Fuel Filter change?
Discussion in 'Performance and Tuning' started by ETaco23, Mar 6, 2009.
  1. Mar 6, 2009 at 9:53 PM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I got a new fuel filter and tryed changing it. But hesitated in doing it bc I had a hard time getting it out. I didn't want to bend the fuel lines or anything. Is there a trick or something to doing this? Should I have my local machanic just do it? Some help Please!!! :confused:
  2. Mar 6, 2009 at 9:59 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    You need a flare nut wrench set to get the nuts loose around those fuel lines. It was a PITA the one time I did it.
  3. Mar 6, 2009 at 10:10 PM
    ETaco23
    Evan
    PNW
    I got the nuts loose and off, but I didn't want to damage the lines. Is there something Im missing?
  4. Mar 6, 2009 at 10:17 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    So did you get the filter off? If so, you did it correct then. What's the question then?
  5. Mar 6, 2009 at 10:24 PM
    ETaco23
    Evan
    PNW
    No, After getting everything loose, I couldnt get the lines out of the filter. And I didnt want to bend them or something. What could I do to get the lines out easier?
  6. Mar 6, 2009 at 10:29 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    You're supposed to leave the lines in place and undo the bolts on the filter and wiggle the filter out.
  7. Mar 6, 2009 at 10:30 PM
    ETaco23
    Evan
    PNW
    Ok, I tryed! but didnt get the lines free. I'll have to try it again when I do my plugs next week I geuss!
    Thanks humanoid!
  8. Mar 6, 2009 at 10:45 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    Hope I helped some. Let us know how it all works out.
  9. Mar 7, 2009 at 3:42 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    When I did mine (on my 96)
    Disconnect the fuel lines from the body - nearest the fuel filter on both sides.
    This will give you enough play in the lines to remove the filter.
  10. Mar 7, 2009 at 10:20 AM
    ETaco23
    Evan
    PNW
    ^^^Alright ill try that! Do you just pull on them and they pop off or what?
  11. Mar 7, 2009 at 10:35 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Hey how often are you supposed to change out the fuel filter. I have an 06'.
  12. Mar 7, 2009 at 10:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Your is in th etank....cant change it as it is part of the fuel pump.
  13. Mar 7, 2009 at 10:39 AM
    ETaco23
    Evan
    PNW
    Not verry often! poeple usually dont do it. Toyota says there good for the life time of the truck. But its a good idea to change them at around 60-80K miles I guess. (Wouldnt hurt!)
  14. Mar 7, 2009 at 10:40 AM
    ETaco23
    Evan
    PNW
    ^^^Wow didnt know that!!
    thanks chris!:)
  15. Mar 7, 2009 at 10:40 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Oh okay got yah! Thanks chris!;)
  16. Mar 7, 2009 at 10:40 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yours is serviceable. You need to change it every so often.
  17. Mar 7, 2009 at 10:48 AM
    ETaco23
    Evan
    PNW
    ^^Yeah, I tryed it yesterday and failed! But I will give it another shot when I change my plugs. Hope I can get it out the 2nd time!
  18. Mar 7, 2009 at 10:48 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Why cant you get it out? nDid you loose the nuts like Janster said?
  19. Mar 7, 2009 at 10:53 AM
    ETaco23
    Evan
    PNW
    Yep, but the lines were a PITA! Not enough slack to get them out, and I didnt want to bend the lines. Im ganna try and remove the brackets on both sides to give me more slack in the line. By the way, do I just pull on them and they pop off?
  20. Mar 7, 2009 at 10:55 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I thought that they were threaded into the filter...its been a while since I last changed one....
