fuel filter question
Discussion in '4 Cylinder' started by cheese7882, Jan 25, 2010.
  1. Jan 25, 2010 at 10:22 PM
    cheese7882
    cheese7882 [OP] Well-Known Member
    California
    2016 Tacoma TRD OR DCSB MT
    Anyone know of an easy way to change out the fuel filter on a 97 toyota tacoma thats a 4cyl w/ the 2rz engine?
  2. Jan 25, 2010 at 10:25 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    drop the tank?
  3. Jan 25, 2010 at 11:16 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    It's not in the tank, he has a 1st gen Taco. For the 4 banger it's in the engine compartment... see my reply over on TN on how to do it.
  4. Jan 25, 2010 at 11:37 PM
    cheese7882
    California
    thanks for the reply. I saw what you put on TN. is it difficult to take off the intake manifold?
  5. Jan 26, 2010 at 7:05 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Alot of people have been able to access it from the driver side fender well.
  6. Jan 26, 2010 at 2:45 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    IIRC you don't need to really take out the whole manifold, just get it loose to the point where you can remove the filter.
  7. Jan 26, 2010 at 6:45 PM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    I had to have my dad help me through the top of the engine compartment, and I took off the wheel on the drivers side and had to fit my hands in there and get it out. ONLY USE A TOYOTA GENUINE PART. I used a autozone filter and it failed in a week.
  8. Jan 30, 2010 at 5:34 PM
    lensal
    lensal New Member
    len
    jax,florida
    97 tacoma 2x2 2.4l 5spd
    i'm glad i found u guys. 3 hrs ago spoke to a service advisor who then asked his 20yr toyota master tech about my 97 2rz fuel filter. he said it's a non serviceable part, and that the whole fuel line would have to be removed. unbelievable. i wonder if it's ever been changed?!
  9. Jan 30, 2010 at 5:36 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    Your service advisor is partially correct, the fuel filter is a non-service item, but that doesn't mean you can't change it out.
  10. Jan 30, 2010 at 6:51 PM
    lensal
    lensal New Member
    len
    jax,florida
    thanks for a quick reply. my search was prompted by looking for answers from my post of last night:
    "As soon as I filled up (10 gal)my '97 2.4L, I've gotten progressively worsening hard detonation, loss of power, no stalling, but shaking. only driven about 10 miles. Can't go faster than 25 fearing something's gonna pop. Added red line complete fuel system-no help.Plan on emptying tank, adding new gas, changing spark plugs. Don't know if I got bad/dirty/cheap gas or water mix. Tanker wasn't delivering at the time. Any recommendations would be greatly appreciated-thanks"
    couldn't change out all gas today, added half a tank of 93 octane. no difference.will do major tuneup sunday. can a valve have gotten bent or burned? engine never overheated, but there seems to be is a clanking sound in 1? cylinder when slightly revving in idle or accelerating in 1st or 2nd gear. if tuneup doesn't help, should compression tests be done? what else can i do??? i can't believe all this because of gas! sorry for the long post
