Fuel Filter Location - 2004 Taco 2.7L
Discussion in '4 Cylinder' started by JSFoster75, Feb 7, 2012.
  1. Feb 7, 2012 at 6:20 PM
    JSFoster75
    JSFoster75 [OP] Well-Known Member
    Scott
    Bluff City, TN
    2018 Wrangler JLU Sahara
    Too many to list.
    Anyone have a diagram of where the fuel filter is located on this motor? I got up under it and tried tracing the fuel lines from the tank to the motor but with no success...
    Pictures would be great, but any information would be appreciated!
  2. Feb 7, 2012 at 6:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Its under the intake manifold on the driver side....lemmie see if I can find somthing to help
  3. Feb 7, 2012 at 6:42 PM
    CUtacomaTIGER
    CUtacomaTIGER Unprofessional Driver
    San Diego
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges Window Rain Guards Bed Liner
    I'd recommend removing front driver side tire to get to it.
  4. Feb 7, 2012 at 6:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Here is a schematic, with the head, and intake removed: you dont need to remove that stuff to access the filter:
  5. Feb 8, 2012 at 4:33 AM
    JSFoster75
    Scott
    Bluff City, TN
    Too many to list.
    Thanks guys, looks like that is a project for next Saturday! :)
  6. Feb 9, 2012 at 5:11 PM
    JSFoster75
    Scott
    Bluff City, TN
    Too many to list.
    Thanks for the information guys, was able to get it changed this afternoon... I'm pretty sure it had never been changed... 133,200 miles on truck...
    How would I tell if it's the original? It had a Toyota sticker on it...
  7. Feb 12, 2012 at 11:44 AM
    armyman89
    armyman89 Member
    mikkel
    new market alabama
    2004 taco prerunner
    so removing the driver side tire is the best way to get it off? any tips or tricks on how to get that bugger off would be great guys thanks
  8. Feb 14, 2012 at 12:09 AM
    1998tacomaowner
    1998tacomaowner Well-Known Member
    chris
    clarkston WA
    98 toyota tacoma
    3in lift,33s
    dont worry about it its not that bad everyone makes it out to be so hard it took me about 30 min i dident even take the tire off but i think my 3 inch lift helped me a bit some bolts are better to get to them at the top and some from the side hope this helps
  9. Feb 14, 2012 at 7:46 AM
    JSFoster75
    Scott
    Bluff City, TN
    Too many to list.
    I ended up not needing to take the tire off (even though I did), I ended up doing it all from the top side... But, my arms are kind of thin, for a larger person, it might be easier from the bottom side. I found it easier to remove the 2 bolts holding it to the side of the engine block, then put the new one in (make sure it's facing the right way in/out), then put it back on... Too hard to get to the tension bolt that holds it to the bracket.
