Fuel Gauge Reading
Discussion in 'Performance and Tuning' started by DanGer, Jul 3, 2009.
How many miles on 1/2 tank
  1. 100-150
    61 vote(s)
    22.8%
  2. 150-200
    145 vote(s)
    54.3%
  3. 200-250
    52 vote(s)
    19.5%
  4. 250-300
    9 vote(s)
    3.4%
  1. May 16, 2013 at 8:58 AM
    #41
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    I don't understand. Fuel guage says I need fuel I get some, divide miles travelled as reported by trip meter divide by gallons used. What is the point of comparing how many gallons per increment on the fuel guage that was designed only to meet the need to know when to get fuel?
  2. May 16, 2013 at 8:59 AM
    #42
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    This
    It's really not that difficult
  3. May 17, 2013 at 8:53 PM
    #43
    BamaToy1997
    Bill
    Navarre, FL
    Exactly correct. You will never have a linear fuel level change.
  4. May 17, 2013 at 8:58 PM
    #44
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Essex county NY
    23 trd OR DCSB 4x4 silver
    a cross on my rearview Circle mirror Scotch guard seats
    based on markings
    1/4 is 5 gallons
    1/2 4 more
    3/4 4 more
    Light on at about 17 gallons.
  5. Oct 22, 2013 at 5:45 PM
    #45
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Miles depends on fuel consumed and that depends on the model, engine, transmission, 2WD or 4WD (weight, friction).
    What is in the tank per the gauge marks:
    FULL TANK= 21 gallons
    3/4 Line= 16 gallons (5 to fill)
    1/2 Line= 12 gallons (9 to fill)
    1/4 Line= 8 gallons (13 to fill)
    Low Light= 4 gallons (17 to fill)
    E Line= 3 gallons (18 to fill)
  6. Nov 19, 2013 at 10:13 PM
    #46
    Socalrider600rr
    Socalrider600rr Well-Known Member
    Socal
    13 access TRD 4X4
    Jack in the Box antenna ball
    Don't mean to necro-post but I'm thinking of taking my new Taco back to the dealer to see if they can fix this problem. Once I get down to 3/4 on the gauge, it drops faster than Obamas approval rating after 0bummercare. Has Toyota come up with a solution for this yet? Is it worth taking to the dealer?
    Thanks
  7. Nov 19, 2013 at 10:15 PM
    #47
    OZ-T
    Peter North
    British Columbia
    No
  8. Nov 24, 2013 at 3:52 PM
    #48
    2012TACOMABOY
    2012TACOMABOY Active Member
    Maryland
    2012 Base 4x4 Debadged
    3 inch toytec lift with 1.5 inch rear aal
    Just a quick question. Is it normal that when I start my Tacoma it shows that I have a lot less gas then I remember having after my last drive. then it slowly goes up after I start driving?
  9. Nov 24, 2013 at 7:09 PM
    #49
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    I'd say not uncommon..my wife's 96 did that.
  10. Nov 24, 2013 at 7:53 PM
    #50
    BamaToy1997
    Bill
    Navarre, FL
    Thermal resistance has a bit to do with this. It is normal. My 97 does it, and almost every other vehicle I have ever owned does it. Also depending on if where you park is level when you start your truck. At the shop I park on a slight incline. When I start my truck it may show say 1/2 tank. Then when I pull out and start driving down a semi level road, the fuel level usually settles at an 1/8 tank higher.
  11. Nov 25, 2013 at 6:01 AM
    #51
    ABA180
    East Bridgewater MA
    While it's not the same thing exactly, my first car (79 Stang) would drop quick once I got to half a tank. That was due to me backing into something and denting the tank however.
  12. Nov 25, 2013 at 7:32 AM
    #52
    KingKoda
    KingKoda Never Satisfied
    Palmetto
    '12 TRD.S DCSB 4x4
    Boosted TRD/URD All Terrain Sleeper w/ Sockmonkey Decals Worth +666HP
    I gave up caring about the MPG, I've already bought the truck (MPG decision) and a few extra bucks here or there on gas isn't going to break my wallet. If it needs gas, I put gas in it. Some months I may get 18 mpg, some weeks I may get 12 mpg, I don't know. In the end, it doesn't matter, and if I did, I should have never bought the truck.
  13. Dec 6, 2013 at 12:17 PM
    #53
    TyNeumann110
    TyNeumann110 Member
    Tyler
    Houston, TX
    2011 DCSB PreRunner SR5
    Driving 40 years beyond my age I read 160-170 at half a tank. How are you guys averaging 20 mph? New spark plugs + air filter maybe? :confused:
    Another fuel gauge related question - when the gas light is on.. and has been on for a couple days, what's the farthest you've gone before stopping for gas? I've had my 2011 v6 4.0 taco almost two months now and already put 4k miles on it but I haven't gone over 30 miles with the light on. When I went thirty miles it took 18.8 gallons to fill up so I'm sure I could've gone further. Anybody?
  14. Dec 6, 2013 at 12:37 PM
    #54
    A_Ninja_Racer
    A_Ninja_Racer Well-Known Member
    Tampa, FL
    08 PreRunner TRD Debadged
    I fill up when the light comes on I might drive a few miles past but normal that's just what it takes me to get to a pump once it turns on. It may be a myth or an urban legend or something like that But I've herd that the reasoning for the light coming on at 17 gallons is to try and keep the fuel pump submerged and there for operating at a cooler temperature extending its life. Again could just be propaganda but who cares.
  15. Dec 6, 2013 at 12:48 PM
    #55
    YankeeVol
    YankeeVol This We'll Defend
    Darrell
    Anchorage, AK
    '13 DC XSP-X 4x4
    A little more than 150
  16. Dec 6, 2013 at 2:35 PM
    #56
    TyNeumann110
    TyNeumann110 Member
    Tyler
    Houston, TX
    Ah, I see. Well I definitely want to prolong fuel pump failure so I'll keep that in mind next time I think about stretching a tank of gas. Thanks for the info! (my fuzzy math shows anywhere from 50-80 miles on the light, 80 being @ steady <1500rpms lol)
  17. Jan 2, 2014 at 6:09 AM
    #57
    Matt Active Member
    PreRunner 2011
    I got 324 but noticed the tires had more PSI than they should have.
  18. Jan 2, 2014 at 8:01 AM
    #58
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That is the truth. The fuel is the lubricant for the pump. Also dissipates the heat from the pump. Simple thermodynamics. Run the pump dry and it will cause a tiny bit of damage. The more and more it done, the more the damage increases.
  19. Jan 2, 2014 at 8:40 AM
    #59
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    In agreement with Tor here.
    I never run the truck past 1/8th unless Im in a bad situation.... I also have a master tech friend who confirms and has replaced many a fuel pump due to people religiously trying to get every last cent out of each tank.
