Fuel Filter Headache
Discussion in '4 Cylinder' started by tacosoup89, Nov 3, 2013.
  1. Nov 3, 2013 at 5:45 AM
    tacosoup89
    tacosoup89 [OP] Active Member
    Carrollton, Ga
    2003 2.7L PreRunner
    Has anybody changed a fuel filter on a 2003 model taco. I have the 2.7 L don't know if that makes a difference. Anyway I thought it would be an easy change cause I initially thaught it would be located under the driver side door like most. I was wrong its under the intake manifold and impossible to dig out. Has anybody dealt with this issue? Tell me there is a trick to getting it out without tearing the engine apart.
  2. Nov 3, 2013 at 8:04 AM
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    It's pretty much set up the same as the 22RE fuel filter was, and it can be removed (did it on my '97 w/ 2.7L and my old '92). It takes time, patience and flexibility. Can't really remember how I did it on both - it has been a long time. But it is doable without pulling apart the motor.
  3. Nov 4, 2013 at 7:32 AM
    Hansel
    Hansel Well-Known Member
    Glenn
    Arizona
    base
    My understanding is that the fuel filter does not need to be changed very often.
    Does anyone know what the book calls for?
    In any case, I like to change filters per recommendation by the factory as a PM item.
  4. Nov 30, 2013 at 7:33 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Fuel filter in the gas tank on mine. It's a sock on the fuel pump and the fuel pump is in the gas tank. A real PITA for DIY. You can put a external fuel pump on - there is a link on here somewhere.
  5. Nov 30, 2013 at 7:44 AM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Look at your service schedule. I bet you won't find fuel filter mentioned at all. They claim 1 million mile, yet people want to change them anyway.
  6. Nov 30, 2013 at 7:51 AM
    george3
    New Jersey
    There is a million mile thread on here somewhere. Maybe there should be a link for gas filter on that thread. :D
  7. Nov 30, 2013 at 8:11 AM
    BamaToy1997
    Bill
    Navarre, FL
    According to Toyota service manual information, the 2003 Tacoma does not have an external filter for the 2.7L engine. The only filter it shows is the one in the tank. It does not have a service/replacement schedule. The 1999 model year was the last year of the external fuel filters for the Prerunner Tacoma.
  8. Nov 1, 2014 at 4:24 PM
    Twisted99
    Twisted99 Well-Known Member
    Gold Canyon, AZ
    I can't speak for the 03, but my 01 DC has one under the intake manifold.
    A MAJOR PITA. Took me about 45 min. to replace, probably twice that to figure out HOW.
    Sorry I don't buy into the million mile thing.
    Here's a few hints:
    Remove left front wheel and the rubber flap thing in the wheel well.
    You will need different length extensions, and a wobble (not a swivel) is a huge help for the bracket that holds it to the block.
    Loosen the lines first then the brackets.
    When installing, connect the lines, very loose, then the brackets.
    Tighten bracket then the lines.
  9. Nov 1, 2014 at 4:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    My 2000 had one. I just removed the intake manifold to change it. You're removing more shit, but you don't have to contort yourself into some origami shape to get to it.
  10. Nov 1, 2014 at 8:46 PM
    Twisted99
    Gold Canyon, AZ
    No origami or contortion, just the right tools and approach.
    The less you remove, the less less likely things go bad. :D
  11. Nov 2, 2014 at 5:23 AM
    DESTROYERRACER
    DESTROYERRACER Well-Known Member
    Sean
    Buffalo NY
    18 DCSB 4x4 SR5
    It's new......mods starting soon. Removed step bars so far. lol
    i agree with Twisted.......and the wheel well is the key, he beat me to it
  12. Nov 2, 2014 at 7:06 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah, you can go thru the wheel well, I just hate bending, and working in confined space.
  13. Nov 6, 2014 at 12:29 PM
    Indy
    Indy Master of all I survey.
    There are some things that are a bigger pain than needed. The fuel filter is one of them :laugh: For that I'd write the check and have a coke in the waiting room.
  14. Nov 11, 2014 at 1:55 PM
    shootis
    shootis Member
  15. Nov 14, 2014 at 8:11 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
  16. Nov 14, 2014 at 8:59 PM
    TACO626
    TACO626 Well-Known Member
    Montclair, CA
    02 Tacoma 2.7
    My 02 2.7 has the fuel filter under the intake manifold as well.
