Fuel gauge shows empty, 1/4 tank left and dealer service?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chumley, Sep 15, 2011.
  1. Sep 15, 2011 at 9:52 PM
    Chumley
    Chumley [OP] New Member
    Chum
    Central Coast California
    '11 Double Cab TRD Off Road
    SnugTop
    I am new to the forum and hate to start this way but I need some help right away to deal with a dealer service department and Toyota. I appreciate any help.
    I just got my new 2011 Double Cab TRD Off Road back from the shop. It was in for an incessant rattle in the area of the driver's side seat belt adjuster - right in my left just before my first week of driving the back roads around Bishop, CA and Minden/Tahoe, NV. Really stupid dealer service goof - nobody that knew the issue test drove the truck after they replaced the part they suspected rattled. That's not the real problem but it may be an example of what I may have to deal with.
    I have filled my truck now only 6 times. Each time it took about 16 gallons and I logged about 250 to 275 a tank. I aparrently wasn't paying attention. Well the last tank went to just the end of the fuel gauge scale and it was on the light for a while. I filled up and it took only a little over 16 gallons. It hit me that no car just gets 275 miles a tank these day so looked at the manual and it says that it takes 21.1 gallons. That left approx. 5 gallons to go! Now at 15 miles a gllon that's 75 and up to 100 miles is possible - on empty!
    The shop said that it was normal and that 3 gallons were to remain in reserve. It was 5 gallons left i said - what happened to the other 2? Don't they know math?
    So is this normal? Do you all have to fill up at 16 gallons?
    I would like to be able to take this to the dealer so if any of you can state what you feel is going on in terms the dealer (and Toyota) can work with it would be greatly appreciated.
    Thanks in advance.
    Chum
  2. Sep 15, 2011 at 9:56 PM
    BRYLONATOR
    BRYLONATOR I now own a RAM....shoot me
    Denver, Colorado
    Chillin in a 120!
    I actually am always dumping in around 18 gallons per fill up. I drive a while with the light on and then hit the pumps. If I use 91 octane...I can get about 325 miles.
  3. Sep 15, 2011 at 10:01 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    The light is suppose to come on when you have 3 gallon left, in a perfect world.
    If you're on a slight incline or decline, it will skew the float and the light may come and go. Your truck may not be 100% level in the first place which may through the reading just slightly off.
    I've had my light come on and fillup with only 16.XXX gallons. Once in a while, I may fit 17 gallons.
    Also, for the fuel tank rating. That's questionable too. Your tank may theoretically hold 21 gallons. But in use, maybe only 19.5 gallons of fuel will fit in it due to the dimensions or whatever.
    Either way, it's not a problem. Don't sweat it.
  4. Sep 15, 2011 at 10:04 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    If I drive 100% free-way I have at least 4 gallons when the light comes on. In city/ mixed it is 3 gallons left when light comes on.
  5. Sep 16, 2011 at 8:46 AM
    textoy
    textoy Well-Known Member
    Fred
    Texas
    2011 4x4 TRD DC
    there is a thread around somewhere that shows a breakdown of what you have left at the marked increments. It is pretty accurate. At 1/4 tank you have lots of miles left.
  6. Sep 16, 2011 at 9:04 AM
    ericb
    ericb I'm a very neat monster
    Dexter
    surface of the sun
    Truck So Good
  7. Sep 16, 2011 at 9:20 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    Normal, not a problem. Would you rather be supprised when it ran out of gas? Mine does it at around 17 to 17.5 gal used.
  8. Sep 16, 2011 at 9:22 AM
    &erson
    &erson Well-Known Member
    Sunshine State
    4x4 SR5
    Wet Okoles, Weathertechs, All-Pro Rear Bumper/Hitch & Sliders
    i glance at my odometer when the light comes on, and note that i have 3-4 gallons left to go
    usually refill in next 50 or so miles
  9. Sep 16, 2011 at 9:55 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    When I fill up it typically takes 15 - 16 gallons and the light has yet to come on in my truck.
  10. Sep 16, 2011 at 4:17 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    You have got to explain this one to me. :confused:
    I constantly put in 17.5 gallons as the light comes on.
    To the OP .... for a while I experienced a similar rattle at my left shoulder. I had forgotten about it until I read your post. Now that I think about it I haven't heard that (knock on wood) for some time. With the cooler weather returning we'll see.
  11. Sep 16, 2011 at 4:40 PM
    saugus
    saugus Well-Known Member
    My corolla light comes on at about 8.5-9 gallons down. At 10 down it is off the chart. It supposedly holds 13 gallons but the most I have ever pumped is around 10.5.
  12. Sep 16, 2011 at 6:30 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Gee folks... it ain't rocket science!
    Some TWers have been recording how many gallons to fill a tank when they get gas at various gauge levels...
    The 21 gallon tank has (+/- 0.5 gallon):
    16 gallons at the 3/4 full gauge line (down 5 gallons)
    12 gallons at the 1/2 full gauge line (down 9)
    8 gallons at the 1/4 tank line. (down 13)
    4 gallons at the E-LIGHT (down 17)
    3 gallons at the E LINE (down 18)
    E line to empty tank is 3 gallons ('reserve')
