Fuel Filter location '99 Tacoma???
Discussion in '1st Gen. Tacomas (1995-2004)' started by SIK99Tacoma, Oct 14, 2011.
  1. Oct 14, 2011 at 5:20 PM
    SIK99Tacoma
    SIK99Tacoma [OP] Well-Known Member
    Taylor
    Big Sur
    2020 OR DCLB
    FOX IFP front 2nd clip 1/2" spacer, FOX 2.0 adjustable resi rear, RXT leaf pack, SSO slimline front w/ baricade 9500lb and amber light bar, ARE Cap, allpro steps, TRD pro style wheels w/ Kenda Klevar skins
    Does anyone know where to find the in line fuel filter on a 2.7L '99 Tacoma 4x4?
    Manual says either under the intake manifold, or on the rear driver side frame rail, but I checked under the manifold and the entire drivers side chassis and no dice.
    Any help?
  2. Oct 14, 2011 at 5:29 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    They're almost always on the drivers side, underneath where the driver sits. It's NOT in the tank like a 2nd Gen Tacoma, should be under the truck.
  3. Oct 14, 2011 at 5:36 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Its on the drivers side, i promise. Just look again man.
  4. Oct 14, 2011 at 7:11 PM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    yeah you missed it its there why are you changing it?? its going to suck changing haha
  5. Oct 14, 2011 at 7:12 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Nah i have read its easy to change. And you are suppose to change it around 100k i think
  6. Oct 14, 2011 at 9:31 PM
    707eric
    707eric Member
    Santa Rosa
    99 TRD 4x4
    Driver side damn near right below the seat on the inside of the frame rail.
  7. Oct 14, 2011 at 9:54 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    on the 2.7 its on the block, drivers side just below the intake plenum/manifold. Its about 3'' long and 2'' tall cylinder. You will see it looking above the top shock tower mount. Very easy to do. Two 17mm bolts for the fuel lines, two 12mm bolts that hold the clamp onto the block, 10mm to loosen the clamp. 15 minute job.
    You guys saying it below the driver on the frame, you have a v6. The OP has a 2.7 4cyl...lol, read his post :p
    Just did mine for the second time two days ago.
  8. Oct 14, 2011 at 9:55 PM
    Nitronick
    Nitronick Well-Known Member
    Nick
    Oregon City, OR
    98 tacoma sr5 v6 3.4
    driveside frame for sure. just did mine like a week ago
  9. Oct 14, 2011 at 9:57 PM
    TacoMX
    Jonathan
    Deltona, Florida
    he is a 2.7, not a V6.
  10. Oct 14, 2011 at 10:11 PM
    707eric
    707eric Member
    Santa Rosa
    99 TRD 4x4
    Oops missed that, sorry
  11. Oct 14, 2011 at 10:48 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    The man is correct, give him a cigar! :D
  12. Oct 15, 2011 at 2:00 AM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    it' a pita to do if you don't know how to do it right..
  13. Oct 15, 2011 at 10:42 AM
    SIK99Tacoma
    Taylor
    Big Sur
    2020 OR DCLB
    200k+ and running like shi*, it was suggested to me after I put my headers on and not having the exhaust leak stopped hiding the rough idle, so I thought why not.
    I guess i will look harder on the block then, thanks TacoMX. I guess I could have put 4cyl, thought 2.7 said it.
    Thanks for all the input guys.
  14. Oct 15, 2011 at 11:21 AM
    UndefinedTaco
    Justin
    Tracy, CA
    Toyota
    This is from Google images..don't bother about the red circle
    see the fuel line with the copper banjo fitting on it connected to the big black round canister? that is your fuel filter.
    Now jack your truck up..take driver side front wheel off..sit inside the fender wells and take off your engine drapes..then look straight inside towards the block and you'll see this
  15. Oct 15, 2011 at 11:52 AM
    TacoMX
    Jonathan
    Deltona, Florida
    I just took a couple of pics. My truck has a 3'' Body lift, so its easier to see.
    Good luck
  16. Oct 16, 2011 at 5:41 PM
    SIK99Tacoma
    Taylor
    Big Sur
    2020 OR DCLB
    Thanks guys. I just overlooked it. Right on the block where it should be.
  17. Oct 16, 2011 at 6:09 PM
    mackattack07
    mackattack07 Well-Known Member
    william
    Jacksonville NC/Graceville FL
    99 Prerunner 3.4/2000 4Runner3.4/85 Pickup22R
    i have a 99 mine is midway down the frame not on the block bui have a 3.4
  18. Oct 16, 2011 at 6:13 PM
    mackattack07
    william
    drivers side beside the frame anyone know the specs for that bolt mine is missing
  19. Feb 3, 2013 at 9:55 AM
    Basil Fawlty
    Basil Fawlty Member
    Upper left corner of the left coast
    99 ToyTac 4x4
    Only picture I could find. Reinstall step 10 on page EG-97 says "INSTALL FUEL FILTER Torque: 20 N-m (200 kgf-cm, 14 ft-lbf)"
  20. Feb 3, 2013 at 6:29 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    2.7 = Driver's side block of engine - PITA.
    3.4 = Inside of frame rail on driver's side, essentially under driver's seat.
    I've owned both and replaced both. The 2.7 fuel filter sucks to replace. Why in the hell didn't they just put it on the frame?
