Fuel injector 2tr-fe turbo size
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tap1, Feb 1, 2016.
  1. Feb 1, 2016 at 6:28 AM
    Tap1
    Tap1 [OP] Member
    Puerto Rico
    2011 Tacoma 2.7l
    Turbo
    Fuel injection turbo size
  2. Feb 1, 2016 at 9:12 AM
    billybob50
    billybob50 Well-Known Member
    Bob
    05 Basic Gold Tacoma Automatic
    Dog friendly, with dog snot on inside windows, with of course a/c! Mag 16 inch wheels from a Mazda.
    Your like my wife, wish you would go into more detail?
    Blais03 likes this.
  3. Feb 1, 2016 at 10:16 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Speedytech7 likes this.
  4. Feb 1, 2016 at 11:32 AM
    Tap1
    Tap1 [OP] Member
    Puerto Rico
    2011 Tacoma 2.7l
    Turbo
    I have a Tacoma 2.7L turbo what fuel injection I can use?
  5. Feb 1, 2016 at 11:37 AM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    Yeah it's not that simple, what kind of boost pressure are you running, what is the capacity of your fuel pump, are you running a piggyback for your fuel maps. We need a bit more info to work with here
    Blais03 likes this.
  6. Feb 1, 2016 at 12:11 PM
    Tap1
    Tap1 [OP] Member
    Puerto Rico
    2011 Tacoma 2.7l
    Turbo
    8psi fuel pump is AEM320 piggyback AEM
  7. Feb 1, 2016 at 12:12 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Are you wondering which size or type of injectors to use?
  8. Feb 1, 2016 at 2:37 PM
    Tap1
    Tap1 [OP] Member
    Puerto Rico
    2011 Tacoma 2.7l
    Turbo
    Size
  9. Feb 1, 2016 at 5:16 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
