line of attack, to resolve almost any performance problem. I see posts from owners whose crankcase breather pipes must be so badly clogged with hardened crud that a "Roto Rooter" couldn't clear them (engine oil forced out
    through the distributor??), I'll bet those same vehicles have probably had their fuel filters replaced. WHY? I have never, ever seen the replacement of a fuel filter successfully resolve any problem. Why do people always recommend first replacing the fuel filter??? Any suggestions????
    I suspect that with tens of thousands of Toyota fuel filter sales, that a great many people are accumulating a nice nest egg to finance their early retirement. Americans spend many millions of dollars a
    year on fuel filters. Would this money not be better spent elsewhere?
    Perhaps a: "I gave up replacing my fuel filter so that a starving child could eat! , type of charity. Are fuel filters car owner's pacifiers, or security blankets??
    I have cut discarded fuel filters apart , but I have never found anything inside that would ever restrict fuel flow. They appeared almost as clean as new inside?? If anyone has ever found one of these
    "Denso" fuel filters that was ever actually clogged with dirt?? I would sure like to hear from you. They may exist?? But, I have not found any in twenty years. Please post if you have ever replaced a fuel filter because there was real evidence that the fuel filter was actually restricting fuel flow, and a replacement filter actually solved the problem by restoring the fuel flow. Please post if one of these fuel filters has ever passed a particle of dirt that damaged a
    fuel injector.
    I believe that the fuel filters very, very clean passing through these fuel filters as I have not yet seen a dirt clogged fuel injector.
    I have found fuel pump residual check valves leaking from what I assumed was a spec of dirt (too small to see) as discussed in my previous post on fuel pumps, but I have always believed that this was because the fuel pump check valve was only protected only by the fuel pump intake filter sock, and not by the actual in line fuel filter.
    The fuel pressure regulator never seems to leak residual fuel line pressure. I think it's because it's fuel is all completely filtered??? Anyone ever found a leak fuel pressure regulator???
    I have only experienced one incident of fuel supply clogging, and that was because someone had attempted to repair a fuel tank by pouring an epoxy treatment inside to seal a damaged fuel tank The epoxy coating
    peeled off and completely clogged the fuel pump filter sock, inside the fuel tank, but the fuel filter was still OK. I recommended replacement of the fuel tank and the fuel pump, as it had become overheated while sucking away on it's plugged inlet filter sock. Never
    had a restricted fuel filter though.
    Please post if you have ever found a restricted fuel filter????
    Anyone???
    SupraMania - The great fuel filter myth.
  4. Aug 24, 2011 at 7:47 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    not restricted really, but when i replaced my fuel filter it had alotta black coming out :)
  5. Aug 24, 2011 at 8:00 AM
    cormchar
    Yeah couldn't find it in the owner's manual which is why I asked the question. So I'm guessing people are not changing it since it's not needed, according to Toyota.
  6. Aug 24, 2011 at 8:09 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    it only has a sock filter in the tank....doesnt have an external filter that i know of
  7. Aug 24, 2011 at 8:55 AM
    textoy
    Fred
    Texas
    2011 4x4 TRD DC
    My '99 Land Cruiser has 160K miles and has never had the fuel filter changed. I had taken it in to have it changed as a precaution and service manager said it is a permanent filter. That was 100K miles ago. Engine still runs fine and mileage has never changed since new. Guess I will forget about fuel filter.
  8. Aug 24, 2011 at 10:00 AM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    Lots of car manufactures are doing this. Gas is better refined now then it was in the day. My wife's old saturn had 175k on the original replaceable fuel filter. It never had an issue.
  9. Aug 24, 2011 at 10:30 AM
    KBToyota
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    I just replaced th efuel filter in my '90 pickup but thats because it sat for 4 years in storage and the tank got pretty nasty. I would say unless that vehicle has sat for a long time or some other out of the norm scenario you should let it be.
  10. Aug 24, 2011 at 10:51 AM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    I had a 91 chevy 4x4 I drove a lot in Baja and I had to change the fuel filter in it every 25,000 miles like clock work. It would start running like crap above 2000 rpm. I also had a 93 Toyota 4x4 V6 and also drove it a lot in Baja. I changed the fuel filter once at 100,000 just for the heck of it, no problem running like the chevy. I assumed it was the Mexican gas or the stuff in their station tanks. I just looked at the Toyota factory manual for the 93 and there is no mention of changing the fuel filter.
  11. Aug 24, 2011 at 6:45 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    You can get an external fuel filter kit from URD.
    that_06regularcab likes this.
  12. Aug 24, 2011 at 7:20 PM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    I dont think it is really scheduled but i recommend it, when I did mine I noticed a little better performance and the old filter was black which seemed kinda clogged compared to the white brand new filter which I installed a Walbro...the easiest way I found is if you have the long bed model of any tacoma its much simpler to take the bed off and slide it down about 12"-16" to access the top of fuel tank if you have short bed you have to drop your tank which is much more work and all this is from experience...
  13. Aug 24, 2011 at 7:23 PM
    mwtaco
    mwtaco Well-Known Member
    07DCSB Black
    omg. that toyota essay was so boring.
  14. Aug 25, 2011 at 11:50 AM
    jax45
    jax45 Member
    Sharpsburg Ga.
    2005 PreRunner
    Mass air seems too easy, cleaned it and air cleaner. More suggestions?
  15. Oct 3, 2016 at 6:56 PM
    EB Group
    EB Group Carbon Jedi
    Rudy
    Halifax
    2017 TRD Sport DCSB 6M
    Holy crap that is the longest post I have ever seen.
    Bocotacointhewild, mpm and teamfast like this.
  16. Dec 21, 2017 at 5:51 AM
    PDXKid
    PDXKid Active Member
    2011 DC TRD Off Road Manual Transmission
    Stock for now
    Soooo... Is there a fuel filter to change or not? If so, has someone done a write-up? This post is full of contradictions.
  17. Dec 21, 2017 at 6:08 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    its in the fuel tank
    permanent !
    mpm and PDXKid[QUOTED] like this.
  18. Dec 21, 2017 at 6:32 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    The filter is in the tank.
    Toyota claims it is a lifetime filter... but lets be real... it probably isn’t. And in the automotive world “lifetime” doesn’t mean forever. However Toyota does not ever recommend changing it regardless. So it would just be a personal preference thing.
    If its in the tank I probably wouldn’t change it for at least 200k miles.
    PDXKid likes this.
  19. Oct 25, 2018 at 5:36 PM
    dapetik
    dapetik Well-Known Member
    David
    Barboursville, Va
    2015 TRD Sport
    Magic bedcover, sweet ass floormats, rocket boosters, warp drive
  20. Oct 25, 2018 at 6:28 PM
    Eselhengst
    Eselhengst Well-Known Member
    South of Abbotsford
    2011 Access cab TRD Offroad
    Sway-A-Way 2.0 coilovers and rear shocks Wheelers 8 leaf springs and superbumps ARB front bumper Trail Gear sliders RCI aluminum skids URD Spec-U exhaust etc.
    If you want to be able to change an external filter, the URD fuel pump options are good. This is the route I’m going when I supercharge eventually. My 2000 Tacoma with the four cylinder would start running really bad every 30,000 miles if I didn’t change the fuel filter, to the point of a check engine light and a code I can’t remember anymore. The new filter would always cure the problem, but it was a nightmare changing the filter under the intake manifold, I got my arm stuck up in there once and it kind of freaked me out until after a few deep breaths I figured if it got in there I could get it back out. I’m sure there are some good stories in the first gen section about that filter location.
