Fuel filter replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by vettehigh, Jan 19, 2018.
  1. Jan 19, 2018 at 6:52 AM
    vettehigh
    vettehigh [OP] Tacoma Tank
    Jon
    Upstate, NY
    1995 4x4 V6 Auto
    Just bought a fuel filter for my Tacoma and this is what it looks like? How and where does it go? Thanks
  2. Jan 19, 2018 at 6:56 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    That looks like a sock that possibly goes into the fuel tank. Fuel Filter on my 98 is in-line with the fuel line under the driver side, along the frame.
    wilcam47, Sicyota04 and jammer like this.
  3. Jan 19, 2018 at 6:59 AM
    vettehigh
    Jon
    Upstate, NY
    I thought it was a can looking filter that I needed, this is the only fuel filter for my VIN#
  4. Jan 19, 2018 at 7:07 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  5. Jan 19, 2018 at 7:13 AM
    Timmah!
    Timmah! Well-Known Member
    TIM
    You definitely have a canister filter along the driver side frame rail. The video below is for a 3rd Gen 4runner but it will work for Tacomas too. The only difference is how you disconnect the power to the fuel pump. You don't have an access hatch above the fuel pump like the 4runner has. If you want to disconnect the power to the fuel pump and run the engine to depressurize the fuel lines, you'll have to reach up on top of the gas tank from under the truck. I've looked at a buddy's truck and it's doable to get you hand up there to disconnect it. If it ends up being too much of a hassle, you can always try breaking the lines free without depressurizing the lines. I've done it before so I know it works.
    Edit: Anthony above beat me too it.
    https://www.youtube.com/embed/vdDhXZIs6Lo
    Area51Runner, Dalandser and jammer like this.
  6. Jan 19, 2018 at 7:14 AM
    vettehigh
    Jon
    Upstate, NY
  7. Jan 19, 2018 at 8:11 AM
    tony2018
    tony2018 Well-Known Member
    Dammit....need to get to mine..
  8. Jan 19, 2018 at 8:43 AM
    skeezix
    skeezix Ol' Geezer
    Western Slope of Colorado
    1998 Limited
    A fuel filter from Toyota cost around $36 and typically are good for around 50K miles. You get what you pay for (if you are lucky). For $7 I wouldn't bother.
  9. Jan 19, 2018 at 8:51 AM
    vettehigh
    Jon
    Upstate, NY
    I can get a Bosch, any good?
    https://www.napaonline.com/en/p/ATM71642
  10. Jan 19, 2018 at 8:58 AM
    skeezix
    skeezix Ol' Geezer
    1998 Limited
    Sorry, I don't know.
    The price of a fuel filter from Toyota is high, I know. Sounds to me like you probably don't drive very often where only fools dare to go, and Bosch is well-known in Germany for quality.
  11. Jan 19, 2018 at 9:13 AM
    vettehigh
    Jon
    Upstate, NY
    Just called local dealer, getting that (OEM Toyota) instead for $40. Thanks all
    Now I need to find the size/thread of the 2 bolts/nuts so I can get stainless steel ones today
    Dalandser likes this.
  12. Jan 19, 2018 at 11:21 AM
    vettehigh
    Jon
    Upstate, NY
    I found the part number for the nuts (2) for the bracket and it's #90179-06161. Any way to find out the nut size so I can go to the hardware shop?
  13. Jan 20, 2018 at 5:17 AM
    ROCKIN RICHIE
    ROCKIN RICHIE Well-Known Member
    BEAN TOWN
    02'TACO
    My gas tank rotted out so I got to see inside tank at 170,000 miles. Sock in first pic was spotless and I change fuel filter about every 50,000. Toyota does not give an interval for filter change out as they believe it is a life time thing. Perhaps with newer style ( last 25 years ) fiberglass underground storage tanks and better pump maintenance by the majors bad fuel is really a myth? Rust in fuel was a real issue years ago but not so much now?
  14. Jan 20, 2018 at 7:21 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Ethanol causes all kinds of Rust .
    I change my filter every spring.
    Not so much for performance but so I can get it off
  15. Jan 20, 2018 at 9:06 AM
    labrador01
    labrador01 Well-Known Member
    Kyle
    Northern IL
    2015 Tacoma
    ordered myself a fuel filter today, hasn't been done in at least 2 years / 50k...I'm sure longer than that.
  16. Jan 20, 2018 at 9:49 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    is it a tacoma?
  17. Jan 20, 2018 at 9:50 AM
    wilcam47
    Will
    Bourbon state
  18. Jan 20, 2018 at 2:50 PM
    vettehigh
    Jon
    Upstate, NY
    Just got the truck back, OEM filter was original (1995 with 206k) and replaced with OEM:thumbsup:
