fuel filter replacement tips
Discussion in 'New Members' started by Footpeg, Jan 3, 2011.
  1. Jan 3, 2011 at 12:37 PM
    Footpeg
    Footpeg [OP] New Member
    Tucson
    Tacoma
    do you need to bleed off fuel pressure
  2. Jan 3, 2011 at 12:44 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    yes, but all that involved is taking off the fuel filler cap.
  3. Jan 3, 2011 at 12:53 PM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    I never bleed them but it's a good idea so you don't get gas all over you. Another thing that's good to do is when you've put the new one on but before cranking the engine, do the following three times:
    Turn Key to On
    Wait Three Seconds
    Turn Key to Off
    Each time you turn the key to on, the fuel pump sends gas to the injectors for two seconds. By doing this three times, you'll refill the fuel line that you emptied replacing the filter. It helps to save the starter from cranking longer than it needs to and likewise prevents it from building up too much heat.
