Fuel Filter replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Paulrv6, Dec 22, 2017.
  1. Dec 22, 2017 at 9:07 AM
    Paulrv6
    Paulrv6 [OP] Well-Known Member
    paul
    2005 Tacoma
    I have a 2005 with 45000 miles and the fuel filter hasn't been changed. Because of the low miles I wasn't considering changing it. The question is should I change it out or leave it go for a while?
    No problems with fuel starvation.
    If required, are there any special tools required to change it and what is the best brand?
    Merry Christmas
    paul
  2. Dec 22, 2017 at 9:42 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    If it aint broke, don't fix it. The fuel filter isn't a regular maintenance deal.
  3. Dec 22, 2017 at 9:46 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Norton and Torspd like this.
  4. Dec 22, 2017 at 10:12 AM
    Paulrv6
    paul
    2005 Tacoma
    Very good. I was just thinking it was an external filter like my older cars. Guess I should not assume. I will leave it go. Thanks for the reply.
    Paul
    NAAC3TACO likes this.
  5. Dec 22, 2017 at 10:50 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    my 99 taco had over 160 miles and never changed the fuel filter
    never changed it on the others I have owned either
    2005 sienna with 208k
    2009 taco with 182k my DD
  6. Dec 22, 2017 at 2:45 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Your engines have disdain towards you. ^^^^ lol.
    Just because YOU don't, is not a prescription for others not to.
    inwood customs and Norton like this.
