Fuel Guage malfunctioning when filling up, dash guage only goes to 1/4 tank
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kyleTRDtaco12, Nov 3, 2015.
  1. Nov 3, 2015 at 7:35 PM
    kyleTRDtaco12
    kyleTRDtaco12 [OP] Well-Known Member
    Kyle
    New Jersey
    2012 Toyota Tacoma Base DCSB 4x4 V6 6MT (202)
    TRD Cat-Back Exhaust TRD Sport Package Springs & Shocks (Front Linear Coil Springs, Rear TSB Leafs) Front & Rear Toyota/Bilstein 40mm Shocks) Silver Toyota 16" SR5 Wheels with 265/70/16 BFGoodrich Rugged Trail T/A Tires w/ Locks OEM Black-Chrome Housed Headlights (SR package) OEM TRDpro Grille Insert RokBlokz Rally MudFlaps w/ Stamped Logo OEM 'TRD Sport' Bedside Graphics TRD QuickShifter w/ TRD Shift Knob Hawk HPS Front Brake Pads w/ Brembo Blank Rotors OEM Front Aluminum Skid-Plate eBay TRD seat covers Rear Diff. Breather Mod A/C Drain Extension Mod OEM Fog Light Kit OEM Intermittent Wiper Switch OEM Bed D-Rings OEM Bed Mat OEM Door Sill Protectors Blacked-Out Badges (from Xrunner 205 Black Sand Pearl) Pop & Lock Tailgate Handle TruXedo TruXsport Roll-Up Tonneau Cover AVS BugFlector II Front Bug Guard AVS In-Channel Window Vent Visors TRD High Pressure Radiator Cap Stubby Radio Antenna Ultra-Gauge EM v1.2 w/ Windshield Mount BullaCulla 7-Pin Relocation Bracket Misc. Stickers
    Hey everybody I got a weird problem with my 2012 Tacoma v6 double cab short bed 6-speed manual 4x4... is it the second time this has happened... what's going on is every time I fill up at the gas station, the gas gauge only goes up to a quarter tank regardless of how much gas was originally in the tank. Now I can get the problem to go away by disconnecting the battery then reconnecting it and it will work normally but only until the next time I fill up and then I will only go to a quarter tank even though the tank is completely filled in reality. I have no idea what the problem is the only thing I can think of is the sending unit and I really hope that's not the case because isn't it in the tank on these trucks? If anyone can offer some insight on what's going on I would greatly appreciate it thanks in advance
  2. Nov 3, 2015 at 7:53 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    Damnit lol, that sucks but ok, thanks man, I do appreciate it
  3. Nov 3, 2015 at 8:35 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I have heard that it is easier to remove the bed than drop the tank...
    kyleTRDtaco12[OP] likes this.
  4. Nov 3, 2015 at 9:00 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    Same here. They used to do that in the dealer I used to work at...
  5. Nov 4, 2015 at 12:27 AM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    Maybe measure the sending unit output to check and see if it's that or the gauge cluster
  6. Nov 4, 2015 at 6:35 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    warranty
    either new combo meter or sending unit
    [my 4runner did that when it was at 4000 miles and it was the combo meter]
  7. Nov 4, 2015 at 6:49 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    IIRC, it doesn't work on DCSB's, since the pump and sending unit assembly end well under the cab.
    One question about the issue though. Are you leaving the key in the off position while fueling? I've found a huge delay in the gauge if the level rises while the key is in the run position. And yes, there was good reason for this, before I get preached at for "SAFETY".
  8. Nov 4, 2015 at 7:30 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I guess that would be another reason to NOT get a short bed truck.
  9. Nov 8, 2015 at 6:36 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    Yes, key is in the off position
  10. Nov 8, 2015 at 6:37 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    Unfortunately, im a year out of warrentee already, but the next morning it fixed itself again, it's very weird lol .. Guess we'll see what happens when I fuel up tuesday lol
  11. Nov 8, 2015 at 8:04 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    This has happened to me like 3 or 4 times randomly.
    Once I turned the car off and restarted, then drove around a bit, it would slowly move to full.
    It's really completely random, I think has time it happened to me was last year. No rhyme or reason. I just chalked it up to a glitch.
  12. Nov 16, 2015 at 11:12 PM
    kyleTRDtaco12
    Kyle
    New Jersey
    I agree man, after I filled up the last time. It worked normally... So weird... And yeah... Its like some sort of glitch that I kinda wanna blame on ambient temperature, as well as the gas station attendant.. Because silly NJ won't let you pump your own gas..
