Fuel filter?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bkusterer, Sep 1, 2016.
  1. Sep 3, 2016 at 12:04 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You can drop the tank without removing the bed. Just two straps and some connections.
  2. Sep 3, 2016 at 12:07 PM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    Damn it.
    Like @Torspd said. You gotta drop the tank, drain the gas out, clean it out, and clean out your fuel pump.
    It's good that it died quickly, it's doubtful the sugar made it to your engine. It's most likely plugged up your fuel pump and your engine is starving for gas.
    You catch the SOB that did this?
  3. Sep 3, 2016 at 12:15 PM
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    you cant replace only the pump on these trucks its the whole assembly and its not cheap
  4. Sep 3, 2016 at 12:22 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Aftermarket upgrade. Nets you an external filter which is replaceable for ~$10.
    Maybe they did you a favor. ;)
  5. Sep 3, 2016 at 12:25 PM
    Bkusterer
    Bkusterer [OP] Member
    2014 tacoma
    Not yet but I will. Chicken shit sob. Back in my day we used to settle shit with a little fist to fist.
  6. Sep 3, 2016 at 1:54 PM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    What initiated him to do this?
  7. Sep 3, 2016 at 5:24 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    You might be fucked. Soda pop doesn't clog a fuel filter. It's a liquid. We are getting confused with the whole 'white sugar' thing.
    Drain the tank and fill it with fresh high octane and crank away until fresh gas hits the motor.
    Does the motor still crank? If not, you may have a bigger issue.
    Torspd likes this.
  8. Sep 4, 2016 at 5:56 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    Before you drop the tank, the sugar is dissolved in the gas. I would put a few bottles of dry gas in the tank, the dry gas will absorb the liquid and it will burn, Its like having a little water from condensation. I am not disagreeing with the guys I would just try the dry gas first. please keep us informed good luck
  9. Sep 4, 2016 at 6:59 AM
    timothom
