Fuel filter replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Matmo215, Jun 13, 2017.
  1. Jun 13, 2017 at 10:15 AM
    Matmo215
    Matmo215 [OP] Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    I have researched for a while and come to no definite conclusion, how often do you replace your fuel filter?
    I feel like it may need to be replaced along with other things. My truck has 102k miles and feels sluggish and loses some power going up big hills. If not the fuel filter, what else could it be?
  2. Jun 13, 2017 at 10:22 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Powerloss could but many items I'm not a mechanic so I will let someone with more experience weigh in on that. How ever the fuel filter on these trucks is located on the fuel pump inside of the fuel tank, it's just a small sock filter over the pump. Very possible it could be replaced but I don't know of anyone that sells just a replacement sock, usually they want you to buy the whole fuel pump assembly.
  3. Jun 13, 2017 at 11:11 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Could be many things causing your truck to feel sluggish going up big hills:
    weak/bad fuel pump not providing enough fuel when engine demands high power
    steep hill in wrong gear
    too much unnecessary weight in truck
    oversize tires without a regear
    sudden headwind, etc etc.
    Why do you suspect the fuel filter right away?
    To my knowledge, there is no recommended schedule for replacing the fuel filter on the 2nd gens. Some people have installed aftermarket fuel filters inline but they are few.
  4. Jun 13, 2017 at 11:16 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Not sure about 2nd gens, but 1st gen V6's have a very accessible fuel filter so it's a cheap and easy DIY way to at least rule one thing out, if not solve the problem.
    At 102k miles, have you done a tune up yet? New plugs might be in order if they haven't been replaced yet.
  5. Jun 13, 2017 at 11:16 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    30k is a good interval. That was a tough find, looking through the Hilux intervals.
    Do the www.urdusa.com fuel pump upgrade. Then you can change the Napa filter for roughly $15.
    Changing your filter will make you regain lost engine power. You'll be quite impressed with how noticeable the change is. Quite.
  6. Jun 13, 2017 at 12:57 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    wow really 30k miles??!? What affects would one see on a NA'd motor with the URD fuel pump? http://urdusa.com/store/Fuel-Upgrad...uel-Pump/Filter-Upgrade-Kit/product_info.html
    any decrease in gas mileage etc?
    Also what would be wrong with pulling the filter on the stock pump and putting an inline one after the pump?
  7. Jun 13, 2017 at 1:14 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Fuel pump won't increase or decrease fuel mileage. Just supplies more fuel before reaching max duty cycle. High mileage pumps have less brush material. So it is basically just replace it because you're there.
    Nothing is wrong with the scenario you presented. You just need the parts to reinstall the OEM pump similar to the aftermarket pump. Then you again have a replaceable fuel filter.
    Hilux's have a replaceable fuel filter in the engine bay.
  8. Jun 13, 2017 at 2:33 PM
    Matmo215
    Matthew
    Waco, TX
    2015 Sport DCSB
    Well my i think the fuel pump because i dont have any extra weight, 265 tires, automatic trans
  9. Jun 13, 2017 at 5:26 PM
    henrilepuf
    henrilepuf Well-Known Member
    henri
    Northwestern Paraguay
    tacoma 2014 4x4 DCLB
    If you won't change the whole fuel pump assembly, you can replace only the Denso pump inside.
    It's cheaper.
    A new filter come with the new Denso.
    I 've had to replace it 4 times on my truck (115 k miles) because the very bad quality of gas in the country.
    Hope it helps.
  10. Jun 13, 2017 at 5:28 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Link of what you said, with filter?
  11. Jun 13, 2017 at 5:42 PM
    henrilepuf
    henri
    Yes, with filter.
    When you buy the Denso pump, it comes with the filter
  12. Jun 13, 2017 at 5:45 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I have a very high % belief that you're referring to the sock.
  13. Jun 13, 2017 at 5:47 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Sock protects the pump. Filter protects the injectors.
    Sock is attached to the inlet of the pump.
  14. Jun 13, 2017 at 5:55 PM
    henrilepuf
    henri
    You're right.
    The sock/filter is attached to the pump, and protects the pump.
    please let me know where is the filter which protects the injectors.
  15. Jun 13, 2017 at 6:19 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The factory filter has a socket, which the OEM pump fits into. It clips onto thw "bucket". Which everything fits inside of.
  16. Jun 14, 2017 at 3:33 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    What Torspd said. There is no traditional fuel filter on a Tacoma. They are considered to last the life of the truck. Because it's in the tank it's considered self cleaning. 2nd gen tacomas have a plastic tank, not metal. Older tanks rusted and needed to have the debris cleaned out by a traditional filter. The only things getting in the tank would be through the fuel from the station, and that's not a big issue in the states.
  17. Jun 14, 2017 at 5:51 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    never changed a fuel filter in past 30 years on my Toyotas
    88 toy 4x4 2.4 180k
    89 taco 2.7 170k
    2005 sienna 205k
    09 taco 4.0 171k
    no fuel filters on any of them changed
  18. Jun 14, 2017 at 8:05 AM
    nd4spdbh
    SoCal
    gotcha. Arent the fuel pumps running "full speed" at all times and the FPR regulates how much fuel pressure there is? Or is it some sort of PWM signal to the pump power?
  19. Jun 14, 2017 at 8:12 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Low and high demands. The FPR regulates the pressure always, regardless of pump demand.
    Some people never brush their teeth either. Lol. Others prefer to never change their oil...
  20. Jun 14, 2017 at 10:21 AM
    glk21c
    glk21c Well-Known Member
    MD
    2007 Silver Tacoma TRD Sport 4x4
    yes, exactly. got mine from RockAuto when my fuel pump went bad
