Fuel filter
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Redsoxnation, May 25, 2012.
  1. May 25, 2012 at 4:59 AM
    Redsoxnation
    Redsoxnation [OP] Well-Known Member
    Pa.
    PreRunner TRD 4X4 Impulse Red
    none yet...
    Ok this may sound like a silly question. BUT! is there and inline fuel filter on 2006 tacoma's? None of the maintance scheds show replacing it.. if there is one where is it located? Thanks
  2. May 25, 2012 at 5:03 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    No inline filter. The filters in the fuel tank.
  3. May 25, 2012 at 5:12 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    ^^^ Correct
  4. May 25, 2012 at 5:13 AM
    Redsoxnation
    Pa.
    none yet...
    Ok thanks
  5. May 25, 2012 at 5:57 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    And...unless you have proof that you have lower or intermittent fuel pressure due to a clogged filter, there is no need to replace it...ever.
  6. May 25, 2012 at 10:33 AM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    wow! what about if you had 300k miles? i can only imagine the sludge in it by then
  7. May 25, 2012 at 10:39 AM
    Maticuno
    2011 Suburban 2500
    Where would this "sludge" be coming from? It is refined through filters, it is filtered as it is pumped into your vehicle. Unless you routinely fuel up out of rusty 55 gallon drums in Nigeria, then there should be no harmful particles floating around in your fuel tank.
  8. May 25, 2012 at 11:05 AM
    Taco Dan
    Dan
    Tuscaloosa, AL
    you would be surprised what is still in gasoline from any gas station. ive changed an inline filter on a 2007 f150 and i turned the filter the opposite direction of gas flow and black deposits came out.
  9. May 25, 2012 at 11:08 AM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    Hook it up backwards its called the f150 tune up:rolleyes:
  10. May 25, 2012 at 11:12 AM
    Taco Dan
    Dan
    Tuscaloosa, AL
    :rimshot:
  11. May 25, 2012 at 11:16 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Stop buying your gas from the local moonshiner ;)
  12. May 25, 2012 at 11:25 AM
    Taco Dan
    Dan
    Tuscaloosa, AL
    you should see a diesel filter after 100k
  13. May 25, 2012 at 11:31 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I used to change mine at 12k.
  14. May 25, 2012 at 11:37 AM
    Taco Dan
    Dan
    Tuscaloosa, AL
    yep my friends weren't so good to their trucks.
    my point is that there are still small suspended solids in gasoline, even after the filter at the pump, that's why there is a fuel filter in vehicles
  15. May 25, 2012 at 12:15 PM
    knucklehead
    knucklehead Well-Known Member
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    Most of the crap that gets into and plugs up fuel filters is actually created out of the deterioration of the steel fuel tank. These trucks have plastic tanks, which means that all debris has to be added in with the fuel. In other words, there is really nothing to worry about.
  16. May 25, 2012 at 12:32 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Seriously... it's nothing to worry about.
    I put over 200k on my '94 on the factory fuel filter.
    Modern fuel tanks are plastic, so you aren't even going to get rust, which is what fouled fuel filters in the "bad old days"
    To change the internal filter usually requires a new fuel pump... and in all seriousness, your fuel pump is likely to fail long before the "sock" ever plugs.
  17. May 25, 2012 at 4:04 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    The fuel filter is actually located in the fuel pump assembly, you can take it out but Toyota doesn't sell it separately. You have to buy the whole assembly for $500.
  18. May 25, 2012 at 5:39 PM
    BlazeTaco
    BlazeTaco Well-Known Member
    PA
    4.0l 6sp SR5
    TRD Exhaust TRD Filter
    Remember nowadays your suppose to spend 500 dollars to replace the fuel pump instead of 20 dollars for a new filter so Corporate can save 10 cents a vehicle for not putting a inline filter in at assembly.
  19. May 25, 2012 at 6:11 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
  20. May 25, 2012 at 6:28 PM
    Asgard
    The Tacoma's fuel filter is actually in the white plastic fuel pump assembly, not a rust proof metal container. I don't think we have that one talked about in the article. You can unclip the plastic housing and pull out the filter.
