Fuel guage issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BroncoDuke, Mar 4, 2016.
  1. Mar 4, 2016 at 10:13 AM
    BroncoDuke
    BroncoDuke [OP] Well-Known Member
    DUKE
    Fort Gibson,OK
    06 DCLB Sport 4x4
    I recently had my fuel gauge stop working between the 1/8 of a tank and empty. The needle stops around the 1/8 of a tank level and just stays there until I run out of gas. when I turn the ignition off the gauge falls all the way like it should, it just never registers less than an 1/8 of a tank to where the orange light comes on. I ran out of gas, then pumped 23 gallons into the truck and went 395 miles before it ran out again. 2nd time was intentional, but truck took 23 gallons again. any ideas thanks
  2. Mar 4, 2016 at 12:39 PM
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4×4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    Check the connection at tank.Negative ground on rear frame by driver side shock.maybe at tank.
  3. Mar 4, 2016 at 12:54 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    bed comes off
    fuel sender and float assembly comes out
    new one goes in
    you can't explain that
    Jimmyh likes this.
  4. Mar 4, 2016 at 1:52 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    What he said. ^^^^^
    Or just make sure you fill up before you run out again.
  5. Mar 4, 2016 at 4:57 PM
    BroncoDuke
    DUKE
    Fort Gibson,OK
    06 DCLB Sport 4x4
    first time I ran out was by mistake, second time was on purpose to make sure there was an issue, thanks I will check the connections.
  6. Mar 4, 2016 at 7:43 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    From what I understood is that it works fine between 1/8 of a tank and full, it just never drops below 1/8th tank.
    If that is correct then the float is sticking inside of the tank, it isn't a connection issue.
    Fenwick1993 and 12TRDTacoma like this.
  7. Mar 4, 2016 at 7:51 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    U have nothing to contribute to this thread, but I do have a question.
    What are you filling up with? Magic gas? 395 miles, hot damn thats some good mileage per tank!
  8. Mar 4, 2016 at 7:57 PM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    This. Sometimes it can be cleaned up and it will work again. Mine worked right for about a year after I did that. Now it is failing again- it'll say it's empty when it's still got a half tank.
  9. Mar 4, 2016 at 8:05 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I was wondering how he got 23 gallons into a 21 gallon tank.
    Must be the filler neck etc...
  10. Mar 4, 2016 at 8:53 PM
    Fenwick1993
    Not Fenwick
    Chesapeake, VA
    I didn't even think of that- I figured it must be a second gen thing. :notsure:
  11. Mar 24, 2016 at 3:42 AM
    BroncoDuke
    DUKE
    Fort Gibson,OK
    06 DCLB Sport 4x4
    These are a few of the questions I had myself, I had only put around 21 gallons before, but yes with the 23 gallon fill up I had gas all the way up to the cap, and yes the 395 mile blew my mind to, before I had managed 330 or so. My problem is not that my truck shows empty when full, it is it shows half a tank when empty, I reset my odo when I fill up and when the truck hits 275 miles I fill it up again.
  12. Mar 24, 2016 at 6:32 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Read my post above. Your float is sticking or defective. The float is on the fuel pump assembly inside the gas tank.
  13. Mar 24, 2016 at 8:32 PM
    BroncoDuke
    DUKE
    Fort Gibson,OK
    06 DCLB Sport 4x4
    thanks Jimmyh, I plan on replacing it when I get around to.
