Fuel filter replacement
Discussion in 'Technical Chat' started by Bambigular, Feb 9, 2009.
  1. Feb 9, 2009 at 6:50 PM
    Bambigular
    Bambigular [OP] Well-Known Member
    Corona, Ca
    04 Double Cab SR5
    I have a 04 DC V6, I know where the fuel filter is, but where do you disconnect the wire to feed the fuel to the motor. In my past car it was under the passenger seat. Any info will be appreciated.
  2. Feb 9, 2009 at 6:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    If your trying to de preserize the fuel line, you can pull the EFI fuse and crank the engine over a few times.
  3. Feb 9, 2009 at 7:00 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    what chris said.................................but when i do mine.........i dont ever de-pressurize mine................just undo the lines where they are "clamped" onto the frame, then undo the nuts............then pull. there isnt alot of gas that comes out, but de-pressurizing may be a good idea.
  4. Feb 9, 2009 at 7:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    being as I most always have a lit cigar nearby, I have become a fan of depresurizing fuel lines. :anonymous:
  5. Feb 9, 2009 at 7:05 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    definitely a good idea for you then brotha!!:D
    i usually smoke after i have the filter changed....................but i wash my hands since i have gas all over them. made that mistake before with hairspray!:eek:
  6. Feb 9, 2009 at 7:16 PM
    Bambigular
    Corona, Ca
    04 Double Cab SR5
    Thanks for all the info guys but chris4x4 you must have missed the myth buster show when they busted the myth about a cigarette or cigar lighting fuel:D
  7. Feb 9, 2009 at 7:17 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i must have missed that one too.................but i dont wanna try............my luck=shit would blow up/burn down!!:D
  8. Feb 9, 2009 at 7:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Weather or not it ignites, I dont want to be on the receiveing end of a bad desision. ;)
  9. Feb 9, 2009 at 8:31 PM
    Bambigular
    Corona, Ca
    04 Double Cab SR5
    After you pull the EFI fuse does it throw any codes up for disconnecting the fuse?
  10. Feb 9, 2009 at 8:36 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    nope..Just dosent start. I do it all the time at work when i change fuel filters. Just dont forget to put it back in when your done.
    I usually cycle the key a few times to get the fuel pump to get fuel into the lines again.
  11. Feb 9, 2009 at 8:42 PM
    PatHLC128
    PatHLC128 College.
    Pat
    Austin, TX
    09 TRD Off Road 4x4 AC
    OME complete 3" kit, 265/75/16 Cooper STTs, Pro Comp 7089 wheels, Shrockworks sliders, UWS Low Pro Toolbox, AFE Pro-Dry S, OEM Bedmat, Ventvisors, Husky Liners, Tint, De-badged
    when i replaced my fuel filter on my 02 4runner i just undid the gas cap before i started. it worked fine.
  12. Feb 9, 2009 at 9:11 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    i think if you read the Chiltons, they recommend doing both.
  13. Feb 9, 2009 at 9:14 PM
    Bambigular
    Corona, Ca
    04 Double Cab SR5
    That's great info! especially cuz I'm new to the Tacoma world.
  14. Feb 9, 2009 at 9:18 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    well..guess its on my to-do list. Dang, i spent all my money on driving lights and beer. lol
  15. Feb 9, 2009 at 10:12 PM
    jwscoot
    jwscoot Well-Known Member
    Mississauga, ON
    98 Tacoma v6 4x4
    Bilstein 5100 shocks all the way around, add a leaf in the rear
    Correct me if I'm wrong... the EFI fuse controls the injectors... I didn't think it also controled the fuel pump?... I thought if you pulled that fuse, the injectors would not cycle the fuel pump would run and you'd reach the max operating presure of the FPR...
    I've always been told to disconnect the pump, start engine and let die to release the presure.
    Can somebody let me know I'm wrong or right?
  16. Feb 10, 2009 at 6:18 AM
    jwscoot
    Mississauga, ON
    98 Tacoma v6 4x4
    Anyone?
    Just seems even if it disconnected the power to the pump and the injectors then cranking it like that would do nothing to relieve the presure.
  17. Feb 10, 2009 at 6:23 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You would think that it would do that, but it allows the injectors to de presurize.
  18. Feb 10, 2009 at 8:12 AM
    jwscoot
    Mississauga, ON
    98 Tacoma v6 4x4
    I'm not saying your wrong.. but any idea how?
    this has been on my mind all night.
  19. Feb 10, 2009 at 3:28 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2003 Tacoma Dbl Cab 4X4
    Just a quick question guys, I've got 66,000 on my '03 Dbl Cab, should I change mine, i'ts never been done..... How often should you change them?
  20. Feb 10, 2009 at 3:32 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Breaks, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    I change mine every other year. Twice in a leap year
