fuel filtre finally located!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by undermoneyed, Apr 11, 2012.
  1. Apr 11, 2012 at 7:50 PM
    undermoneyed
    undermoneyed [OP] aka Alley Opp,
    Mark
    B.C., Canada
    Tacoma TRD
    totally stock
    The fuel filtre is part of the fuel pump module located on top of the gas tank. It is in Haynes Repair Manual p 4-3, just not listed in the index. [​IMG]
    Mark
  2. Apr 12, 2012 at 7:55 PM
    JKD
    JKD Well-Known Member
    Modern fuel filters are designed to last for hundreds of thousands of miles. Many hundreds of thousands.
    I have it on my list of things to check at 500,000 miles, and I'll replace it even if it's not clogged at 1,000,000 miles.
    Unless you pumped mud into your gas tank, it's just not going to need to be replaced, ever, on almost any vehicle.
  3. Apr 12, 2012 at 8:39 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
  4. Apr 12, 2012 at 8:48 PM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    how does the filter stay clean?
  5. Apr 12, 2012 at 8:49 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    It's still " filter "
  6. Apr 12, 2012 at 8:52 PM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '12 DCSB 4x4 SR5
    :frusty::anonymous:
  7. Apr 19, 2012 at 9:42 PM
    undermoneyed
    Mark
    B.C., Canada
    Tacoma TRD
    totally stock
    Thanks JKD, I'll probably change mine at a million as well but it will probably kilometres. I checked with Toyota and they want $700.0 for the fuel pump/filtre module, so much for the idea of carrying a spare.
    Peter, it gives me great pleasure to spell filtre!
    Mark
