Fuel gauge not working ,no low fuel light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CoopDC, Sep 25, 2013.
  1. Oct 20, 2016 at 7:57 AM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    That's me too, I'm afraid to let the fuel get down that low, I've always wondered if the light works or not.
  2. Feb 28, 2018 at 8:56 AM
    blacksandtaco
    blacksandtaco Well-Known Member
    I realize I'm resurrecting an old thread here but hoping someone can help. On two occasions in the last 6 months I've run out of gas. I know, I should fill up at 1/4 tank to keep the fuel pump from failing prematurely but I'm not as consistent with that practice as I should be.
    The 2 times I've run out of gas my gauge has read 1/8 of a tank and my low fuel warning light did not come on. When I filled the tank back up my truck started just fine and my gauge read full. The gauge itself seems to work just fine until it gets to that 1/8 mark. I have 140k miles on my 07 and I'm sure I've done some damage to my fuel pump running it low like I do but I'm curious whether I should replace the entire pump or if these symptoms could be due to a failed fuel level sensor or fuel sending unit instead since the gauge seems to work at all other levels.
    Don't have the tools or the knowledge to do it myself so probably at the mercy of my mechanic or dealership. Mechanic quoted $970 for fuel pump replacement and labor. Haven't tried the dealership yet. What do you guys think? Replace the entire thing given the mileage or can I save some money by looking at the sensor or sending unit?
    I should add, is there an easy way to tell if the entire pump is failing? Lower power or acceleration and high RPMs?
  3. Feb 28, 2018 at 9:26 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Did you actually run out, or did the pump just not work?
    How many gallons went in to fill it at the 1/8 tank point?
    The tank hold at least 21 gallons (80 liters)
    When at the E line, there is still about 3 gallons usually (ie. takes 18 gallons to fill from there. The light comes on just before, when about 17 gallons is used.
    simontorres38 likes this.
  4. Apr 3, 2018 at 10:24 PM
    simontorres38
    simontorres38 Active Member
    Simon
    2012 Black Tacoma sr5
    Where can I buy a good reliable level risistor? Any links?
  5. Jan 18, 2020 at 4:03 PM
    jtaco11
    jtaco11 Well-Known Member
  6. Jan 18, 2020 at 9:15 PM
    David K
    I always reset the trip odometer when I fill up. If I am near 300 miles, I better be getting gas, no matter what the gauge says!
    Torspd likes this.
  7. Jan 18, 2020 at 9:17 PM
    jtaco11
    Same here i switch to check total miles and forgot switch back to trip was relying on light
  8. Mar 8, 2022 at 8:39 AM
    mark.ferrell
    mark.ferrell New Member
    Mark
    I just started having this same issue, my first mechanical problem in 357,000 miles. My solution - fill up the tank when I get down to 1/8th
    cizko33 likes this.
  9. Mar 21, 2022 at 8:20 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    My daughter's '06 is having the same problem. The sending unit is showing the correct Ohms when the float is manipulated, but the gauge will not go below 1/8 tank. Looks like it's a problem with the gauge in the dash.
  10. Jan 14, 2023 at 4:42 PM
    cizko33
    cizko33 New Member
    same. My truck doesn’t read past 1/8 tank. Stayed stuck a few times
  11. Jan 14, 2023 at 4:45 PM
    cizko33
    cizko33 New Member
    did you ever fix this? I’m gathering info to get mine fixed. Same issue. Sometimes it reads , sometimes it doesn’t. Hard to know when it’s not working.
  12. Sep 3, 2023 at 8:58 AM
    bluesteel731
    bluesteel731 Toy taco
    PNW Vancouver BC
    07 White TRD Tacoma DCLB
    FX-R III, Bestop, custom rock sliders, 2.5 ext RR kings 650/14, icon uca w/Delta Joints, AP expo, bilstein 5165 9.5" w/stem to eye, OBA ARB compressor and ARB rear locker, MR304 w/Cooper STT PRO 295/70/17, TAC WORX light bar mount behind the grill, Rock lights, OTRATTW switches, TAC WORX bed rack with hilift mount, TJM RTT w/annex, CMC
    2007 with 417000 km and just had this happen to me.... guess I'll have to drop the tank and replace at some point
  13. Sep 3, 2023 at 9:45 AM
    jtaco11
    Happen to me 2nd time LOL. Been pumping $20 due to work from home was in a hurry forgot to check the trip counter. 2 blocks away from gas station, bought 1 liter water bottle, downed it, filled with gas, and caught ride by from stranger. All good, right??? NOT!!! 1 liter not enough to start it on empty tank learnt the hard way. Ran back gas station, bought 1 gal water bottle, filled up, and ran back. Good to go!
    Went the cheap with cheaper solution, bought AAA and most likely I will pump full tank going forward. Let me know how the repairs/cost goes.
