FUEL FILTER ; FUDGECAKE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacotruck 2.7, Apr 14, 2013.
  1. Apr 14, 2013 at 3:26 PM
    tacotruck 2.7
    tacotruck 2.7 [OP] Well-Known Member
    Katy TX
    09 cab and a half 2.7
    TWO QUESTIONS ON A 09 2.7 TACOMA WHERE IS THE FUEL FILTER AND HAS ANY ONE EVER PUT A INLINE FUELFILTER JUST BEFORE THE FUELRAIL ?
  2. Apr 14, 2013 at 4:47 PM
    charles leandro
    charles leandro Well-Known Member
    north alabama
    08 perrunner dc sr5
    none
    filter is on fuel pump in the tank buy pass filter needs to be high pressure or it will leak
  3. Apr 14, 2013 at 5:11 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    No real need to worry about replacing the fuel filter. It a million kilometer filter. Unless you somehow dump dirt in the tank you shouldn't ever need to replace.
    http://www.supramania.com/forums/content.php?121-The-great-fuel-filter-myth
    Some people refuse let go the need to replace things that don't need replacing.
    Why do you want to replace it? Or add a second pointless one down stream?
  4. Apr 14, 2013 at 5:30 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Gen I 2.7l the fuel filter was below the fuel rail on the intake side. Hard to replace DIY.
    It's a 2-year, 24k mile maintenance item for $120, just follow the maintenance schedule. Flush your radiator at the same time. It's not all that much money . . .
  5. Apr 14, 2013 at 5:30 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Good read.
    A member recently had his tank punched by a fuel thief. He posted a photo of the inside of the old tank.... had around 60k on it.
    Perfectly clean. If it weren't for the smell of gasoline, I'd have eaten off of it.
  6. Apr 14, 2013 at 9:54 PM
    tacotruck 2.7
    Katy TX
    Funny you should mentio "dump dirt" last sat dats exactly what i had coming out of the fuel line going into the fuel rail. Add to that blackend fuel, burnt dirt filled one year old spark plugs and soot driping out the tailpipe. LST the symptom was it would turn over allday but would not start. Solution replaced sparkplugs installed a fuel filter pre fuel rail i figure what could it hurt. Been runing fine since. See my job requires i drive through some very dirty mudy crapyass construction roads year long so perhaps my (service intervals) are quite diffrent than norm. First time it hapend ill have to stay on top of my maintanence in the future.
