Fuel Filter
Discussion in '1st Gen. Tacomas (1995-2004)' started by robertcorda, Jun 17, 2013.
  1. Jun 17, 2013 at 10:23 AM
    robertcorda
    robertcorda [OP] Member
    Rob
    Sonoma
    04 Tacoma xcab 2wd
    None
    I have a question about fuel filters. The fuel filter does not seem to be a scheduled service item and I did some research and found that Toyota engineers designed the fuel filter with such high efficiency and that most gas is quite clean that the fuel filter does not need to be replaced. Any thoughts?
  2. Jun 17, 2013 at 10:49 AM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    Replace it anyway. They do get dirty inside and can cause hard starting and other problems.
  3. Jun 17, 2013 at 10:51 AM
    Large
    Large Red
    I'd change it at 50k intervals anyway.
  4. Jun 17, 2013 at 10:53 AM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    And take your time doing it so you don't ruin the mounting bracket. SMH... things I know now I didn't know then.
  5. Jun 17, 2013 at 10:57 AM
    WHPLSH3
    WHPLSH3 Fortified with horsepower-adding goodness...
    Vance
    Alberta
    Supercharged Spruce Mica 6spd 4x4
    Build thread coming soon!
    Replacing a fuel filter every 15,000 miles is what most manufacturers recommend. Never hurts- lets the fuel pump last the life of the vehicle that way:)
  6. Jul 2, 2013 at 3:10 PM
    ManofSteel1
    ManofSteel1 Well-Known Member
    Stock
    Where is the fuel filter located?
  7. Jul 2, 2013 at 3:30 PM
    Madjik_Man
    Colorado Front Range
    driver's side, just below the door, on the inside of the frame
  8. Jul 2, 2013 at 3:56 PM
    YOTA LOVER
    NH
    Lucky SOBs!!! It was tucked under the intake manifold on the 95.5... Ball buster to change!
  9. Jul 2, 2013 at 4:11 PM
    EDJY
    EDJY Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    I randomly found a fuel filter for my old 89 4 runner. Examined my 01 fuel filter and realized it was exactly the same so I figured I would swap it out. Pulled the old one out and dumped it out from the in side. The fuel that came out of the filter was the gnarliest fuel I have ever seen it looked brown/green, with shit floating around in it. I'm guessing I was the first one to change it (around 270k). Felt no performance difference, but I was sure glad I had a clean one!
  10. Jul 2, 2013 at 4:30 PM
    Larrys 02 Tacoma
    Larrys 02 Tacoma Member
    Lawrence
    Santa Maria, CA
    02 Prerunner Stnd Cab
    On the 4cyl models the fuel filter is under the intake manifold. Non OE repair maunels suggest changing fuel filter every 60,000. Just did the one on my 2.7 at 127,000, had been done once before (had a Chinese replacement that removed). I cut it open and undid the paper element and it was pretty dirty, more so than I expected. Changing one on the 4cyl engines is a challenge.
  11. Jul 2, 2013 at 5:14 PM
    YOTA LOVER
    NH
    Terrible placement IMO.
  12. Jul 2, 2013 at 6:55 PM
    ManofSteel1
    Stock
    Never noticed it there. Thanks.
  13. Jul 2, 2013 at 7:03 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    That's on the 3.4L V6
  14. Jul 2, 2013 at 7:23 PM
    Madjik_Man
    Correct.
    The guy who asked the question doesn't specify what motor he has. So I put mine :notsure:
  15. Jul 2, 2013 at 7:24 PM
    Shotshell
    Shotshell Member
    Rocky Mountains
    '03 4-Door V-6 4x4
    4" ProComp Lift, K&N Cold Air, Roof Rack, Camper Top, Custom Storage System, Brush Guard, 33" BFG A/T's.
    I change it every spring in my '03, irregardless of mileage driven. They're fairly cheap. And with today's crappy ethanol infested fuels, it's a good idea. IMO.
    My truck starts telling me when she needs a new one. She starts running weird, and I know it's time to replace (usually in the spring, around May-ish, for me.) So what I'm saying is, pick a month, and change it every year in that month, just to keep things simple.
  16. Jul 2, 2013 at 7:26 PM
    YOTA LOVER
    NH
    Agreed, but I would use a mileage based number ( miles driven = amount fuel put in). Either way, change it more often :D
  17. Jul 2, 2013 at 7:28 PM
    facemob
    facemob Well-Known Member
    Chase
    1st state
    03 V6 Manual, TRD
    OME 881, Nitrochargers front and rear, diff drop, Wheelers 3 Leaf AAL, Supertop, shitty brush guard and a hole in the muffler
    As EDJY also pointed out, the fuel that will come out of the inlet side when you change it is going to be super dirty. Do it. and be careful with the lines that run to it, not much wiggle room.
  18. Jul 2, 2013 at 11:47 PM
    Janster
    Jandy
    Lancaster, PA
    FWIW, If you disconnect the brackets that hold the line to the underside of the body, makes it much easier to get the filter out/in.
  19. Sep 11, 2013 at 6:22 PM
    mc3404
    mc3404 Well-Known Member
    Concord ,NC
    03 v6 tacoma
    Anyone notice a problem using an afternarket fuel filter on the 3.4? It seems as if mine started thumping after i put an aftermarket fuel filter on it. Today after further examination it sounds like the thumping that most cant figure what it is is actually coming from the fuel rail? Is this just me?
  20. Sep 11, 2013 at 6:43 PM
    Madjik_Man
    I've had no problem with the WIX filter I put in about 5,000 miles ago
