Fuel Injector cleaning
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Glocktex, Jun 13, 2009.
  1. Jun 13, 2009 at 12:16 PM
    Glocktex
    Glocktex [OP] Active Member
    Texas
    05 PreRunner
    Ok so after using my search button and reading what I can, I am still uncertain. Does one or should one, clean the fuel injectors? If so with what and why? Is the dealer 'fuel injector' clean any big deal? Can it be done by me?
    I appreciate the info.
  2. Jun 13, 2009 at 12:34 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    Run a can of Seafoam through the gas now and then. Gets and keeps them shiny new!
  3. Jun 13, 2009 at 12:49 PM
    Glocktex
    Texas
    05 PreRunner
    I've read posts about this seafoam. Some people say don't. Some say do. Some say the fuel will do all that needs to be done. If Toyota recommends cleaning the fuel injectors, there might be something to it??
  4. Jun 13, 2009 at 1:32 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Glocktex your going to hear a lot of different recommendations on this I would suggest going on Google and doing a little research. But here are some recommendations from me. Some car companies recomend not using fuel injector cleaner and others do. I don't think it really matters, I think that most cars need it.
    I also think that a lot of it depends on the quality of fuel you put in. Some fuel companies use a small amount of it already in the fuel like Shell for example but it can cost a little bit more. I always put it in around every 4000-5000 miles or right after every oil change. I fill up at Costco which from what I understand does not use any kind of cleaner already mixed in so that is why I put it in every oil change. If you fill up at a place that does use cleaner, than you may want to wait every 8000-10000 miles or after every two oil changes.
    I have no way of knowing what is the best product, but I have heard a lot of people say that the Techron Concentrate Plus by Chevron works the best. So that is what I use but I'm sure that other companies products such as Lucas, STP cleaners work good as well and remember too change out that fuel filter every 30,000 miles as well.
  5. Jun 13, 2009 at 5:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Federal guidlines require Fuel companies to have a certain amount of detergents in their fuel. Some use the min. required, while others use more.....I use a quality fuel, and never had to use an injector cleaner in any of my vehicles. :)
  6. Jun 13, 2009 at 10:33 PM
    sebiotacoma
    sebiotacoma Well-Known Member
    Corpus Christi Tx
    TRD OFF ROAD
    wet okole seat covers,weathertech floor mats,wheel skin wheel cover,factory bed mat,factory skid plate,s.s. n-fad steps,undercoating,transmission TSB,REAR SPRING TSB,TRUCK BED DIVIDER/ROD HOLDER,paint protection film on hood-lamps-fogs-door-edge / avid off road rear bumper guard
    I have a 2002 gmc envoy with 160000 miles. I have no miss fires recorded on the tech 2 gmc scanner. I also use 2 bottles of techron very 5000 miles. GREAT STUFF
  7. Jun 14, 2009 at 6:58 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Go to an Autoparts store and buy some fuel system or fuel injector cleaner - (the stuff you pour in the gas tank). It's probably the easiest, cheapest, and fail safe way to clean the system initially.
    I use TECHRON PLUS fuel system cleaner. I put a bottle in about every 6 monhts - 1 year. They recommend using it at every oil change, but that's a bit much (gets expensive).
    http://www.chevron.com/products/ourfuels/prodserv/additives/tcp.aspx
  8. Jun 14, 2009 at 8:42 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    I was told that those bottles are useless. If you really want to clean the injectors there is a kit that connects to the fuel line. You actually disconnect the fuel line and block it off, then connect this pressurized aerosol can and run the engine on just this can until it is empty.
    I have never used it though...
    Nibblekibbles likes this.
  9. Jun 14, 2009 at 8:54 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i use a bottle of techron with every oil change......never had a problem with it.
  10. Jun 14, 2009 at 10:06 AM
    Yuma Taco
    Yuma Taco Well-Known Member
    Lee
    Yuma, Az
    09 PreRunner DC TRD
    35% tint windows, OEM black running boards, OEM black roof rack, Foglight mod, De-badged & Sockmonkey Horns decals added, Two ammo box storage units (removed), 110 volt & 12 volt outlets for back seat area, EGR Slimline inchannel visors (all windows), Fold-A-Cover G4, Tonneau, Bedmat.
    In the bike world "Seafoam" is legendary.
    I used it on a regular basis in my carburetoraed (sp) bike. When people had problems just short of a full tare down, this stuff worked.
    I'll be running some through on a regular basis.
    My thoughts,
    Yuma Taco,
  11. Jun 14, 2009 at 10:12 AM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Buy some super unleaded and call it a day!
    robertjohnsonjr likes this.
  12. Jun 14, 2009 at 11:09 AM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    I use the Lucas fuel injector cleaner every other oil change.
  13. Jun 14, 2009 at 1:46 PM
    Janster
    Jandy
    Lancaster, PA
    And that would be the next step if the bottles don't work.
    For me, the bottled stuff is just 'maintenance'. I buy it twice a year and hope it does what it advertises. I might see a very very slight throttle response difference, but that could just be in my head.
    The pressurized setup is neat and probably more valuable if your system is really messed up.
  14. Jun 15, 2009 at 5:28 AM
    LEEP
    LEEP Well-Known Member
    LEE
    CONNECTICUT
    O8 TACOMA TRD
    Bg cleaner in fuel tank evert 10 thou dealer should have it USE B-4 OIL CHANGE NOT AFTER
  15. Jun 15, 2009 at 2:16 PM
    lasllc
    lasllc Wait. . what’s wrong here
    Southwest RedRocks
    13 SuperWhite DCSB Sport TRD
    SnugTop Super Sport, BedRug mat, Redline Tuning hood lifts, LED interior lights, 3D carpet protectors.
  16. Jun 15, 2009 at 2:38 PM
    06BLUEDBLSPORT
    06BLUEDBLSPORT Well-Known Member
    Colin
    Fort Wayne Indiana
    12 Tundra DC SR5 4x4 5.7L
    True Dual Flowmaster 40 Series exhaust, Volant CAI, HIDs, Raptor series Side Steps, Weathertech Floorliners, OME 613 Shocks and Coils with Diff Drop, Rear Bilstein 5100 Shocks, ToyTec AAL, Fearless Fabrication Front Bumper
    I put STP injector cleaner in my truck and brothers truck and my other brothers 4runner and we all could feel the difference
  17. Jun 15, 2009 at 2:59 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    thats just butt dyno man!
