Fuel gauge problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Deraj1288, Apr 28, 2011.
  1. Apr 28, 2011 at 12:24 PM
    Deraj1288
    Deraj1288 [OP] New Member
    Northwest
    06 6spd 4x4
    6" fabtech 33's
    hey i am new to this site. i have an 06' access cab 4x4 v6 6" fabtech w/33's . was wondering if anyone has had the same problem with their fuel gauge as me. my gas light is coming on most of the time after driving only about 160 miles, then i fill up and it only takes about 12 gallons, when its full it registers about half way above 3/4 of a tank. and everytime the light comes on at different mileage. i have taken it into a mechanic and he is telling me its my gauge cluster that went out (even though everything else works ) he checked the fuse in the back and says its good. had him check the float and that was fine as well. dont really want to fork over $800 to replace. can a fuse be bad even though it tests fine?
  2. Apr 28, 2011 at 2:02 PM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    I believe that would be your sending unit. Its the part that's on top of your gas tank that goes down into your gas tank. Pretty easy fix if your gas tank is low and you have the tools.
  3. Apr 29, 2011 at 3:04 PM
    Deraj1288
    Northwest
    06 6spd 4x4
    6" fabtech 33's
    ya thats what i have been told but when i took it in to my mechanic he replaced, put back together and said it did was doing the same thing so i donno
  4. Apr 24, 2012 at 8:28 PM
    Vixen36
    Vixen36 New Member
    Jamie
    los angeles
    2006 Toyota Tacoma 4x4
    I have a 06 tacoma and today the truck was registering at a half a tank however it suddenly ran out of gas, no warning light just shut off and wouldnt turn on. I thought maybe dead battery or something else but the only way it started up again was with a couple gallons of gas. I went straight to the gas station put in $30 and it registered as full tank which I know $30 did not fill my tank. What do you think the problem is with it regestering more gas then what is actually there?
  5. Apr 24, 2012 at 8:39 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    The gas pump isn't dependent on a sending unit to decide the tank is full, if it indeed isn't actually able to fill it would likely be something with the pump.
  6. Apr 24, 2012 at 8:47 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Possibly your fuel pump is taking a shit.
  7. Apr 24, 2012 at 9:21 PM
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    Fuel sock clogged at bottom, fuel pump, or fuel pump sending unit.
    Essentially, your tank needs to come down, and your FSU needs to come out.
    Good luck. . :)
  8. Apr 25, 2012 at 5:13 AM
    AnotherSilverTaco
    AnotherSilverTaco Well-Known Member
    South Texas
    2006 Double Cab 4x4
    CBI trailrider rear bumper, CBI Front Receiver, Warn M8000 Receiver Winch in Warn Multi-mount cradle
    This kind of thing has happened twice on my 06. It stopped on its own.
  9. Oct 12, 2019 at 4:52 PM
    tinner15!
    tinner15! Member
    Nick
    Pas area SO CA
    '07 4.0 V6 PRE-RUNNER
    I've got an '07 Tacoma , 4.0 V6 and just changed out the fuel pump with sending unit (Toyota Parts). When finished putting 10 gallons of gas in I started it & the fuel gage still measures 1/4 tank which is where it was prior to all my work. I understand there is a reset for the fuel gage which anyone can do, but haven't been able to find out directions. Anybody have it I'd sure be thankful for it. Please respond if you know it.
    Nick
