Fuel Gauge Issues...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MGCPNGN7, Mar 16, 2016.
  1. Apr 9, 2016 at 6:34 AM
    #141
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Just came across this thread, and immediately thought ofnsomething like this. I use an instrument at work for measuring water quality, looks like a wand with a cord that you drop into a river/creek/pond/etc. It provides a depth measurement based on water column pressure as compared to atmospheric pressure. It is very accurate.
  2. Apr 9, 2016 at 10:58 AM
    #142
    robertbank
    robertbank Well-Known Member
    Bob
    Terrace, BC
    Ordered TRD Sports DCLB Upgrade Pkg
    Sheech, yet another first world problem. How do we ever get through the day.
    Bob
    PROseur, BlkTaco47 and "OldManTan" like this.
  3. May 31, 2016 at 9:37 PM
    #143
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    yep i have a little over 2 gal when it hits zero and yes that means that it have OVER 4 gal when the low light comes on (not 2 to 2 1/2 ) like they say . i have only 2200 miles so far but it would be nice if they could get it close to 1 gal (say 20 miles or so )when you hit zero . as i just want to know, because, some times i want to fill up where it is .10 to .15 cents per gal cheaper now when i see the dash light i can blow it off for 60 miles if i have to . but i try to fill up when i hit the last 1/4.
    if Toyota thinks they are making it Safer for us it is like the dumb shits that set there clocks off 10 to 15 min because they forget there late.... I'm going to bend the float wire and "fix" it....
  4. Jun 1, 2016 at 5:09 AM
    #144
    manofsteele2003
    manofsteele2003 Well-Known Member
    2016 Blazing Blue TRD Sport Double Cab
    17" TRD wheels w/265/70/17 BFG KO2s, Weathertech mud flaps, Gecko LED bed lights, more to come.
    I think every Toyota I've owned has been this way, the first and last 1/4 is more like 1/8. Not sure what the big deal is though, when it says E fill it up.
  5. Jun 1, 2016 at 7:31 AM
    #145
    robertbank
    Bob
    Terrace, BC
    Way to easy. Do that and you have nothing to bitch about.
    PROseur likes this.
  6. Jun 1, 2016 at 9:18 AM
    #146
    DRJ1014
    DRJ1014 Well-Known Member
    CA
    Only read the first couple of posts, so here we goooo...
    You have to also take into account temperature. Gas expands just like anything else with higher and lower temps. Also, unless you are taking the exact same route every day, the change in throttle for the first 1/4 of a tank will be different from the previous 1/4 of a tank.
    As long as you are getting roughly the same miles per tank, whats there to worry about? The only way to get an accurate reading is to put the truck on a dyno and run the truck to get accurate mileage readings per each section of the tank needle.
    You cant honestly say you are driving the same route, filling up at the same point each time, giving the same throttle through your 2000 miles of driving. You may say you are but its just not humanly possible.
  7. Jun 1, 2016 at 12:40 PM
    #147
    robertbank
    Bob
    Terrace, BC
    For the win.
    Bob
  8. Jun 1, 2016 at 2:33 PM
    #148
    bstone4
    bstone4 Active Member
    Mark
    South East Texas
    2016 White TRD Sport
    Wow, this is awesome.
    I have noticed this with all my fuel gauges. The only difference between my Taco and my old Chevy is when the Taco say its at a half tank the needle doesn't bounce when I accelerate or brake. My chevy, after about the 3quarter mark that needle danced all over the place. Under heavy acceleration I had a full tank, under heavy braking I had an empty tank lol
    I've found just like someone mentioned earlier its just much easier to mark it and reset the Trip A/B. That's what I've been doing since my old Chevy. I marked it at 275 and every round about 275 miles I pumped gas. 275 is what I considered empty.
    Now on the Taco, I use the range meter and I pump gas around 80 miles to empty. I mean big deal. You need gas, so just pull over and pump, there's really no reason to bitch about it. I know that this isn't a MPG thread but let me leave with this, If you're overly concerned with MPG then get you a Prius or the Volt or Leaf. Who really cares? You bought a truck, shut up pump your gas and do truck stuff.
    Thelgord likes this.
  9. Jun 1, 2016 at 8:44 PM
    #149
    robertbank
    Bob
    Terrace, BC
    2nd place but a strong 2nd. Kinda the Silver Medal if anyone watched the World Hockey Tournament......Canada won Gold :>)...again.
  10. Jun 2, 2016 at 8:57 AM
    #150
    DRJ1014
    CA
    Canada will always win gold lol. Some of our top players on the Ducks are from Canada.
  11. Jun 9, 2019 at 9:23 AM
    #151
    MEANGREEN17
    MEANGREEN17 Member
    DFW
    2017 Silver Tacoma SR5
    Hello all,
    I own a 2017 SR5 and I wanted to ask if anybody had problems with their fuel gauge or for that matter, their fuel pump. I fill up with a quarter left but the digital gauge isn't reading what it used to when I first bought the truck. I usually fill up at a Chevron or Mobil gas station if that matters. Thanks!
  12. Jun 9, 2019 at 1:00 PM
    #152
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    What did it used to read?
  13. Jun 9, 2019 at 1:07 PM
    #153
    TacoRated
    TacoRated Do the chickens have large talons?
    Colorado
    2016 DCSB TRD OR
    High speed, special purpose duct-tape noise cancellation LCAs. Redline Tuning hood struts Hefty Fabworks Rock Sliders Trifold Bed Cover TRD Pro Grille
    The fuel gauge or the distance to empty? Do the 17s have a digital fuel gauge?
  14. Jun 9, 2019 at 3:17 PM
    #154
    MEANGREEN17
    MEANGREEN17 Member
    DFW
    Sorry, distance to empty. Used to read 416, now reads 398.
  15. Jun 9, 2019 at 3:27 PM
    #155
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    Calling In-Situ re: a warranty repair would be a fun time :fistbump:
  16. Jun 9, 2019 at 3:38 PM
    #156
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I'd think distance to empty is based off, multiplying amount of gallons X current MPG average. So if your average MPG drops, so does your DTE. Of course average can fluctuate greatly, winter gas, wind, speed, tire pressure, etc etc.
  17. Jun 9, 2019 at 3:45 PM
    #157
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Usually Vonnegut and Orwell. But now it's WAY off in the rubarbs.
  18. Jun 9, 2019 at 3:53 PM
    #158
    MEANGREEN17
    MEANGREEN17 Member
    DFW
    I really hope this is the case.
    Chew[QUOTED] likes this.
  19. Jun 9, 2019 at 3:56 PM
    #159
    gmiller
    gmiller Member
    G
    Eastern TN
    2019 tacoma trd sport dcsb concrete
    I used to be curious as to why I'd get 75 or so miles on trip A before the needle would come off the right peg...I don't worry about it now.... the wanna-be prepper in me automatically kicks in and I fill up when the gauge nears half way.
    Chew likes this.
  20. Jun 9, 2019 at 4:47 PM
    #160
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    It seems as though the simple solution would be to not make the dash gauge linear, design the tank and float system and then use the actual system to mark E, 1/4, 1/2, 3/4, and full.
