Fuel Filter
Discussion in '1st Gen. Tacomas (1995-2004)' started by saweetlou, Dec 11, 2010.
  1. Dec 11, 2010 at 6:24 AM
    saweetlou
    saweetlou [OP] Well-Known Member
    Guelph Ontario
    TRD Stepside
    2in Skyjacker
    Not my Taco but the Wife's 4runner, I dont think the fuel filter has ever been changed and I know it wont be easy, so Im looking for some tips of any kind to get the lines loose cause guaranteed something will get fudged up.
  2. Dec 11, 2010 at 6:32 AM
    tacotopher
    tacotopher Well-Known Member
    Memphis
    Zombie TRD OR
    Grey wire mod, 5100's on all four corners, AAL in the rear, deckplate mod,
    I've changed the fuel filter out on my bro in laws 4runner. Its fairly easy. I'm not sure what size wrenches you need, but you need two on each side of the filter to undo the metal lines. You may have to bend them slightly to remove the filter once you have undone the lines, and loosened the clamp that wraps around the filter and holds it to the frame. Be prepared to get a good bit of gas on your hands, arms, and shoulders lol. Hope this helps out some! :)
  3. Dec 11, 2010 at 6:36 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Relieve the fuel system pressure by first placing a container under the fuel filter. Slowly loosen a joint with the correct size wrench and a backup wrench, if necessary. Let the fuel from the fuel line slowly empty into the container. Once it all runs out, you can fully disconnect the joint.
    Disconnect the negative battery cable. Locate the fuel filter in the engine compartment at the inlet line to the fuel rail. Remove the filter inlet and outlet lines and plug them to prevent any remaining fuel from leaking out, or dirt from entering the system.
    Take out the fuel filter and remove it from the bracket. Place the new fuel filter in the bracket. Install the filter in the vehicle and tighten the bolts to 14 ft-lbs. Install new gaskets and tighten the union bolts to 22 ft-lbs.
    Re connect battery, start vehicle and check for leaks.
    Read more: How to Replace a Fuel Filter in a Toyota Tacoma | eHow.com http://www.ehow.com/how_4507492_replace-fuel-filter-toyota-tacoma.html#ixzz17oWPX9kZ
  4. Dec 11, 2010 at 6:44 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Good to know, I've gotta do this too
  5. Dec 11, 2010 at 8:27 AM
    ScootsOFP
    ScootsOFP Well-Known Member
    Scoot
    Wisconsin
    03 PreRunner SR5/TRD
    deckplate, white LED gauges, fog light mod (Beau02 write up), Scion t1814 head unit
  6. Dec 11, 2010 at 8:53 AM
    saweetlou
    Guelph Ontario
    TRD Stepside
    2in Skyjacker
    Oh sorry Guys I should have been more specific, its the one under the truck along the frame( I forgot about the one under the hood, Thanks for that) and it looks pretty rusted and all gummed up, thats why im worried about breaking the line.
  7. Dec 11, 2010 at 9:35 AM
    tiger955
    tiger955 Well-Known Member
    Carson City
    06 Access 4WD
    trd suspension
    If you don't have good line wrenches in the proper size to keep from rounding off the fittings, it might be worth it to pay a garage to do it for ya. The fittings on the lines are usually real tight and very soft and round off easily. They shouldn't charge more than 1/2 hour labor.
  8. Dec 11, 2010 at 11:04 AM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    What Chris said...and to add you can also depressurize the fuel system by removing the fuel filler cap...This will relieve any pressure built up in the tank...Disconnect the fuel pump harness connector or even easier pull the EFI fuse and crank over the engine for 2-3 secs...
  9. Dec 11, 2010 at 11:27 AM
    saweetlou
    Guelph Ontario
    TRD Stepside
    2in Skyjacker
  10. Dec 11, 2010 at 5:30 PM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    i did this a couple weeks ago...took like 20 mins max
    pulled the EFI fuse...started the truck, let it die out (this removes the built up fuel pressure)
    get under the truck and loosen the nuts (you don't need flare nut wrenches)
    it helps to pull the hardlines out of the holders....just gently pull the lines out of the filter and go from there
  11. Dec 12, 2010 at 11:10 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Currently under the knife for turbocharger..
    The one on the frame is for the V6, the one under the intake manifold is 4cyl...FYI.
